15960626465183
  • I swapped out the 5ar4 rectifier tube to a 5U4GB,and a OD3 regulator to a OC3,in my Aric Audio Unlimited pre amp on the recommendation of an agon poster,and Aric. If you have one of these pre's,I highly recommended this swap. Pure magic.
    mhardy6647 Posts: 32,927
    edited December 2019
    So, a 5U4 will have a slightly higher peak inverse voltage rating, but a higher voltage drop, and lower capacity to deliver power (i.e., lower plate current rating) compared to a 5AR4 -- I take it that the Aric Audio Unlimited (whatever that is) doesn't need the extra performance capabilities of a 5AR4? ...'cause if it does, it might not be very happy with a 5U4 in there(?)
    https://300guitars.com/articles/rectifier-tube-voltage-drop-chart/
    http://www.fourwater.com/files/fullrect.txt
  • @scottfox Absolutely! The quality of DAC makes a huge difference and I'm assuming you went from the computer's soundcard's DAC to an external USB one, which is the biggest jump you will observe. Believe it or not, higher end external USB DAC's will result in further improvements in noise reduction, jitter reduction, musicality of presentation, etc.. I have a modest DAC compared to most people here (gotta start somewhere) with an iFi nano idsd DAC. I got a huge improvement by adding an iPurifier3 and, to a lesser extent, an iDefender with a low noise external iPower power supply. The iPurifier3 does what some much higher quality DAC's and higher end regenerators do in that it regenerates and reclocks the USB signal resulting in a much cleaner, smoother, and musical sound.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • TEAforONE
    TEAforONE Posts: 999
    That's why Aric had me replace the OD3,with an OC3,due to the voltage dip. Aric Audio is a small shop in MA. Reasonable price,high quality stuff. At least in my opinion.
    The "Unlimited " is one of his preamps. If I could figure it out,I would post a link. It would make things so much easier.
    Don't know it/him.
    http://aricaudio.com/tube_gear.php
    For a preamp, which should have modest P/S demands, it probably doesn't matter what's in there... but the 5AR4 was a super-duper HV fullwave rectifier, developed for high-power, high-performance hifi (and fairly late in the vacuum tube era, too). Plus, good ones are 'spensive (and most of the current production 5AR4s are more or less junky). 5U4s are a dime a dozen (in fact, I can send you a couple if you want to play with -- and you're in the US :) Just PM me).
    "We" sometimes substitute rectifiers with more voltage drop as a quick & dirty workaround to the typically higher AC mains voltage of today vs. the 1950s (it takes some of the strain off of vintage hifi components, which might otherwise push, e.g., output tubes too hard). Gee-tar amp buffs tend to like some sag in their amp
    P/S, but they're into creative uses of distortion (and compression), which we generally like to avoid in hifi.
    Still, lots of designers/builders out there with all kinds of ideas!
    Pretty 'stiff' P/S design for what looks to be a pretty simple preamp -- I would guess the 5U4 loosens things up a bit and may well sound better.
    EDIT: The photos on the site show a Sovtek 5AR4. Did you have a good one (vintage Mullard) in yours, or a current production 5AR4? If the latter, that may be why the 5U4 sounds better, too. :|
    It is cool it has a built-in phono preamp for that low price.
  • joecoulson
    joecoulson Posts: 4,943
    Ivan??? Do tell
    pitdogg2 Posts: 24,481
    joecoulson wrote: »
    Ivan??? Do tell
    Snitches get stitches I'll never give it up ...
    What are we talking about ?
  • mhardy6647 wrote: »
    Don't know it/him.
    I only used the Sovtek that Aric provided,so no experience with anything else. The 5AR4 was replaced with a 5U4GB. As I understand it,there is also a 5U4 (no GB)? He said DO NOT USE A 5U4. That he said would cause problems. Now you must know,I have about zero technical knowledge. I figured if the guy that built this suggested the swap,explained how I could make it happen,and also talked about how the sound might be effected. I figured I'd give it a whirl,and I'm glad I did.
    The pre I have does not have a phono stage,as I already had one,and I run a mc cart. I found out about his gear on one of the other forums,and purchased one of his early pre's.(which I still own) I think his stuff sounds great,he's great to deal with,and I can actually afford some of his products!
    The 5U4GB is rated for 275 mA plate current, the GA was only rated for 250 mA, and the "G" ("G" stands for "Glass" -- there was no unsuffixed version per se and AFAIK), which was a 5Z4 with an octal base, was only rated for 225 mA.
    Apparently there was a metal 5U4 'variant', but its type designation was 5T4.
    That's
    why the designer/builder says to use the GB if you're not going to use a 5AR4.
  • Hey guys! @rocray , the 5U4GB (not 5U4 or 5U4G) can safely be used in the Unlimited as the first filter cap it requires can be no larger than 40uf, whereas the 5U4 is much lower (the Unlimited uses 33 uf). Using it will lower the B+ voltage just a bit, so just make sure the regulators light consistently. If you find they are going out, then use one OC3 and one OD3 when the 5U4GB is in place. I agree with Tube Power on his choice for a favorite 5U4GB. For 5AR4s I’ve only ever used new production- either the Sovtek, Tung Sol or Mullard reissues all sound really good! Best, Aric
    Here was part of our conversation on Agon. This is all way above my pay grade.
    Ahh, so he uses a big input filter. That's the deal.
    Thanks.
  • At some point I'll try a different/better? 5AR4,but the 5U4GB,OC3 combo sounds so good.
    treitz3 Posts: 18,230
    Started catching up on all of the new albums I have....one, right after the other.
  • treitz3 wrote: »
    What have you been playing?
  • Nightfall
    Nightfall Posts: 10,042
    afterburnt wrote: »
    Village Idiot of Club Polk
    TEAforONE wrote: »
    Mark Knopfler, 3 new albums from Chris Stapleton, Eva Cassidy and a couple of new ones from Vince Gill. Enjoyable day.
    Never knew Chris Stapleton until I heard him on the speakers at a bar while I was eating pizza. I heard something about "Tenesssee Whisky and Strawberry wine", so I looked it up on the phone while I was there 'cuz I really dug the song....or what I could hear of it. Daggum place was noisy!
    Went home and played all CS songs on Tidal and got to liking his style and voice. Liked him so much, I bought three of his albums right off the bat. Glad I did.
  • joecoulson
    CS is some good listening. Wish we had that in common when you were down.
    Tony M Posts: 11,009
    CS's "the Traveler" album won a ton of awards when it came out. B) I heard him sing and play during those award shows, liked it, and still want to get that CD for sure. I'm sure the others are just as nice. Talented fellow, he is! ;)
    Song-writer extraordinaire! ;)
  • Vince Gill is not shabby either. He is a great guitar player.
    Harry / Marietta GA
  • Mike Reeter
    Mike Reeter Posts: 4,314
    Vince Gill is an extremely talented musician. Getting his start way back with Pure Prairie League.
    At one time he was invited to join a little group called Dire Straits, but declined so he could continue his Solo Career, although he did set in on their final Studio Recording of 'On Every Street'.
    He is the second guitar on 'Fade to Black' and 'You and your Friend' amount others.
    I did not know that.
    well, that's remarkable -- I mean, given that they were a bunch of Brits, bad dentition and all... :)
    Mark Knopfler definitely has good taste -- he had Ruth Moody with him on at least one tour :) I loves me some Ruth Moody.
    He (Gill) is a heck of a guitarist and an entertaining performer overall.
  • Mike Reeter
    I guess seeing and hearing Gills reasons as to why he didn't join the group might tell the story.
    https://www.youtube.com/watch?v=sCloCqw-ZXw
    And yes, Ruth Moody has the voice of an Angel. 'Wherever I Go' is probably my favorite track on 'Tracker'
    Post edited by Mike Reeter on
  • dromunds
    dromunds Posts: 9,969
    Ruth Moody coming round in my neck of the woods on March 12 - definitely attending.
    Her singing can reduce me to tears; listen to her soar as she pines "Calling all angels" near the end of the Wailin Jennys version of Jane Siberry's Calling All Angels on Live at Mauch Chunk Opera House. I am getting chills just typing this.
    Ahem on topic -- the aforementioned Jennys' album sounds really good, too. Your hifi will thank you for playing it. :)
  • Unboxed a pair of RCA 6SN7GTB and Sylvania 6SN7GTB for the Rogue 99 pre.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • verb
    verb Posts: 10,176
    phipiper10 wrote: »
    Nice! Post some pics! :smile:
  • treitz3 wrote: »
    Thanks for sharing. I did not hear about Chris Stapleton either till I saw your post. And like you, I really liked his voice and music.
  • Spiked my fully modded SDA -1cs. Turntable , Tubes and fully modded SDA s lifes good.
  • verb
    verb Posts: 10,176
    rebelsoul wrote: »
    Sweet! Post some pics! :smile:
