13031333536175
    mhardy6647 Posts: 32,042
    took me two hours to make four freaking cables (numerous cases of pilot error -- good thing I wasn't helming a 737-MAX8 :/ )... but, as I type this, all of the embarrassing cables have been purged from the main part of the upstairs hifi except for the tuner and the subwoofa.
    Not that you'll be able to tell from the photos I just took :|
    32552825977_b3ecce84f4_h.jpgDSC_4264 (2) by Mark Hardy, on Flickr
    47442002492_20678acc1e_h.jpgDSC_4262 (2) by Mark Hardy, on Flickr
  • verb
    verb Posts: 10,176
    Looking good Mark! :smile:
  • halo
    halo Posts: 5,616
    edited March 2019
    I guess that depends on what you consider to be embarrassing. For example, I see one pair of Acoustic Research interconnect cables (all blue) and one pair of Monster Cable interconnects (fuzzy ones in the back, silver color with blue stripes) in the background ((bokeh)). :p
    Yeah, but you essentially can't see the two brand new pairs now connecting the phono preamp and the DAC to that source selector/TVC "passive preamp" :)
    You can see the pair of new cables going from the passive towards the amp.
    I labeled the shield-connected ends of the connectors I made today (and earlier this week) with heatshrink. The first pair I made (seen in the photo above) just have a little snippet of masking tape at the shield-connected end :p
    nooshinjohn Posts: 24,563
    Today I began serious listening evaluation of a set of 1.5M Audioquest WEL RCA interconnects... so far I can say that solid silver is a vastly different listening experience, and that you don't need much of it to make a difference. The detail within the upper frequencies is definitely more airy and delicate. There is more space and shimmer up top as well, but it also walks the edge of inviting sibilance into the equation, which is not a good thing with Polk Audio's tweeters, even the RDO-198's.
    At this point, my next focus will be to get my Dreadnaught built and install the new binding plates I have had laying around for a while. Beyond that, I think I have come to the point where there is very little left to do besides sit back and listen. If there are more improvements to be made, it will need to come from replacing the Polks.
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson
    VR3 Posts: 27,366
    I run a set of dh labs revelation which are solid silver... I agree it adds a hint of shimmer
    edited March 2019
    I find so far that on some recordings it really can elevate the performance of the artists, and on others it can be distracting. They also really seem to have an impact on the SDA side of things. Greater bloom, expansion of the soundstage and mire pinpoint imaging with a very focused center. It seems like I am running my center channel at times.
    There seems to be just a bit more growl to electric guitars as well.
    Post edited by nooshinjohn on
  • stangman67
    stangman67 Posts: 2,036
    edited March 2019
    Got these puppies in, so far I am very impressed. Are they as good as my previous separates setup? No but I think it would be unrealistic to expect a 2000 set of speakers to keep up with 12k worth of equipment. I will say the difference is not huge though, and I haven’t even added the sub into the mix yet. I’m very happy with the decision to transition to these. Now waiting for some taller Skylan stands to come in!
  • musicnut23
    musicnut23 Posts: 16
    edited March 2019
    verb wrote: »
    Cool! And welcome! Post some pics of your fine work! :smile:
    Pics from the changes to my Ariston RD11S last week. Also switched out my rectifier this morning on the Dynaco ST-70. Purchased an old Amperex GZ34 from the classifieds on here (Thanks to @mikeyb128 ) to replace a JJ GZ34.
  • aiconn
    aiconn Posts: 277
    I finally took the time to troubleshoot the buzz in my Quads. I thought it might be the cable box, and sure enough that's it. I was surprised that it was causing the ground loop through the HDMI cable. It happens if the HDMI cable is plugged directly into the TV as well. I also tried a different cable to verify and it continued. I'll try swapping boxes next.
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • verb
    verb Posts: 10,176
    Just got these locally from a CL ad. Analysis Plus Oval 9's speaker cables with locking banana's, and a set of silver coated jumpers, also Analysis Plus! :smile:
    verb wrote: »
    [emphasis added]
    Is banana theft a big problem in your area? ;)
    sorry, couldn't resist.
    I spent a few minutes still tryin' to document my fine new phalanx (kind of a mini-phalanx) of freshly-minted wires upstairs.
    :p
    47502189341_604bff7dee_b.jpgDSC_4275 (2) by Mark Hardy, on Flickr
    47502189721_48d0222575_b.jpgDSC_4274 (2) by Mark Hardy, on Flickr
    I might even swap out those dump find Monsters one of these days...
    B)
  • verb
    verb Posts: 10,176
    Hehe! :) No but I like the locking aspect of em, so they don't get loose over time. Especially with the weight of those cables! :smile:
    Today I mounted my Dreadnaught transformer inside its case and got the new terminal plates for my SDA's drilled out and installed the binding posts.
    audioluvr Posts: 5,067
    verb wrote: »
    This must mean you are in the market for monoblocks... HA! you're always in the market!
    Gustard X26 Pro DACBelles 21A Pre modded with Mundorf Supreme capsB&K M200 Sonata monoblocks refreshed and upgradedPolk SDA 1C's modded / 1000Va DreadnaughtWireworld Silver Eclipse IC's and speaker cablesHarman Kardon T65C w/Grado Gold. (Don't laugh. It sounds great!)There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January. by Dr. Sardonicus
    pitdogg2 Posts: 23,356
    aiconn wrote: »
    If you have extra cable at the entrance you could re-terminate the F connector at the box and do not use the coax ground shield. Other's try 3 to 2 prong cheater plugs and it works. I believe its caused by having two different ground pontenials between house and cable. I've successfully used the F connector method with no problems. For some changing boxes doesn't help because it's not a box problem.
    My .02
  • aiconn
    aiconn Posts: 277
    aiconn wrote: »
    My .02
    You're on the money. Changing the box didn't help at all. I tried running the cable through a Panamax, but that didn't help either. Finally tried running it through a surge protector and the problem is solved.
    Denon DVD 2910
  • stangman67
    Did a little cable management using some simple split look and cable clips. These stands are temporary as I am waiting for Skylans to come in but they don’t have any cable management built in, so this concept should also work well when those come in.
    Gotta get my hands on a 2m set of eclipse rcas now. Anybody got one laying around?! g99pvjwy7b4u.jpeg
  • verb
    verb Posts: 10,176
    Nice Zach! Love the blue KEF's! :smiley:
  • verb
    verb Posts: 10,176
    Installed the Analysis Plus Oval 9's on the Bottlehead rig. At about 1m, they were the perfect length! Howard Jones putting em through the paces now! :smile:
  • stangman67
    Very tidy setup you got there Dave
  • verb
    verb Posts: 10,176
    stangman67 wrote: »
    Thanks Zach. I’m pretty arnal when it comes to cable management! :smile:
    Tony M Posts: 10,964
    I think you should turn your new ribbon cables 180 degrees.
    Just kidding. :p They're fine. ;)
    verb wrote: »
    stangman67 wrote: »
    You are welcome to come over and fix my cable mess any time you like.
  • verb
    verb Posts: 10,176
    Love to John. Next time I’m in CA for sure! :smile:
    verb wrote: »
    stangman67 wrote: »
    Looks great Dave! Notice any improvements in sound? Inquiring minds want to know...
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Nothing really jumped out as compared to a set of Douglass Connections cables I had previously. But I didn't really spend too much time with em, as the Bottlehead was put aside for the Antique Sound Labs monoblocks! :smile:
