1…959698100101…207
  • GlennDog
    GlennDog Posts: 3,158
    First, to Mark.
    Hope that didn’t come off as snooty. Wasn’t meant to
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • CH46E
    CH46E Posts: 3,595
    edited August 2020
    joecoulson wrote: »
    That’s a sweet center mass.
    I always aim center mass! B)
    May not aways hit it though! :(
  • GlennDog
    That looks sweet!
    What complement of tubes does said product take?
    The lower level units are pretty straightforward
    but as you climb up the food chain, it becomes a cornucopia of tube possibilities.
    I’m not familiar with the Mullard 4003 variant, but it’s equivalent to the 12AU7
    Gotta get my Lamp authorized toob learn-On
    Image on rear apron denoting some specs (top LH side, circled in yellow) ...
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    mhardy6647 Posts: 35,562
    GlennDog wrote: »
    First, to Mark.
    not at all (if you're talkin' to me) -- I was just bein' a goober.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited August 2020
    GlennDog wrote: »
    That looks sweet!
    My Amber 3 came with a 5962 tube in the Output Stage, it's also another variant of the 12AU7/ECC82 family.
    The Mullard CV4003 is a drop in replacement for the 12AU7/ECC82 also. It was made for the Military, rugged construction and a very long life.
    Can be a little dark in some applications, but it is a good fit for the Amber, as its presentation is a tad bit forward, in my set up that is.
  • Gardenstater
    Gardenstater Posts: 4,982
    edited August 2020
    Got the Cardas Litz 15.5 ga tweeter wires installed in my 7B's. Did the right speaker on Sun and the left one on Mon. The difference was astounding! I mean in less than a second immediately discernible that the cymbals had extra detail, more shimmer, less smearing and it was an unbelievable wow moment that those 24" wires could make that much a difference. I guess I shouldn't be surprised but I still am. And there are knuckleheads refuting this by making measurements with electronics instead of just listening?
    It was interesting that when I had only done the right speaker, I was almost thinking....hmm.....are my speakers too bright now? But paradoxically that feeling was entirely gone when both speakers were done yesterday. I stayed up way past my beddyby time listening and I'm sure the neighbors could hear through the walls lol.
    I'm not sure if it shows in the picture but the large inductor had worried? a hole in it's solder joint probably from being stressed during modifications so I reflowed the solder joint so that's something to watch out for. Maybe other people just desolder it which may have been the wisest move. Anyway, bass sounded vastly superior after that and I thought it couldn't get any better. I don't think I will wait too long to do the fuseholder and binding post wires and Cardas Binding Posts :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    I just did a temporary swap of the ELAC Debut 2.0 B6.2* with a (relatively) nearby hifi colleague for a pair of GR Research Paradox 1 two ways. Just hooked up the latter. Listening to NPR (mono program material) so I can't say much about 'em yet except that they work :)
    They look -- purposeful (and I do mean that as a compliment).
    http://gr-research.com/paradox1.aspx
    VR3 Posts: 29,756
    The TC90 is a great tweeter and I agree with GR Research assessment of the replacement!
    so -- a fellow I know wanted to try the ELAC Debut 2.0 B6.2 loudspeakers. No problemo; I gots a pair of those. We arranged to meet someplace mutually (in)convenient ;) for me to pass them to him for a couple of weeks. He felt compelled, I guess, to a little quid pro quo, so he brought me a set of his speakers to play with in the interim.
    Listenin' to 'em now :)
    Y'all may -- or may not -- recognize 'em.
    They have been slightly modified from their standard implementation (they're kits, or quasi-kits, at least).
  • gp4jesus
    gp4jesus Posts: 2,025
    What’s the little toggle switch do? Adjust tweeter output?
    *all connected w/Premiere ICs
  • Gardenstater
    rooftop59 wrote: »
    I was hearing a very slight bass bump, using around the A-D on the bass (appr. 55-75 hz). I have my ML Grotto crossed over very low, either 42.5 or 40 (can't see without pulling it out of the cabinet) so I just reached around and turned it down one click (2.5 hz). MUCH better. That allowed me to raise the volume ever so slightly getting a slightly fuller foundation while getting better integration at the same time.
    How does that Grotto compare soundwise to the Dynamo original? Go ahead and tell me I can take it lol. I see it's a servo-controlled sub! Interestingly, and I may have mentioned it, but the back of the Dynamo manual has a reference to it being a servo controlled sub! That's a mystery to me because it is not! I wonder if the early ones were and they didn't make that correction in the very back of the manual.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    gp4jesus wrote: »
    check.
    actually, it changes the HF contour -- according to their owner, who added it after consulting with the designer. :|
  • gp4jesus
    From who did you buy? Pre-termed & cut?
    I’d love these for my next round of mods. I would have used these instead of the bulkier 14 ga from BJ. Would like ~30’ to connect my tower’s tweeters
    Thnx, G. Tony
  • rooftop59
    rooftop59 Posts: 8,120
    rooftop59 wrote: »
    Honestly I cannot really say. Not only have I never directly compared them, but I never used the Dynamo in this setup. Plus, I have changed basically everything except my speakers in the last year, so its hard to isolate individual components. I can say that I am VERY happy with the grotto. Even in a less that ideal setup (stuffed in a cabinet) it fills my living area (open to the kitchen and much of the house) with quick, tight, and textured bass. But again, most of that is coming from the Contours, as the sub is crossed over very low.
    Game Room 5.1.4:
    Bedroom 2.1
  • Gardenstater
    edited August 2020
    Tony I got the 15.5 ga Cardas in Red and Black from Sonicraft for $1.95/ft and I got the WBT-0657 2.8mm Fastons (they call it a Flat Push-On Cable Shoe lol) from Parts Connexion for $2.50 each. The Wonder Signature solder was from michaelpercy. A crimper that was actually a crimper used for crimping braided steel fishing leader sleeves was extremely helpful as well (borrowed from a friend). Actually very helpful for twisting the litz wires extra tightly after denuding them, and also for getting a very good crimp on the fastons, prior to soldering.
    I mistakenly said above in my construction post that the fastons were Furez. They were WBT. I feel these were way overpriced and I was mistakenly assuming that they must be (because of the price) of a superior conducting material. I don't think they are anything but gold plated brass but I don't actually know because I haven't asked the manufacturer. I do know that I can scratch a copper penny with the cut end.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • gp4jesus
    WBT ?
  • DaveHo
    DaveHo Posts: 3,584
  • Gardenstater
    Correct, although they do not show the fastons on their website. It's a high priced German company. https://www.partsconnexion.com/wbt-faston-connectors.html
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Tony M Posts: 12,026
    Hooked up my Carver TFM35-thx to some things. Enjoyed it so much I stayed out there till 3:15 AM. :p Had a blast.
    Played around putting pieces in and on top of those 3 racks. Nothing's hooked up yet...
  • gp4jesus
    edited August 2020
    “...the 15.5 ga Cardas in Red and Black from Sonicraft...”
    How do I “get there?” “Sonicraft” takes me to a recording site. And what am I looking for on their site? I want ~30’ of this stuff, maybe less if available in speaker wire config. Connectors can wait. I hope they take PP
    I use Cardas solder. How does that stack up?
    “...twisting the litz wires extra tightly after denuding them...”
    “denuding?”
    Thanks G, Tony
  • Gardenstater
    edited August 2020
    My Bad.....Sonic Craft. Two c's in their website apparently
    http://www.soniccraft.com/product_info.php/cardas-awg-155-black-p-1610
    http://www.soniccraft.com/product_info.php/cardas-awg-155-red-p-2040
    I honestly don't know but Cardas Eutectic or WBT may be as good or better.
    https://forum.audiogon.com/discussions/solder-eutechnic-wonder-wbt
    Denuding.......to divest of covering, make bare ;)
    https://www.thefreedictionary.com/denuding
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • spongebobsquarepants
    JB welded more mw drivers.
    I made a squeezy bag with my food saver, and it made the application so much easier!
    Still made a little bit of a mess trying to push it in the gap with pieces of index card.
    I even did my spare NOS 1998 mw6510. Interesting it has different (single) terminals than the originals (double).
  • Gardenstater
    Well that certainly isn't going anywhere! How long did the JB Weld stay workable in your squeeze tube you made?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    It was still workable after about an hour when I threw it out cause I ran out of drivers to glue.
    Viking64 Posts: 7,826
    Did you pick up any of that Hormel Black Label® bacon @ $4.99? It may seem like a deal, but if you look closely, it is only 12 ounces instead of a pound.
    Still, it's not as high as Peter Luger's Steakhouse® bacon. That's like $53 for 12 ounces plus about $10 for shipping! :o
  • BobandTorey52
    I’ve gotten the new L800 from Polk I really like them
  • joecoulson
    joecoulson Posts: 4,983
    Congrats
  • dromunds
    dromunds Posts: 10,175
    Got any pics?
  • displayname
    displayname Posts: 1,248
    Just got some Herbie's slider feet. Thinking I maybe should have sprung for the big ones for actual sliding, but these will help protect our new carpet.
    Discogs
