189111314203
  • halo
    halo Posts: 5,619
    edited January 2019
    Then I will definitely have to invest in some stands. :)
    Amusingly enough, I was just broaching that concept (the stands, that is) to Mrs. H.
    Well, you did mention the Carver Crimson 275 integrated to her and, IIRC, she gave you the green light. Since you've not yet made that purchase, I'd say you're good to go on the stands ;)
  • halo
    halo Posts: 5,619
  • halo
    halo Posts: 5,619
    Vanilla is acting glitchy. "Unkownkn column 'Active' in 'field list'
    Anyone here speak "Vanilla?"
    @KennethSwauger ?
    nooshinjohn Posts: 26,023
    halo wrote: »
    @KennethSwauger ?
    It's been glitchy ever since the new site went live...
    Clipdat Posts: 13,100
    edited January 2019
    halo wrote: »
    @KennethSwauger ?
    Saw that earlier when trying to edit a post. It'll display that error, but if you navigate away to a new page, and then come back to the thread where you just made your post & edit, you'll see that the edit actually did save successfully, despite the error message.
    But at least the Recent Discussions auto refreshes in Firefox now! Yay!
  • halo
    halo Posts: 5,619
    Clipdat wrote: »
    Thanks Drew!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Picked up a ModWright PH 9.0 Phono Stage, sounding very good right out of the gate, sporting some cheap stock tubes no less.
  • halo
    halo Posts: 5,619
    Very nice! I used to own a ModWright modified Sony DVP-NS9100ES (Signature Truth Mod). Very solid piece of equipment with great sound. Congrats!!
  • Mike Reeter
    halo wrote: »
    Thank you Victor, I have a ModWright LS 100 Line Stage also, one of the deciding factors on going with the Phono Stage. And yes, very solid equipment with great sound.
  • verb
    verb Posts: 10,176
    verb wrote: »
    VR3 wrote: »
    Change out that outlet to the pangea 20 Amp outlet, built like a tank and affordable
    Yep. The generic outlet doesn’t have enough retention to withstand the weight of the cable. Another rabbit hole! :smile:
    Got this hospital grade outlet for 4 bucks. Made by Cooper. Built like a tank - I expect better retention of the AC9's while plugged in! :smile:
  • verb
    verb Posts: 10,176
    Replacement Marantz CD-1 came today! Warming up (been on the porch all day) before I hook it up! :smile:
  • Milito
    Milito Posts: 2,003
    edited January 2019
    verb wrote: »
    verb wrote: »
    VR3 wrote: »
    I just installed 2 Pangea Audio Premier AC Outlets (20 Amp White) I got here: https://www.amazon.com/dp/B01DV0LXKQ?ref_=pe_2640190_261118450_302_E_DDE_
    I use them on my Cullen gold power cable and Signal power cable and they work very well, really hold the plugs into the outlet.
    mhardy6647 Posts: 35,318
    halo wrote: »
    Hmmm... I wonder if I have $2500 of saved-up opportunity by passing on that amplifier...
    It is a testable hypothesis. B)
  • verb
    verb Posts: 10,176
    Milito wrote: »
    verb wrote: »
    verb wrote: »
    VR3 wrote: »
    Yep. I had my eye on those as well. The hospital grade outlet retains much better after doing some static testing (not installed yet), hope to install it this weekend! :smile:
    static testing...
  • verb
    verb Posts: 10,176
    LOL! Not that type of static testing, dear sir! :smile:
    edited January 2019
    oh :(
    Here I thought this was a fun hobby...
  • Milito
    Milito Posts: 2,003
    Well if the ones I got start losing their hold, I'll look for those.
    What did I do to my stereo rig today? Somehow managed to break/loosen one of the ceramic tube sockets on my Backert Labs Rhumba 1.2 Extreme.
    See that center gold disc/slug that holds the white ceramic portion in place? Well there's now a slight amount of space between it and the ceramic part which allows the ceramic part to rotate slightly CW and CCW and make an unpleasant ceramic on metal sound. When you insert a tube and fully seat it, it doesn't rotate anymore. Functionality seems unaffected, but knowing it's messed up is irritating to me.
    I blame this damn Upsale.. er Upscale Audio RCA tubes with excessive corrosion on the pins that I swapped in. Should've stopped when I felt how much resistance there was compared to the last tubes I had in, but NOOOO. Well now I have a loose tube socket to show for it.
    I feel like I am too dumb for tube gear at this moment. Sigh. Oh well, life lesson. Good excuse to send the Backert in to get the socket fixed and to get the new version of the feet plus other "upgrades".
    Except sending it in will mean I'm preamp-less.
  • joecoulson
    joecoulson Posts: 4,943
    Easily done. Almost did it with the Vincent right out of the box. Sorry Drew.
    Just my 2 cents: Put the blame not on the tubes but the sockets. Sorry, but based on the description of what happened (and, based on everything @Clipdat's ever posted, I am sure he didn't go all orang-utan on insertin' tubes into them) -- this is symptomatic of poor quality sockets.
    As the "hams" and DIY hifi crowd has known for decades, it is hard to beat NOS sockets. NOS ceramic sockets of high quality for 9 pin tubes are probably pretty pricey now, which is probably why equipment manufacturers are using modern "standard goods". :(
  • verb
    verb Posts: 10,176
    OMG Drew! Very sorry to hear. My EAR pre has a flimsy interface (PCB is unsupported) to the tube sockets, which concerns me.
    edited January 2019
    Oh no, make no mistake, I "orang-utan'd" the **** out of it. Boneheaded move.
    This is why I shouldn't touch any audio gear when I'm tired and exhausted. Wasn't thinking clearly.
  • stangman67
    stangman67 Posts: 2,330
    edited January 2019
    Yikes. That happens. I’m sending my pre in to backert as well for a few upgrades and a look through to see if they can replicate my hiss problem. Might be a gain issue with my amp, we will see. Great cs as always from backert
    Post edited by stangman67 on
    edited January 2019
    I agree, Zach. Andy emailed me back the same day just a few hours after I emailed him, and it was well outside of normal business hours.
    And, I purchased the preamp used, not new directly from them. They are a real stand-up company.
    Spent $286 shipping 3 boxes from the west coast to the east coast. Yay egregious FedEx shipping rates.
    Where do you live Clipdat?
    SF bay area.
  • verb
    verb Posts: 10,176
    Found these little guys to help with power cable routing (Pangea AC9).
  • joecoulson
    Those are very useful
    I have a coupe also.
