Post a picture... any picture
13513523543563571153
  • aprazer402
    aprazer402 Posts: 3,399
    Question. I've seen many brands of tubes mentioned on CP. Never seen this brand. Was this a company that just re-branded other mfg. tubes and sold them under their company name?
    mhardy6647 Posts: 35,098
    aprazer402 wrote: »
    Because they're most likely rebrands. Sometimes, the rebrands were excellent tubes, usually not, though.
  • aprazer402
    Thanks, that was my first guess. Did a little browsing. Several similar companies existed in the past. Some obtained seconds, washed off the original brand and put on their own. Back in the day, In NJ, "obtained" may be a correct word choice. :)
    pitdogg2 Posts: 27,124
    edited November 2019
    aprazer402 wrote: »
    Not exactly some of the big tube companies made tube for others. You need to look at tube codes, it may say "realistic" or "Rogers" etc but the tube code number will absolutely tell you who manufactured the tube. 322= Tung-Sol 188= GE 337= Westinghouse etc.etc. then look at the internal structure of tube some are dead giveaways. type of getter and other things.
    Rad-Tel never made tubes
  • aprazer402
    aprazer402 wrote: »
    I agree Rad-Tel never made tubes of their own. I had just read that some tube companies like Rad-Tel, back in the 40-50's bought tubes, either seconds or not, and some removed (washed off) the orig. mfg. name and re-branded them themselves. Rather than GE, RCA, Westinghouse... selling their own tubes, rebranded i.e.: labeled Realistic to Radio Shack...
    yes, all sorts of skulduggery in the electronics 'aftermarket', then as now.
    The funny thing is, the off-brands can work both ways. One of the local gurus told of picking up some NOS, NIB "International Servicemaster" branded 2A3s for chump change... in the box? Rebranded RCAs.
    (random, borrowed image for illustrative purposes only)
    As to the EIA manufacturer numbers (which should indeed be on proper "OEM" Amurrican tubes, but will be lost on "washed"* tubes), an EIA code list is invaluable (which is not a synonym for worthless B) ) when playin' the vintage hifi game.
    Here's the best one that I know of. In case any of you weren't aware of this/these.
    http://www.audiophool.com/Misc/EIAcodes1961.pdf
    Here's a nice little primer in the realm of speaker (driver) codes, too, while I am at it.
    https://www.tedweber.com/speaker-codes-application/
    sorry for the digression :p
    ____________
    * Some tube manufacturers used 'delicate' print on their tubes so that unscrupulous repairpersonages couldn't just take an old, pulled tube ('plinker') and clean it up with water or Windex, then sell it as new to an unsuspecting customer. Those of us who rehab decades-old, grungy vacuum tube hardware have learned to clean such tubes very gently indeed.
    "Legitimate" rebranded tubes were often labeled with the brand name of the component in which they were installed (e.g., Airline, Silvertone, Magnavox, harman/kardon, Fisher, etc.). Some companies played on both sides of the fence (Zenith, Sylvania, and, of course, RCA and GE, e.g.).
    It was also not particularly uncommon to see rebranded tubes branded with the names of 'big' tube manufacturers -- especially late in the tube era. For example, I have "RCA" branded 6922s that are clearly labeled "Made in Holland" -- and not made by RCA in Holland ;)
    Here's a 'rebrand' --- these gorgeous (yes, I am biased) "Westinghouse" 5692s are RCAs.
    13337579533_65c3688dea_h.jpgWesties closeup by Mark Hardy, on Flickr
    (borrowed image, of course!)
    49069830256_0e9bb20977_b.jpgSabreliner Move by Baltimore Washington International Thurgood Marshall Airport, on Flickr
    I enjoyed these photos, from BWI (Baltimore-Washington/Thurgood Marshall International Airport) on Flikr... they moved an old Sabreliner jet from the airport (or nearby, maybe from Northrop-Grumman, the old Westinghouse) to the nearby Electronics Museum (a place I wouldn't mind seeing someday)...
    here's the 'album' from which the photo above was borrowed:
    https://flic.kr/s/aHsmJoDEhA
  • tonyp063
    tonyp063 Posts: 1,135
    These are another nice rebrand.
    (borrowed image also)
  • Nightfall
    Nightfall Posts: 10,083
    Old and new NSX. Drool.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    afterburnt wrote: »
    Clipdat Posts: 13,098
    Clipdat wrote: »
    Wow. This thing works.
    Amazing.
    Mullard made some for servicemaster as well
    Clipdat wrote: »
    Amazing.
    Here's my three word review of the Audioquest Niagara 1200:
    Worth every penny.
  • joecoulson
    joecoulson Posts: 4,943
    Yep^
    All you naysayers out there, AQ power is legit ****
  • verb
    verb Posts: 10,176
    Walter got a new outfit today! :smile:
  • mrbiron
    mrbiron Posts: 5,721
    I finished! Kind of...
    Built the upper, lower, and installed traditional shiplap. Painted the walls today. Just need hooks. Then I start framing for my 1,200sqft basement. Yay!
    mrbiron wrote: »
    Nice! The "Frogtape" really makes it pop.
    No, in all seriousness -- looks fantastic! Deserving of a better class of mud than are most folks' mudrooms.
    I am envious.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Clipdat wrote: »
    Amazing.
    I'm curious how the EMI meter reads the before and after with your new toy! :smile:
  • Willow
    Willow Posts: 11,237
    My son's African mantis having lunch .
  • joecoulson
    mrbiron wrote: »
    Great job - close to the kind of stuff we do
    verb wrote: »
    Well, measurements aren't everything apparently.
    Viking64 Posts: 7,577
    Clipdat wrote: »
    verb wrote: »
    Tell that to my ex-wife. :'(
    EDIT:
    1) this is not a response to any of the previous posts (not even @Viking64's) :p
    2) the image might make a good badge*; @hermitism?
    ___________________
    * even if it would might be impractical to photoshop in @lightman1's... umm... puss... onto that puss's puss.
    (we'll see how Vanilla feels about the word p-u-ss. None too sanguine, I suspect.)
  • Dabutcher
    Dabutcher Posts: 2,606
    Dabutcher wrote: »
    Neat-o.
    Whoever made that should display it with a copy of the cover art from Pete Townshend & Ronnie Lane's album, Rough Mix -- the cover of which was a montage of cigarette cards from the England of days gone by. :)
  • OleBoot
    OleBoot Posts: 3,135
    Dabutcher wrote: »
    Neat-o.
    Don't remember cigarette cards in England - maybe were before I started the evil habit. I think a lot of the cards on the Rough Mix cover are "tea cards", which came in, errr, packets of tea. Trading cards came with other things as well like bubble gum and various sweets (candy).
    The other theme on this cover is that the "Rough Mix" title in the top left hand corner is in pretty much the same font as Rizla rolling papers, and the yellow area the same shape as the pack.
    All I can say (bein' a Yank and all) is that I remember a reference to the cover's being a collage of "cigarette cards" in a contemporary review (which I am still seeking in the annals of https://www.americanradiohistory.com/index.htm :p).
    I did find this -- but it's a modern reference and can't really be fact-checked for accuracy :p
    https://www.collectorsmusicreviews.com/clapton-eric/pete-townshend-and-ronnie-lane-unsurpassed-masters-rough-mixes-audiofon-af19/
    The covers are rather splendid – featuring the original, unadorned U.K. sleeve featuring various vintage cigarette cards of the kind that might be framed & displayed in a local hostelry. With Audiofon’s newly used casual font adorning the track listing on the back along with the familial picture of Pete & Ronnie sat back to back on a tree stump – this also appears in a larger size in the case back. Liner notes are amended & uncredited from the excellent Lostgrooves blog adding a small addendum at the end for the specific details of this disk. The only gripe would be the spelling of the ‘Stones drummers name – Who is ‘Charly Watts’?
    I also note a reference to cigarette cards in Tom Robinson's song 1967 (So Long Ago) as performed on The Secret Policeman's Ball (The Music) -- an album dating from about the same era as Rough Mix and also featuring a trio of absolutely superb, gossamer Pete Townshend acoustic performances.
    https://youtu.be/eplo-8F1el8
    https://en.wikipedia.org/wiki/Cigarette_card
    Oh, and... finally... Rough Mix is a magnificent album, in a way that one would never have expected from Big T (unless one were very familiar with his other early solo work and the influence of Meher Baba in his life, especially in those days). It sounds really good, too.
    Post edited by mhardy6647 on
  • OleBoot
    Don't break your fingers Googling - it is very likely to be my memory, And yes, Rough Mix is an excellent album - one of my favourites. I think it may be one of the few albums I have on vinyl, cassette and CD!
  • OleBoot
    So I did the Googling. Turns out that British cigarette cards died out after WWII, which is why I don't remember them. Looking at the age of some of the images, they probably are pre-war cigarette cards. I guess I just grew up knowing those little cards as tea cards.
    cigarettecards.co.uk/intro.htm
