Polk Signature Series Official Discussion
1232426282931
  • deronb1deronb1 Posts: 4,755
    I would love to get a pair of S55 in here to compare with the Q Acoustic floor standers.
  • Ctxx24Ctxx24 Posts: 66
    Not sure if it's a screw up on their end or what..
    What does anyone think of getting some s60s for the front and moving my 55s to the rear?
  • cfrizzcfrizz Posts: 13,420
    Others, have had towers in front and back and seem to like it, try it and see. However, if you don't like it, make sure you have somewhere else where you can hook up the second pair of towers.
    Marantz AV-7705 PrePro, Classé 5 ch. 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
    I'm really wondering how different they are gs the 55s if it's worth it.. Or if they would need more power.. I don't use a amp
  • Try it and let us know
    I prolly won't be trying it.. My room is only 10x10 with short ceilings.. I'm sure I wouldn't benefit much
  • tonybtonyb Posts: 31,434
    Ctxx24 wrote: »
    in a 10 by 10 room ? overkill....
    B&k 1430
    Tad 803 speakers
    tonyb wrote: »
    Ctxx24 wrote: »
    Exactly why I chose not to get em.. Mine sound great
    Relocated my s10s from str8 overhead to angled at me and think they sound better..
  • D2Lo wrote: »
    @VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
    I have my front stage polk audio s20's, polk audio s35, and klipsch r-10sw sub. I now have four of the polk audio s10 to place as rear surrounds and side surrounds.
    Can you tell me what mount was used?
    I would like my wall surrounds to have this same clean look with virtually no wall gap.
  • DaveHoDaveHo Posts: 2,416
    Mostly likely hung using the keyhole slot which is integrated into the power port.
    D2Lo wrote: »
    You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s.
  • halohalo Posts: 5,198
    Ctxx24 wrote: »
    Do the S20 have a keyhole mount built into the back? I thought they did not.
    halo wrote: »
    Ctxx24 wrote: »
    Not sure about the 20s don't have then.. They are ridiculously huge..i wouldn't use them for rears.. Mains they would be good
  • mrlorenmrloren Posts: 2,083
    halo wrote: »
    Ctxx24 wrote: »
    no they do not
    Family Room:
    Samsung UN75RU710DFXZA,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
    Main: Polk LsiM 705
    Center: Polk LSiM 704C
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES AVR, Sony DVP-NS3100ES for disc
    Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
    Old sony 12" Sub
    Mini tower PC with 400GB of music
    Ctxx24 wrote: »
    You they have the built in hole...
    The older I get, the more I ask that question....don't ask me why. :)
    B&k 1430
    Tad 803 speakers
  • ClipdatClipdat Posts: 7,134
    Nice looking setup! The only thing that concerns me is no airspace above the Marantz receiver to allow it to vent it's heat.
    Synomenon wrote: »
    The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
  • I was worried about that too so I cut open the back of that nook in the TV stand the Marantz is in so there would be airflow moving over it either through the front or from the back.
    edited February 2018
    Nice. Well, usually they require at least a 3-6"+ or so of air space above the top vents, but maybe since it's their slimline series they run cooler.
    As long as you are happy with the temps, then carry on. :)
    Synomenon wrote: »
    Could alway find a way to mount one of these to pull air over it https://www.coolerguys.com/collections/cabinet-cooling
    These are great if you can fit it https://www.amazon.com/dp/B01LW0G46K?ref=emc_b_5_t
    Family Room:
    Main: Polk LsiM 705
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Old sony 12" Sub
  • Ctxx24 wrote: »
    D2Lo wrote: »
    Thank you for the information. I now have my brand new 5.1.4 media room set up with Polk S20 Fronts, Polk S35 Center, Polk S10 Surrounds, and Polk V60 in ceiling atmos (x4), and Klipsch RS10W subwoofer, all driven by an Onkyo TX-RX920. The signature series sounds amazing, combined with the V60s. The sound envelop is seamless.
    All that's left to do is replace furniture, carpet, and paint.
    Congrats and Welcome to Club Polk!
    Ctxx24 wrote: »
    D2Lo wrote: »
    Awesome man
  • Thank you!
    Added the final piece of hardware: Isoacoustics Iso-Pucks.
    These really open up the s35 center channel for those that will not wall mount.hez5072azmjk.jpg
  • mhardy6647mhardy6647 Posts: 22,958
    FWIW. Interesting perspective on the S20 loudspeakers compared to a couple of other recent/current small, low-ish cost darlings, as seen Someplace Else.
    http://audiokarma.org/forums/index.php?threads/wharfedale-denton-80th-anniversary-noobie-review.710399/page-3#post-11584387
  • DSkipDSkip Posts: 16,113
    Good move HTGuy! The jump from the TSi/Monitor line to the Signature is more like a giant leap. There is literally no comparison between them.
Howdy, Stranger!
