1…105106108110111…208
    mhardy6647 Posts: 35,550
    BlueFox wrote: »
    Solid state amplifiers (or receivers) draw very little current (more to the point, they consume very little power) at idle.
    Unless it is Class A.
    That is absolutely true: Class A (power) amplifiers are running essentially "flat out" at all times, whether tubed or solid state.
    audioluvr Posts: 6,065
    edited January 2021
    Doing some serious A/B'ing between my B&K M200's and my Belles 350a Reference... Again.
    Update. Rolland at Hi-Tech Audio told me to use a 2 prong adapter on my power cable for my Belles. Much better!
  • CH46E
    CH46E Posts: 3,595
    audioluvr wrote: »
    Oh those B&K must sound terrible against the Belles. You should probably just sell the M200s to me. :D
  • JayDog
    JayDog Posts: 266
    just listened to it for hours today, no work done!
  • gp4jesus
    gp4jesus Posts: 2,019
    On & off over the past 2 weeks messed w/an RTA and its mic at preferred seating monitoring just my LR RTi A7 towers
    This first image is the un-tweaked in-room FR. Pink noise from a phone app, LP’d ~3K. I turned off subs & verified DSP was disabled....
    ...and the after. LP’d @ 10Khz, after DSP W/subs.
    During several sessions of fiddling & tweaking I learned and/or discovered a few things:
    a. the spec’d FR is only the roughest suggestion of in-room FR.
    b. In-room will surprise you
    b. by the first “graph” you see a substantial hump @ 35hz. Polk specs the F3 at 35hz.
    c. the tweeters* were “flipped”. I noticed a notch right at XO frequency between them* and the mids. I flipped first one channel, then the other seeing the notch disappear.
    Following some tips from a friend:
    a.I smoothed out the FR low end by “carving” the peaks - no boosted frequencies.
    b. I performed BSC w/a 3dB sloped shelving cut @ 576hz followed by turning up the mid a few dB
    I’m delighted the final in-room system F3 is below 25hz
    During the last session I did some prelim on my CSi A6 center. I determined the tweeter has issues - blown I think. Next chance I’m gonna look at the RTi A3 surrounds and their subs.
    Cheers
    *all connected w/Premiere ICs
    Ha! I seriously can't decide which one I'd part with. Since I don't have a gun to my head I'll probably just put one of them back in the spare bedroom eventually.
  • motorstereo
    motorstereo Posts: 2,422
    Today I swapped my Yaqin mc100b tube integrated for the Mc mono's just to change things up a bit for a few days. It should be quite a change going from 1200+wpc down to 45wpc in triode mode.
    My guess is the 1.2tl's aren't going to be as happy now with the big reduction in current
    pitdogg2 Posts: 27,877
    Gosh I'd love to hear both to be honest.
  • motorstereo
    You're more than welcome to stop by if you're ever in the area.
  • phipiper10
    Skipped the preamp and plugged the Lumin directly in to the amp. Yes please, more of this!
    This isn’t great for the TT since both can’t be plugged in at the same time. Meaning I would be connecting and disconnecting ICs to change source and believe I would need a phono pre like Gram Slee Ascension.
    That said I’m going to have an in home Demo of the RP-7 this weekend.
    I really don’t know which way this is going to go. My Logic says less is more and having a preamp can only get in the way but who knows, it could add that something special.
    I’m not a betting man but any thoughts on how it ends?
    Karma after a decision is made! Wish me luck!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • michaeljhsda2
    Try the Yaqin in ultralinear mode as well...looking forward to your impressions.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • spongebobsquarepants
    @phipiper10 bet it’ll end with static when using the remote :D@daboyz
  • afterburnt
    afterburnt Posts: 7,892
    I have been ignoring mine. But I got a bunch of iFi noise doohickeys to test when I have the presence of mind to check out.
  • phipiper10
    We
    Well I took My 99 Magnum out of the chain so if my phone, as the current remote adds static, I will blame @daboyz !
  • GlennDog
    GlennDog Posts: 3,158
    phipiper10 wrote: »
    I’m looking forward to your thoughts....
    I’m not unhappy in the slightest with my Cary 05 preamp. However, I’ve often wondered what the RP-7 (or 9) would bring to the table when paired with my Rogue M-180 monos.
    btw, I just upgraded to the Dark mod
    Which LUMIN do you have?
    TIA
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • phipiper10
    phipiper10 Posts: 961
    edited February 2021
    GlennDog wrote: »
    phipiper10 wrote: »
    TIA
    I have the lumin T2. Also picked up Primaluna Evo 400 preamp, just before getting the RP-7 (no RP-9 at my dealer) this afternoon.
    Primaluna is up first and just casual listening right now. I'll do a little write up when done.
    Never heard them but Those Apollo Darks were on my wish list. Think I'd be afraid of those, they are beasts!
  • gp4jesus
    Yesterday, performed a more comprehensive cleaning of equipment and stand than usual. And...
    ...tweaked the surrounds and their subs - much more challenging than the LRs and their subs. I regret no RTA image to post. The tweaked FR is smoother than before but it needs more than I had time allowed.
    “The Dark Knight Rises” sounding MANY times better than in the theatre @ PCB years ago. In PCB theater, ANY gun fire hurt my ears so much I had to anticipate to put my fingers in my ears. My system - NO PROBLEM!
    Put my B&K monos in the closet. The upgrade I performed on the Belles 350a Reference is taking a lot longer to break in than expected but I'm really liking what I hear. The things I liked more about the B&K's are becoming less of a difference now. The Belles takes up less space too.
    nooshinjohn Posts: 26,137
    audioluvr wrote: »
    Nice of you to give Tom Cruise a set of amps to build around...
  • marvda1
    marvda1 Posts: 4,972
    I had a pair of Mullard cv4003's that I thought were noisy since last I played them was a few years back when I had a Belles 21a preamp. Well something told me to try them in my Mastersound Compact 845 integrated amp. They were dead quiet and the best sound I have heard from the Mastersound, not to mention that it saved me $300 as that is what they are going for a pair now. :D
    Puritan PSM156
  • Gerres26
    Gerres26 Posts: 874
    I’ve been running this guy in my rig the last few days. AVA FET Valve 600R Hybrid. Sounds just plain excellent to my ears.
    I’m wondering what some NOS Mullards or similar in the input stage might do for the sound.
  • maxward
    maxward Posts: 1,742
    Almost pulled the trigger on that one several years ago. Glad you are liking it!
    What tubes?
  • Gerres26
    Gerres26 Posts: 874
    Its almost brand spankin new and still has the stock JJ 12at7 tubes in it. Just when I thought I would stay away from tubes , they drag me right back in. It sounds great as is but it’s been my experience with tube rolling there is a chance to be even better...guess it’s time to look for a deal on some nice sounding NOS replacements.
    That is a serious toroid...
  • Mike Reeter
    Mike Reeter Posts: 4,315
    marvda1 wrote: »
    I have this tube in my DAC, it provides the 'Secret Sauce'. In the right application, it's one of the best.
    gudnoyez Posts: 8,213
    Warming up the HT for the big game, so nothing major just getting ready.
    gudnoyez wrote: »
    What game would that be?
  • dromunds
    dromunds Posts: 10,173
    “Game” is right, I ain’t watching nothing
    Being a Vikings fan it wont be a Packer Game, Aaron will be sitting at home watching it pretty sure he wont be boycotting it it's a game that he and Brady have one thing in common, that is they have each one a NFC championship game.
    It was a **** season with all the teams not having all their starters and players opting out because of the pandemic that along with all the other BS that went on I agree with you guys I did not watch many games until the playoffs, as it didnt seem like a real season to me. But it's the Superbowl dangit it's like -20 with the wind chill I'm staying in and watching a inferior product and eating a ton of chicken wings and guacamole and chips tossing back a few cold ones and watch Mahomes win a second ring even if it is an astrix season. Dro just giving you a hard time about Rodgers joking aside.
