This Should Be Interesting - Help Me Spend Money - New (Used) Tower Speakers...
@erniejade ^^ Big difference ^^ between 2ce and 3 meaning going up in number is for the better or worse? Trying to figure out the nomenclature.
The 3a being better, clearer, more bass, clearer mids.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
https://www.zuaudio.com/loudspeakers/omen-dirty-weekend-2
Be quick, in a week, and grab a pair of these.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
For 6 hundred bucks... you need to run and grab these, and if you don't like them, you can send them to me. Magnepan's Ribbon tweeter is sublime.They are a three hour drive from you and maybe the seller will meet you somewhere in the middle, or the Polkie Express can help out.
https://www.ebay.com/itm/Magnepan-Magneplanar-MG2-6R-True-Ribbon-Speakers/143184838662?hash=item21567b4006:g:CTwAAOSwk4hcc2CG
I had the 2.5Rs and they were awesome! Almost no sub needed and there was a live sound to them. You'd swear the singers were in the room.
If I didn't need money back when I sold them, I'd still have them.
I had a lot more space back then and played them quite often. 600 is a steal if they're in great condition. I received 550.00 for mine years ago during a recession.
Those real ribbons are superb!Most people just listen to music and watch movies. I EXPERIENCE them.
Not many have heard these but they are amazing. I'm playing "let's make a deal" with Klaus right now thanks to @stretchl (I'll PM you what happened if you'd like) and may have these for sale at less than your target price. Getting them to you could be "fun". 100 lbs each.
Nothing definite at the moment but things are moving along.
Aaron
Enabler Extraordinaire -
@ALL212 Ahhh, Klaus. I am interested so please do tell. I'm behind already on the first day in the office after spring break, so won't be able to respond immediately. But please share.
I also have a story to tell. Maybe we should talk by phone later this week? “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
http://Vimeo.com/channels/stretchphoto -
Honestly, I like pretty much everything about them. Great low end and sweet mid range. Not at all fatiguing. If you can get your ears on them then I highly recommend it. There are many Dynaudio models that you might find that you like. -
I truly truly appreciate the thoughts, comments, links and suggestions you all shared, gave me lots to think about and a wide net to cast which is always key to a good deal.
So these followed me home this weekend... JMLab Electra 926, thoughts and impressions to come.
Suffice to say because of the obvious condition issues, and the fact that the guy was moving in 5 days and just needed them gone, I was able to come to a favorable arrangement.
Good news is they have cleaned up well so far, still want to redo grill cloth, and work out some of the marring on the wood finish. The drink rings cleaned right off.
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Congrats manThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thanks @nooshinjohn, honestly, I might have enough left over to grab those Maggies too if I push it and see which ones I like better. I'm watching them right now and giving it serious consideration. I do worry about having to place them into the room, as you can see, I'm a little cramped off the wall.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Forget the Maggie’s. You won’t hear what they are capable of in that room.
Actually, they may do quite well there. I had MG20's cramped into a very small apartment and they were so good there that I got rid of my 2.3TL's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Nice speaker! I was actually looking at a set myself.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
None taken @dskip, like you say we work with what we have, and its certainly not ideal.
Any thoughts on if the Electra should be toed? I've tried both ways, I think so far I like them a little more with just the slightest toe-in as they are now, but it will be an evolution.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Those look amazing! Congrats!
@VR3 should be able to guide you in the ways of the JM Lab speakers!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Are the VR2's making their way into your home??HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Looking good!
I usually do a slight toe in, no tilt
Definitely get them off the wall atleast a foot and try to prevent furniture between them...
Congrats- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
[/quote]
Are the VR2's making their way into your home?? [/quote]
Liquids from Odyssey Audio are being negotiated.
Aaron
KEF Q750 retailing at $750/ea didn't make the list? I can't say I've heard them, but aren't they supposed to have trickle-down technology from the lauded LS series?Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
^^ Honestly, I have heard some of the KEF^^, and they remind me a little of Wharfedale, in that English "laid back" kinda way. Maybe unfair, probably just an internal bias, but I eliminated KEF for that reason, right or wrong.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I see. But the LS50 has a rep for being forward, and I figured with aluminum drivers the Q would be anything but laid back. I'll take your word for it, however.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
I have the Q150's and I would not describe them as "laid back" or as exceptionally forward. I think the previous generation of Q100's were more forward, brighter, and, possibly, more fatiguing. The Q150's are not fatiguing at all, to my ears, but they present many details, to me, in music that were veiled or hidden in the past. These are some of the most balanced speakers I've heard, especially with a sub taking care of the lowest notes. I am, of course, just a little biased. So, YMMV.
Hmm thanks for the comments, just goes to show, you have to listen to know for yourself. My bias out of ignorance of the brand probably eliminated a speaker (KEF) that i might have liked, completely unheard.
I'll have to give them a good listen if I run across a set!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Sooooo….How are you liking the Electra's?Things work out best for those who make the best of the way things work out.-John Wooden
I know you put a hard stop at $1500, but, just a few hundred more would get you a really nice pair of Usher MD2's. I know a guy that can hook that up.
LOVE my MD2's. I don't see them leaving my house for a very long time. As a matter of fact, they may carry me out of the house before the speakers leave
Things work out best for those who make the best of the way things work out.-John Wooden -
I 3rd the md2's
Puritan PSM156 -
Muy Bueno!
At first I wasn't sure, I definitely was impressed with just how good the Lsim705's are in that this wasn't the slam dunk at first listen I was expecting... But in the end, I believe these are definitely keepers.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
The older Electra’s are ok. I really wish you could have grabbed stangmans Arias for 1750$ they are exceptional, I think they sound like baby kantas. I’ve heard a lot of the focal line. The Aria is a giant killer speaker! I have them, and new Electra’s. The Electra’s being superior. If Sh$t hit the fan, I would be totally ok living with the Arias. They are super good! Not to mention easy to drive.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
You can't trust Paul, he's a Texan that speaks Texan, but doesn't own a pair of boots...just sayin'
txcoastal1 wrote: »You can't trust Paul, he's a Texan that speaks Texan, but doesn't own a pair of boots...just sayin'
I ain't got no idear whut yer talkin bout.Things work out best for those who make the best of the way things work out.-John Wooden
