1166167169171172200
    VR3 Posts: 29,429
    I run all audiolund, no regrets
  • maxward
    maxward Posts: 1,693
  • DarqueKnight
    DarqueKnight Posts: 6,765
    invalid wrote: »
    Have you ever tried one line of one brand of cables throughout your entire system? I've always been Curious about this, but have never tried it.
    I have AudioQuest speaker and balanced interconnects in my main stereo rig. I tried their power cords and digital cables also, but preferred other brands. For now, I like AudioQuest for speaker and balanced interconnects, Revelation Audio Labs digital cables, and PS Audio power cords.
    nooshinjohn Posts: 25,926
    That is a work of art.
  • Milito
    Milito Posts: 2,003
    Beautiful table, congrats.
  • newbie308
    newbie308 Posts: 803
    That's gorgeous 😍
    treitz3 Posts: 19,992
    Jody, that is freakin' NICE my man. Enjoy brother!
  • jdjohn
    jdjohn Posts: 3,357
    Thanks fellas! She is gorgeous, for sure, but also definitely more than just a pretty face. This turntable takes things (for me) to 'the next' level.
    I had been on a direct-drive kick for the last several months, trying to find a good match for the MA-505L tonearm, which is basically a 12" arm. Frankly, the arm sounded great on everything I mounted it on, so I thought, "This is great. I like this arm." I bought the 505L (a couple of years ago) after thoroughly enjoying a 'regular' 505 arm on a few different tables. I highly recommend any version of the MA-505 arm.
    Anyway, the Micro Seiki BL-91L turntable is a bit of a unicorn (compared to the regular BL-91), and if you find one, it is almost always a 220VAC unit, so requires a transformer.
    To try and shorten this post, I found a BL-91L for sale, which had an SAEC arm (that I didn't really want), so I worked with the seller on getting JUST the turntable (including armboard), and everything worked out. He included a 110>220 transformer.
    The sound I'm getting from this combination is a revelation. I don't know if it's simply a build quality upgrade from other belt-drive tables I've tried, or perhaps the armboard being made from a big disc of milled, polished aluminum (or chromium?) vs an armboard made from wood, or a composite. For whatever reason, the PRAT with this setup has been elevated.
    Needless to say, I'm enjoying the HECK out of this turntable and tonearm setup. FWIW, it doesn't matter what cartridge I choose...they ALL sound better.
    Very nice, sir! Enjoy brother!
    @jdjohn… get your hands on a Gold Note PH10 if you really want to take things to the next level. My PH5 is an eye opener for me, so I can only imagine what the next one up can accomplish with your setup.
  • jdjohn
    jdjohn Posts: 3,357
    @nooshinjohn I've gone fairly deep down the phono preamp rabbit hole, and my current reference level is the Musical Fidelity Nu-Vista Vinyl. It is exceptional. I also own a unit from the very boutique UK brand, the Bigbottle Audio tube phono preamp (BB3), that requires loading plugs. It scratches my itch for a tube phono preamp.
    For awhile, I was determined to obtain the heralded Herron VTPH-2A phono preamp, but the feeling passed. Those units utilize 6 tubes, which (in my opinion) opens the opportunity for 6X the noise.
    Happy to do a swap for trial purposes :)
    Jody, when speaking with Bob Carver, he stated thet the more tubes in a phono pre, the better.
    This contradicts what you are saying.
    His TOTL phono pre had many tubes. The model escapes me right now. FWIW.
  • jdjohn
    jdjohn Posts: 3,357
    Tom,
    In a utopian world, where all tubes perform as expected, it would be ideal to have 'the more tubes in a phono pre, the better'. But let's be honest...that is not reality. Tubes are fun...tubes are noisy...tubes are tubes.
    In the world of tube phono preamps, the Herron still reigns supreme (based on reviews), but Manley Labs has a few choices that cannot be ignored.
  • Wardsweb
    Wardsweb Posts: 942
    The only constant is change. I swapped some gear around in my backroom system.
    Yamaha QL-Y5F turntable
    Juicy Music Tercel phono pre
    Sonic Euphoria PLC preamp
    Music Fidelity Pan CDP (Germany)
    DIY ST70 amplifier
  • xsmi
    xsmi Posts: 1,801
    Wardsweb wrote: »
    DIY ST70 amplifier
    Have I had a stroke or is there a JVC on that turntable? 🤣
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Wardsweb
    Wardsweb Posts: 942
    xsmi wrote: »
    Senior moment. It is a JVC QL-Y5F.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,308
    I found a Janis Interphase 1A crossover/amplifier in a nearby town that I can try and reverse engineer the schematic. tw0czimge8bl.jpg
  • newbie308
    I let the magic smoke out of my Jolida JD502B. Time for some refurbishing and then it's going up for sale.
  • jbreezy5
    jbreezy5 Posts: 1,141
    newbie308 wrote: »
    Bummer!
  • Wardsweb
    Wardsweb Posts: 942
    newbie308 wrote: »
    I have run into that on a couple of Jolida pieces. Had a JD1000RC that I had to totally resolder the entire board.
  • newbie308
    I think this unit is from 2001, so the electrolytic capacitors are due for replacement. It is stock with no upgrades or alterations, so I think it will respond well to a tune-up.
  • Wardsweb
    Wardsweb Posts: 942
    Moved the Arte Forma 2A3 into the sunroom. Something special about SET and horns.
  • Wardsweb
    Wardsweb Posts: 942
    The Gilmore Raptors moved to the dining room.
    txcoastal1 Posts: 13,513
    edited May 2023
    @Wardsweb Hey Luther, you still sporting the modded JBL and setup in the living room?
    Loved that sound?
    --Ron
  • Wardsweb
    Wardsweb Posts: 942
    txcoastal1 wrote: »
    Loved that sound?
    --Ron
    My main system and still my fav.
    xschop Posts: 5,185
    I'll have to try the bean bag mod this weekend. Looking good.
    pitdogg2 Posts: 27,054
    xschop wrote: »
    That is a bass trap. The more bass it traps the larger the bag gets.....I've seen it in person, pretty cool!
    Damn. I must be a bass trap then.
