Polk Signature Series Official Discussion
That's where I picked up my receiver, no issues so far. I was planning on standing pat for a while, but if this deal is still around in a couple months when my finances loosen up some I might have to pull the trigger. Under $500 for a pair, delivered? WowPro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
Well I am in Canada and paid 798 Canadian for my pair of S60 and free delivery from an electronics store here in Canada. I think for the price you can get these speakers for it is a no brainer. Polk has done a great job with these speakers as far as I am concerned
Who here has s15s on speaker stands and what stand thanks
Hi Ct,Who here has s15s on speaker stands and what stand thanks
Not sure what your budget is but I'm using cheap Sanus stands. They look cheap up close, but ok for the price. $50
I will probably upgrade to better ones at one point but for now they're ok.
IF you can spend more there are much better options also depending on the height you want. Mine are 31".
Also I use Bluetack to keep them in place . I wouldn't even consider not using Bluetack.
https://www.amazon.com/gp/product/B00006JQ5O/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B001FGLX72/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
They say the top plate is only 5x5 that seems pretty small.. Price is ok and height is good tho.. -
I used my S15s with the TransDeco Speaker Stands, 32-Inch and they work brilliantly together. I've moved on from the bookies but still have the stands and I'd be willing to let them go as I'll have no use for them when we move.
HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
How much? I would imagine they aren't cheap to ship -
If anyone is interested in the s55s they are onky 162 each right now on Amazon.. That's cheap!Post edited by [Deleted User] on
I would love to get a pair of S55 in here to compare with the Q Acoustic floor standers.
Not sure if it's a screw up on their end or what..
What does anyone think of getting some s60s for the front and moving my 55s to the rear?
Others, have had towers in front and back and seem to like it, try it and see. However, if you don't like it, make sure you have somewhere else where you can hook up the second pair of towers.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I'm really wondering how different they are gs the 55s if it's worth it.. Or if they would need more power.. I don't use a amp
Try it and let us know
I prolly won't be trying it.. My room is only 10x10 with short ceilings.. I'm sure I wouldn't benefit much
in a 10 by 10 room ? overkill....HT SYSTEM-
lsi 9's -
Exactly why I chose not to get em.. Mine sound great -
Relocated my s10s from str8 overhead to angled at me and think they sound better.. -
@VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
I have my front stage polk audio s20's, polk audio s35, and klipsch r-10sw sub. I now have four of the polk audio s10 to place as rear surrounds and side surrounds.
Can you tell me what mount was used?
I would like my wall surrounds to have this same clean look with virtually no wall gap. -
Mostly likely hung using the keyhole slot which is integrated into the power port.
newsseriesowner wrote: »@VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s. -
Do the S20 have a keyhole mount built into the back? I thought they did not.You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s.
Not sure about the 20s don't have then.. They are ridiculously huge..i wouldn't use them for rears.. Mains they would be good -
no they do notWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
You they have the built in hole...
The older I get, the more I ask that question....don't ask me why.
lsi 9's -
Originally tried the S20 with a tiny Yamaha receiver and didn't like the boomy sound it seemed to have.
Got a better receiver and added a S30 center and SVS PB12 sub. and the setup sounds great now in this small-ish media room. I use it mostly for TV and movies.
The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
Nice looking setup! The only thing that concerns me is no airspace above the Marantz receiver to allow it to vent it's heat.The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
I was worried about that too so I cut open the back of that nook in the TV stand the Marantz is in so there would be airflow moving over it either through the front or from the back.
Nice. Well, usually they require at least a 3-6"+ or so of air space above the top vents, but maybe since it's their slimline series they run cooler.
As long as you are happy with the temps, then carry on.
Could alway find a way to mount one of these to pull air over it https://www.coolerguys.com/collections/cabinet-cooling
These are great if you can fit it https://www.amazon.com/dp/B01LW0G46K?ref=emc_b_5_tWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
