The Grande Utopia Project
    VR3 Posts: 29,642
    Yeah the first and second generation grande is designed to be faced straight ahead. If it sounds better toed in, then something is wrong either with the upstream gear or the speakers themselves.
    That baffle is an engineering masterpiece
  • Gerres26
    Gerres26 Posts: 874
    Definitely makes sense to run them the way they were designed. I find myself preferring to run most speakers I’ve owned with very little to no toe in. As long as it was a well designed speaker with good dispersion properties then there is usually no issue with center fill or instrument placement in the playback and it can really widen the soundstage. I’m finding it true again with these Vandy 5As I’m currently getting dialed in.
    A little off topic, but I feel that some of these older generation top of the line speakers are some of the best buys and biggest bang for your buck that you can get in the hifi world. There are a hand full of manufacturers that offer wonderful value but for the most part, as you probably know, the performance to price goes well into your favor when you can snag a set of speakers like you have here.
    VR3 Posts: 29,642
    100% agree, i dont even look at new speakers anymore, the prices are crazy and I don't much care for the sound either. Im not a huge fan of the overly critical, highlight all of the nuances in a mix sound people like. Music doesn't even sound like that. You get a band playing together and you just won't have that experience.
    But I absolutely agree, these 15 to 20 year old speakers, especially if you plan to upgrade the crossovers to more modern caps And resistors... Huge bang for the buck and minimal chance of money lost and sometimes even a gain.
    I've found owning these, as off axis speakers, the front end had to be impeccable.. If there is any type of error in the front end, an artifact, whatever, an off axis based speaker really really shows it. Thats why I said if you like the sound better toed in then something else is off in the chain that needs to be addressed.
    These speakers have really opened my eyes to component and cable choices, removing artifacts and low level noise.
    VR3 Posts: 29,642
    So funny to return back to this thread and see this comment from April and how different the system is now... I am very close to doing everything I can think of sans replacing stuff inside the components... lol
    Setup now...
    RG11 belden, 14 awg OFC copper from outdoor cable box to modem direct wired
    3 x Dedicated 20 amp circuits
    Netgear CM2000 modem
    >Audiolund Reference Ethernet Cat8 and DC power cable
    Netgear MK83 Tri Band Mesh router hub
    > Netagear devices powered by Teradak W200 linear power supply with Audiolund Reference PC
    Lumin U1
    >Lumin X1 Power supply, stock umbilical
    >Audiolund Signature PC
    >Audiolund Xtreme 1.5M Digital Cable with BNC ends
    ANK PRO5.1 DAC
    >Emission Labs Mesh 5u4g rectifier tube, Tung Sol 12au7, JJ Ecc99
    > Audiolund Xtreme RCA Cables, 1m
    Musical Fidelity KW750
    >Revelation Audio umbilical cables
    >Audiolund Xtreme Power Cable, High Powered Version
    > Audiolund Xtreme 6 wire version speaker cables with Furutech ends
    >1998 Jm Lab Grande Utopia with partially modded crossovers
    VR3 wrote: »
    I believe the rig is where it needs to be.
    Lumin U1 with Kenneth Lau umbilical using LEEDH processing volume
    Wireworld Starlight BNC
    ANK DAC 5.1 Pro with Quad C Cores
    Duelund Dca 16 awg ICs
    Musical fidelity kw750 amplifier with revelation audio umbilical cables
    Duelund dca 12 speaker cabling
    JM Lab Grande Utopia with the band aid mod
    Duelund Dca 12 600v power cabling thru out
    All network components have linear power supplies, supra ethernet. Nighthawk mesh system and modem.
  • jdjohn
    jdjohn Posts: 3,416
    VR3 wrote: »
    Always interesting to follow your progression. I've got Supra and DH Labs cables based on earlier iterations with your journey. Looks like Audiolund is your current darling.
    But, I thought you were a bare-wire guy with speaker cables, so curious about your decision to go with terminated ends.
    VR3 Posts: 29,642
    That is just how they were made and terminated. They are locking banana plugs and the wbt posts are locking so should have a great connection. I am a firm believer otherwise is no connectors.
    Audiolund uses duelund dca wiring which I am a huge fan. I love the synergy of that wire with the Focals. Really a great combination!
  • jdjohn
    jdjohn Posts: 3,416
    Good info, thanks B) I currently have Supra Quadrax bare wire for my Mezzo Utopias.
    VR3 Posts: 29,642
    The quadrax is a great wire. I did find the dca 12 oil baked cotton to have a slightly fuller sound. I still recommend quadrax to anyone asking for a solid wire that won't break the bank
  • jdjohn
    jdjohn Posts: 3,416
    edited October 2022
    I am quite pleased with the Supra Quadrax for speaker wire...thanks again for that recommendation. I also use the Supra EFF-I cable, and Supra RCA locking interconnects...DIY construction after purchasing from that Supra seller on eBay.
    VR3 Posts: 29,642
    For the knick knacks
    treitz3 Posts: 20,225
    That will come in very handy, Trey. I have about 6 or 7 of them in the audio room. It helps to keep all of the nick knacks, spare parts, measurement and vinyl tools, lasers, measurement tools and the like all in the room but hidden and relatively clutter free.
    Are you planning on staining that the same color as your speakers?
    VR3 Posts: 29,642
    I have a cherry stain that is similar but a tad darker... I might do that for sure!
    I have collected a bunch of articles and brochures about the speakers as well that I plan to keep in there...
    Those little boxes for 10 bucks are pretty sweet!
    VR3 Posts: 29,642
    Finally found a 12au7 in my stash that wasn't bad and I like the results!
    https://youtu.be/S33DRBk8EwY
    Clipdat Posts: 13,101
    Nice slippers bro
    VR3 Posts: 29,642
    Thanks man! Toasty!
    Do you have the speakers pulled out more than usual today?
    VR3 Posts: 29,642
    Nah thats my normal location but when I use half zoom on my camera it kind of gives everything a slight fish eye look
    pitdogg2 Posts: 27,634
    Looks like they are 6' out into the room LOL
    You can tell when he pulls them out, as the front of the speakers will be closer to the front of the carpet. He listens to them in nearfield to change things up every once in a while.
    VR3 Posts: 29,642
    It's not really near field per say, I still sit approximately 9 ft away but I sit further back to the back wall and the speakers are 5 ft out.
    Really sounds awesome
    VR3 Posts: 29,642
    You have to remember just how large the grandes are...
    20ish wide, 30ish deep, 70 tall, 450 pounds so pulling them out 2 ft off the back wall brings the drivers a good ways out into the room
    450lbs lolol so crazy
    Yeah, no flinging those off your shoulder when you trip!
    VR3 Posts: 29,642
    Exactly you would just die
    VR3 Posts: 29,642
    Should sound half way decent on headphones I would guess, haven't listened to it beyond my cell phone
    https://youtu.be/lXmGC80fEjo
    I thought I heard that song before! I just listened to it about 4 days ago. I have another track by them marked as a favorite (If memory serves me correctly....been listening to a lot of new music as of late)
    VR3 Posts: 29,642
    I dig it, the bass is very hard hitting and the staging is great
  • smartie_panta
    VR3 wrote: »
    Amazing! Who's the artist?
  • jdjohn
    jdjohn Posts: 3,416
    Sounding great. Any plans to add your famous defraction pads to those bad boys?
    VR3 Posts: 29,642
    Thanks guys!
    I will have to look up the artist and get back to you
    These don't need diffraction pads, I tried them initially and quickly removed , hard to tell in the photo but the main baffle is rounded versus flat
