What are those speakers? Are they mirror imaged with angled front baffles or is that an illusion?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
More of an illusion. Those are Odyssey Audio Liquids.
Here’s from the top. They ain’t square!
Aaron
Enabler Extraordinaire -
Those are gorgeous speakers! Wow!
Sold stuff... didn’t buy anything but moved stuff around.
R2R with dbx now lives in the main rig. Running some 1970’s tunes on 10” reels. Recorded @ 3 1/4 40 years ago (or so).
Did I know you had an A77?
I knew there musta been some reason that I like you...
[/quote]
Prbly not. It’s been in the wings waiting for it’s chance to perform.
Old tapes are a bit stretched at the start and end. Wow and flutter is noticeable but it sure sounds nice.
Hmmm. Tape is fine. Take up side doesn’t have good torque with a full reel.
Anyone know where the zerk is on that side? I’ve got grease...
I rebuilt the dbx a couple years ago and pulled the stock opamps and put in Burson. Made quite the difference.
Didn’t I threaten you with a visit some year?
Aaron
DBX? Burson? I have some DBX stuff. Enlighten me...I rebuilt the dbx a couple years ago and pulled the stock opamps and put in Burson.
Thnx Tony
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
The dbx box is the skinny critter just in front of the R2R. It is a compression/decompression device for tapes. Was quite the thing in the 70’s and 80’s. Works well for me. Got some dbx rekids too...
Burson makes replacement 8 legged opamps so you can pull the elderly ones out and get something from this century in. Best description of the results would be an extended frequency range with improved dynamics. I did a full capacitor refresh as well as much better diodes in the power supply.Aaron
[/quote]
anytime -- you know, when we're not all infection threats.
@KennethSwauger is doin' the down to the nuts and bolts rehab of an A77 even now* -- bet he knows about the zerk in question (if a zerk it indeed be)!
_________________
https://youtu.be/wiwx2J5Kh6c -
Beatcha to it - questions have been filed in triplicate with Sir Swauger.
Didn’t realize what the Barry attachment was - lol - nice one !!
Aaron
@gp4jesus
What dbx gear do you have?Aaron
A couple of their DriveRack PA XOs. AKA DRPA in other circles.@gp4jesus
I remember that line of stuff was pretty cool 😎 consumer gear. The DRPA* is pro gear. Maybe a factor for the op amps.
*along w/ the DRPA+ & DRPA2
Did you find the Cap upgrade challenging?
Thanx TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Cap upgrade - that one was easy. Single board, easy disassembly. There are two models of the dbx224. One is made in Japan (the one I have) and the other made in USA. I've had them both. The USA one is overly complex compared to the Japanese produced one.Aaron
@ALL212 we should PM from here forward.
Not that it doesn’t apply, because it does. I believe this fall under esoteric. Please PM If you recall the make and model caps.
Big thanks. You are part of what is right w/this forum. TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
As long as I’m in need of attention:
Rig #2 got cleaned up and extended and Rig #3 taken down.
Aaron
I miss my 2.3’s, I’m on the hunt... not doing good..nooshinjohn wrote: »It says "SDA's are forever"
Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
where are you located
Decatur, Georgia 30033nooshinjohn wrote: »
Some final words,
Warren -
For you sir...
https://www.facebook.com/marketplace/item/272494847625258/?ref=search&referral_code=undefined
Now we only need to get the Polkie Express up and running to see if we can get them a little closer.
@ALL212 the only problem I see with your hifis is that you need more Yamaha equipment.
bwahahahahahahahahahaaaaaaa...
ALL212 - Those speaker stands are cool but I sure hope you don't acquire any cats in your house!George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »ALL212 - Those speaker stands are cool but I sure hope you don't acquire any cats in your house!
I assumed he was already a cat owner. 😺Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
Aurender n100h, Benchmark DAC2 HGC
Arcam SR250, Parasound JC5
Revel F208, SVS SB-4000 -
HEY! I’ll have you mooks know that those were actually planned which is not something I normally do.
Originally those are the three tubed stands, two of which are filled with shot and/or sand. Still a bit ringy, especially the 3rd tube that was intended to put your cable in. 100’ each of that hemp rope fixed it.
And... should the apocalypse occur I’ll have something to smoke.Aaron
Mike Reeter wrote: »Took the rig apart today to perform an annual room cleaning. Time to clean wire connections and whatnot also
looks like you've got some snakes mixed in there
Yeah, it's that animal mimicry thing.
We lose dozens of audiophiles a year to the wily wiresnakes.
@audioluvr and @jaycee have you received the brimar cv4003's in yet?
if so what are your thoughts on the sound?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I have a pair if you'd like to try them Marvin. 12at7 triple mica black plates. -
the cv4003 is a 12au7.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Haven't had a chance to put them in.Gustard X26 Pro DAC
Same here. Delivered last week but haven't found time. Maybe, this weekend.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Pulled out the Belles pre to dust and the stupid shelf came out with it and the front dropped 3" when the shelf came off the pins. While I had it out I thought I'd set it on top, pull the cover and do some tube rolling. Fired it up to get a reference from my favorite tubes (the Raytheon long black plate halo getters marked "Baldwin") and nothing. No sound. Swapped out the tubes with the RCA clear tops I picked up from @Gerres26 and all's well again! Clearly those tubes weren't Mil-Spec rated... Good thing I have a stash!
The RCA's are very nice. Accurate, smooth and revealing with just a little less bass than my favorites.
Next I put in a fresh set of the "Baldwin" tubes. Immediately I'm immersed with what I can best describe as "hall effect" where the sound of music wraps around you. One of the benefits of small venue concerts is that "hall effect". I miss live music
After some reference tracks on those tubes I went ahead and rolled in the Brimar CV4003's I got from Upscale Audio. The only thing I can say they lack in is the "Hall Effect" (it's there but just not on the same league as the Raytheons) They are the most balanced of all the tubes I have tried so far from 20Hz to 20K! Whether playing low volume or cranking it up you don't feel like something's missing. They are also the most accurate tubes, edging out the RCA's for their crystal clear reproduction! The only bad thing about that is they make mediocre recordings more mediocre...
Currently rocking April Wine's "Harder / Faster"
Post edited by audioluvr onGustard X26 Pro DAC
