14445474950198
  • HzTweaker
    HzTweaker Posts: 927
    okay so I just needed to be patient. I'm now receiving a flood of emails from myself lol.hzhza5q1nljf.jpg
    nooshinjohn Posts: 25,877
    They look great, but I am curious just how much of the internal volume of the cabinet they take up, and if that would have a negative impact on the sound.
    VR3 Posts: 29,386
    I've heard the modified Lsi9 powered on a krell system and I can assure you, it's definitely not negative. 😜
  • HzTweaker
    I asked the same thing. I believe Trey.
  • sucks2beme
    sucks2beme Posts: 5,681
    ok, big changes afoot.
    https://nanomesher.com/nanosounddac2/
    It's a raspberry pi direct mounted dac with
    a small front panel display and controls for volumio.
    And it has a remote!!!
    1st couple of minutes sounded BAD!!!!
    After a couple of hours, much better.
    I also had to play with a couple of settings.
    No preamp, just a external homemade passive
    pre (shunt style) to prevent volume mishaps in case
    of issues with the hardware volume control of the
    DAC. Setting changes can put it to 100%, so I always
    have it in line. I was using a audiogd dac via usb before.
    IT's feeding the McCormack.
    Jury's still out, but the sound has really hit a good point.
    I'm hoping after a couple of days it will be equal or better
    so I can keep things simple. My raspberry has a big honkin'
    usb stick with my music in lossless FLAC.
    It's got a very small footprint.
    Some users have hacked the interface for a 7" screen.
    But for now the goal was a small footprint and the ability to
    use the mini remote. I only need the tablet for setting up
    playlists.
    For someone looking for a small rig, you can get a small amp board
    to add on for a small desktop system.
    VR3 Posts: 29,386
    Just hooked this bad boy up... My road to simplicity continues!
  • sucks2beme
    Remote control stepped attenuator passive preamp.
    That's some high tech simple!
    VR3 Posts: 29,386
    I'm comparing it the ci audio passive preamp at the moment, not sure why one needs an active preamp after owning these, especially with a decent match between source and Amp
    audioluvr Posts: 5,871
    So what exactly is a passive pre? Just a volume controller?
    VR3 Posts: 29,386
    Essentially it is an in and a out with a volume knob.
    Some more involved as far as options, the ci audio has 4 inputs, dual outs, ht bypass, etc
    The axiom pre uses a nice stepped attenuator, you can add more inputs and outputs if you like for more money
    Today I figured out how to employ all the tools of the SugarCube and am now able to do everything including the correct track splits and click removal levels. Total time per LP, from needle drop to transfer to hard drive, is about 1 hour. Given that 90 percent of the work is automatic, all I need to do is verify the results and burn the finished work to the hard drive.
    JRiver has no trouble at all identifying the files, and the results are indistinguishable from the original LP. Once I am finished with the transfers, I will sell off my turntable setup and invest some of that feed up cash on improving my DAC...
    mhardy6647 Posts: 34,916
    edited June 2019
    audioluvr wrote: »
    Usually an attenuator (resistive or inductive) and - ideally :) - a source selector.
    The coolest ones include remote control, too, for the sofa spud market, of course. ;)
    I used to bristle at such gizmos being called a preamplifier, but since they're installed ahead of the amplifier... no harm, no foul. B)
    IF one doesn't need impedance matching (buffering), additional voltage gain or current drive between source and power amplifier, a good passive can be as good as it gets, IMO. I use one that's built around one of Dave Slagle's older transformer volume control modules (FWIW).
    46721118974_bbda9a7b6b_b.jpgDSC_4219 (2) by Mark Hardy, on Flickr
    treitz3 Posts: 19,946
    Trey, what is your preference....The new on or the old one you have been using?
    VR3 Posts: 29,386
    I probably won't make an immediate decision on that one, maybe by end of the month, I'm evaluating to much with the crossovers and such. I'll have the second utopia back together next week, I'll use them to evaluate the pres.
    Oh, I forgot about that. Thanks.
  • DaveHo
    DaveHo Posts: 3,580
    I've tried several passives over the years and found that a few of my favorite CDs are recorded at such a low level that achieving a decent volume is nigh impossible. How do you overcome that?
    DaveHo wrote: »
    Short answer -- you can't (other than a switch to a CDP with higher output) without added gain.
    Comment: Your problem strikes me as very odd, though, for two reasons.
    1) CDs, especially in more recent years, tend not to be mastered at low average signal levels.
    2) CD players tend to have high analog output voltage relative to the old "line level" standard.
  • sucks2beme
    That's the down side. If your source output is low
    Or your amp input isn't very sensitive you have a problem.
    My passive is a home brew, direct connection in and out.
    The alps pot just shunts signal to ground.
    The only real fix is to increase the pot value or
    Add a resistor between the pot and ground.
    As far as running the signal through the pot,
    I never liked the result. VR3's pre is as good as passive gets.
  • steveinaz
    steveinaz Posts: 19,545
    I ran a Placette passive for many years, and it interfaced well with my Parasound HCA-1500. I never had any gain issues with any source. Passives are super "clean" but that trait can also make them a bit boring.
    VR3 Posts: 29,386
    edited June 2019
    A passive isn't clean, your source is.
    Just my experience.
    Having maxed out the tri Vista dac, is all in the source! 😁
    Oooooo, a debate? Is it the passive or is it the source?
    Fun, fun....
  • joecoulson
    joecoulson Posts: 4,943
    That’s not fun, this is...
    Clipdat Posts: 13,078
    aye aye skipper!
  • joecoulson
    Nope! That’s right skip. I let’s those who want to swipe against jellyfish and step on crabs have all that fun...
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,742
    There are no jellyfish in lake Lanier.
    Harry / Marietta GA
  • joecoulson
    Nowhere near Lanier Harry...
    VR3 Posts: 29,386
    VR3 wrote: »
    So.... I have been trying to like this preamp all week. I just haven't been happy with the imaging, not very wide and congested and bright treble....
    I hooked up the ci audio back and immediately the imaging returned.
    Sent an email to luminous to get their thoughts. Ayee
  • 55LS70
    55LS70 Posts: 184
    Just ordered a Decware CSP3 preamp. It has yet to be built and I probably have to wait three or four months before that process is completed. Trolling the Decware website has caused me to take interest in SET amps. This rabbit hole has no bottom.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
