Candy store for OPPO owners?
nooshinjohn wrote: »Come on man. Now is not the time to slack off. Hurry up and plug that bad boy in.
John
Click on the link that I sent you in your SACD thread and get to buying!
Meantime PATIENCE GRASSHOPPER
(happy now mikey???
Looking good!My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Amazing base
How sweet will be the sound?? -
She slides right into place perfectly.
However the toroids are touching. I wonder if I’ll be able to get that cover back on?
They say in the video you can leave it off if you want once the new supply is installed.
Of course the video is now three years old and they weren't using a toroidal transformer then that hangs over the edge of the board. -
Okay screwed in and the connectors are all back in place. Time to put it all back together.
@nooshinjohn trust and believe this was all a LOT easier than it will be reinstalling this in the system with all dem cables -
Oh this is fargon highlarious
I quite literally cannot put the cover all of the way back in place because of the size of the new toroid!!🤣😂 -
Just want to thank the op @Mikey081057 for starting this thread. I never would have known about oppomod or accidentally found out about clones audio had you not started this thread.
You have to remember which screws go where. Two of the screws for that center barrier are different. One is black and goes on the back of the unit to hold it in place. Another has a washer and goes into the top at the front. The other two go into the bottom. I kinda lost track because I had all of the screws in order in the cups, but because I cannot put the black power supply cover back in place I needed to remember which cup had what screws in it and take that cup that had the power supply cover screws out of the way -
Best to use a magnetic screwdriver so you don’t drop any of them inside the unit. Don’t forget the two plastic standoffs that have the rubber caps that go into their tops to hold the top cover up. That blue ribbon cable is easy to get out, but a major pita to get back in, because it isn’t attached to a plastic clip. It stands by itself once you remove it and is really easy to bend trying to reinstall. -
Side note
Upon closer inspection I see the caps on that board are all made by Elna -
The ones on this board are mostly Elna and a couple of Acons
This is for your electronics wiz geeks who know more about this kind of thing than I do.
The Acons👆🏾
Big Elnas👆🏾
Might want to tidy up a bit while you are in there. That dust is robbing you of audio quality.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
And your Krell?...need update2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Easy part is done.
Now to try putting all FOURTEEN cables back in the right places.🤦🏽♂️ -
John this is all yo fawlt!!
I gotta do this AGAIN when the BD-ROM stabilizer comes back. -
txcoastal1 wrote: »nooshinjohn wrote: »Come on man. Now is not the time to slack off. Hurry up and plug that bad boy in.
Stop trying to derail his thread man. WTH is wrong with you?
honestaquarian wrote: »John this is all yo fawlt!!
I do what I can...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »honestaquarian wrote: »John this is all yo fawlt!!
I do what I can...
Ju fargon aisehole!
At least it’s not that blue spray paint mod
John I would LOVE to get a side by side from you if you decide to go this route and upgrade your 205. I wanna know what it sounds like compared to yo big ****$ Krell.
Okay time to put this thing back in.
FUN TIMES!!
I took some pics of the screen with my Avatar Blu-ray box set playing before the upgrade earlier today and I will do back to back comparisons.
Sorry none of this is gonna be 4K as I do not yet a 4K display. Still waiting for all of the stuff promised for this year at CES to come to fruition (AND I gotta save up the money/get my credick skraight) -
Okay to say reinstalling alla dem cables was a pita was an UNDERSTATEMENT
It is done and time to turn it on and check the channels to make sure it is done right/left -
Keep a fire extinguisher handy...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »Keep a fire extinguisher handy...
John ima gowna fargon cut off Ju head an shove it in ju aisehole ju fargon bastage!!😝😝 -
Before upgrade👆🏾
After upgrade👆🏼 -
The first thing I always notice if there is a change is in the bass. It is tighter and deeper and more apparent so far.
Before upgrade👆🏼
After upgrade 👆🏾 -
I can’t see a difference.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Before👆🏾
After👆🏼 -
Some of this may be difficult if not impossible to see here because of whatever processing the iPhone 7 camera is doing to the 1080p picture on the screen.
The bottom one looks worse.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
