1104105107109110185
    nooshinjohn Posts: 25,101
    I bet that is sublime!
    It is more than that. It is entirely another level, and endgame for sure. It has to be experienced to be believed.
  • doctor r
    doctor r Posts: 837
    edited January 2021
    Spent 4 hours playing with:
    My Christmas present from the wife 👍🏻
    The improvement using Analogmagik on the setup my OL Enterpise Mk4 arm with the Madake has been a little eye opening (really ear opening...). I have always put a lot of effort into my cartridge setups but his placed the sound into a different world.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • tratliff
    tratliff Posts: 1,663
    doctor r wrote: »
    That is a great present. Would like to give it a try but its pricey. Sounds like a good investment though.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
    pitdogg2 Posts: 24,583
    tratliff wrote: »
    doctor r wrote: »
    Group buy
  • tratliff
    tratliff wrote: »
    doctor r wrote: »
    Group buy
    Count me in.
  • Gardenstater
    Gardenstater Posts: 4,189
    edited January 2021
    Finally got around to installing the Blackhole5 that @Moose68Bash so kindly karma'd to me a while back.....err uhh quite a while back :D It was a piece that is 7-1/4" x 9-1/4", so not quite big enough for 2 pieces 6" x 6", so I pieced it into 2 pieces that are 5-7/8" x 5-7/8" with a 1-1/4" square missing from one corner (yeah I'll fix that in the future....maybe). Anyway, this was a bigger transformation than I expected! The first song in the queue happened to be David Gilmour Live at Pompeii, Comfortably Numb and the difference was astoundingly obvious from the git go. The vocals were super clean and breathy.....yeah I'd rather use that in reference to a female vocalist but that was my first reaction. Further songs cemented that in that vocals have taken on a new crystal clarity and the bass is tighter as well. The feeling that there is a live band in my room is now inescapable. I guess attenuating that back wave from the midwoofer is super important. Anyway I'm lovin it.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gp4jesus
    gp4jesus Posts: 1,969
    A piece ~7” X 7” in each closure made what sounds like a BIG diff?
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • Gardenstater
    It was a little less than 6" x 6". The more I think about it, it is probably having that little square missing in the upper outer corner that is where the magic comes in. :D
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    gp4jesus wrote: »
    You just need it directly behind the woofers.
    This stuff is incredible at cleaning/tightening up resonances. In the 2.3tls you just use a piece that's just big enough to go behind the woofers. If you get too much it will suck the life right out of your speakers.
    @Toolfan66 IIRC did most of his enclosure on his 1.2tls and promptly removed most quickly.
    edited January 2021
    Umm I added a new CD player. The guy I bought it from said it was good.
    edited January 2021
    Man, that looks familiar :p
  • CH46E
    CH46E Posts: 3,554
    I don't think ive ever heard Krell equipment before. But I am for some reason drawn to it. I want a Krell amp so bad!
  • motorstereo
    motorstereo Posts: 2,052
    gp4jesus wrote: »
    I finally got around to ordering a sheet of bh5 last week and plan on doing my 1.2tls after reading all the positive reviews for years. I'm thinking 2 strips 27'' long by 3'' wide behind each array should be good. I've read that the adhesive is very good but I wonder if anyone has used extra adhesive to insure they do not loosen up?
    Clipdat Posts: 12,608
    Congrats on your new disc spinner, Ivan!
  • Gardenstater
    edited January 2021
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited January 2021
    gp4jesus wrote: »
    I was wondering that myself but I took the precaution of cleaning the surface of my particle board with some Everclear 190 on a paper towel. I'm sure Isopropyl or Denatured would work fine but you can't use it for a Bloody Mary :). Anyway, some brown stuff came off and it was much smoother and cleaner feeling. You don't want to get the wood wet, just a lil on the surface which will quickly flash off. Then I tested the adhesive with a finger and felt it was plenty sticky enough. Time will tell.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,279
    http://www.lampizator.eu/lampizator/references/krell cd300/Krell CD300.html
    This is what lukasz fikus the owner of lampizator had to say about the krell kav cd300.
  • Navy_Goat
    Navy_Goat Posts: 375
    gp4jesus wrote: »
    I just went through this process with my 2.3tl. I pretty much covered the back wall and it totally killed bass and mid-bass. Took the life right out of the speakers. I removed all by a 4x4 square behind each drive and the came right back to life.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • gp4jesus
    edited January 2021
    gp4jesus wrote: »
    So this BH stuff is to dampen resonances like say Dynomat, Secondskin, or Armacell*?
    *CHEAP version of Dyno or SS
    Or does it absorb certain frequencies?
    Help me out. Thanks
    gp4jesus wrote: »
    No need for that. The glue they use is like that mouse trap glue. If you've ever got into any of that you'll understand.
    How about some thoughts on that new Krell you are playing with...
  • motorstereo
    I now have a 3X27" strip of bh5 behind each of my 1.2tl's arrays. I haven't had the drivers out since 2012 so it was a struggle pulling the first driver out of each cabinet. As was mentioned the glue is very strong and I saw no need for any additional glue. Now I need to spend some time with them for some listening impressions.
    edited January 2021
    If I can stop the ear orgasms long enough....
    My Pioneer PD-09 was/is no slouch but this Krell is a magnitude force factor of 10.
    Much cleaner bass, better midrange and the sparkle in the upper registers are crisp clean and concise without any fatigue.
    You said it, IT was no lie!!
    END GAME!!!
    I mean really it sucks😳🤣
  • GlennDog
    GlennDog Posts: 3,087
    END GAME!!!
    I was wondering whose tranny was missing some gears! Congrats Ivan!
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    END GAME!!!
    Thanks Glenn.
    John and I had fun with all that.
    Great seller and a wonderful Polkie.
    I had ran into some initial problems with it playing some SACD's. While he does have the manual he was not able to include it's due to its location at the time of packing. He was very helpful in getting the player to play the SACD's I was having trouble with.
    It has played everything I have put in it today.
    Glad this stayed in the family Ivan. It is also good to know my description of you was right on the money! :p;):pB)
  • jdjohn
    jdjohn Posts: 3,004
    jdjohn wrote: »
    Oh, so GF is now the backup? I really like the AT house sound. I guess my top ones are OC9/I & III, and AT33PTG. Also an AT33 Mono. Lots of vintage AT MM carts as well. Nice, flat FR IMO.
    I have realized I was off in my comment here, thinking @nooshinjohn had purchased (a lowly) Audio Technica cart. In my defense, the logo on the box confused me between the two manufacturers. Perhaps you can understand my confusion looking at the company logos side-by-side:
    For the record, though, I do like the AT house sound...especially for the money.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    jdjohn wrote: »
    jdjohn wrote: »
    I recently picked up an AT-OC9XSL, about 40 hours in and it's starting to shine. I like the Threaded Body on the new style AT offerings as well.
  • Moose68Bash
    Moose68Bash Posts: 3,842
    @Gardenstater,
    I'm glad the BH5 worked out well for you1
    Happy New Year!
  • Gardenstater
    I'm gonna need another piece from you so I can put some in the back of the enclosure behind my driver in my Martin Logan Dynamo Sub. Ha ha just kidding!
    Thanks again and Happy New Year!
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
