Polk Signature Series Official Discussion
1222325272831
  • Ctxx24Ctxx24 Posts: 66
    I prolly won't be trying it.. My room is only 10x10 with short ceilings.. I'm sure I wouldn't benefit much
  • tonybtonyb Posts: 32,466
    Ctxx24 wrote: »
    What does anyone think of getting some s60s for the front and moving my 55s to the rear?
    in a 10 by 10 room ? overkill....
    tonyb wrote: »
    Ctxx24 wrote: »
    Exactly why I chose not to get em.. Mine sound great
    Relocated my s10s from str8 overhead to angled at me and think they sound better..
  • D2Lo wrote: »
    @VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
    I have my front stage polk audio s20's, polk audio s35, and klipsch r-10sw sub. I now have four of the polk audio s10 to place as rear surrounds and side surrounds.
    Can you tell me what mount was used?
    I would like my wall surrounds to have this same clean look with virtually no wall gap.
  • DaveHoDaveHo Posts: 2,715
    Mostly likely hung using the keyhole slot which is integrated into the power port.
    D2Lo wrote: »
    You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s.
  • halohalo Posts: 5,570
    Ctxx24 wrote: »
    Do the S20 have a keyhole mount built into the back? I thought they did not.
    halo wrote: »
    Ctxx24 wrote: »
    Not sure about the 20s don't have then.. They are ridiculously huge..i wouldn't use them for rears.. Mains they would be good
  • mrlorenmrloren Posts: 2,315
    halo wrote: »
    Ctxx24 wrote: »
    no they do not
    Family Room:
    Samsung UN75RU710DFXZA,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
    Main: Polk LsiM 705
    Center: Polk LSiM 704C
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES AVR, Sony DVP-NS3100ES for disc
    Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
    Old sony 12" Sub
    Mini tower PC with 400GB of music
    Ctxx24 wrote: »
    You they have the built in hole...
    The older I get, the more I ask that question....don't ask me why. :)
  • ClipdatClipdat Posts: 8,309
    Nice looking setup! The only thing that concerns me is no airspace above the Marantz receiver to allow it to vent it's heat.
    Synomenon wrote: »
    The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
  • I was worried about that too so I cut open the back of that nook in the TV stand the Marantz is in so there would be airflow moving over it either through the front or from the back.
    edited February 2018
    Nice. Well, usually they require at least a 3-6"+ or so of air space above the top vents, but maybe since it's their slimline series they run cooler.
    As long as you are happy with the temps, then carry on. :)
    Synomenon wrote: »
    Could alway find a way to mount one of these to pull air over it https://www.coolerguys.com/collections/cabinet-cooling
    These are great if you can fit it https://www.amazon.com/dp/B01LW0G46K?ref=emc_b_5_t
    Family Room:
    Main: Polk LsiM 705
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Old sony 12" Sub
  • Ctxx24 wrote: »
    D2Lo wrote: »
    Thank you for the information. I now have my brand new 5.1.4 media room set up with Polk S20 Fronts, Polk S35 Center, Polk S10 Surrounds, and Polk V60 in ceiling atmos (x4), and Klipsch RS10W subwoofer, all driven by an Onkyo TX-RX920. The signature series sounds amazing, combined with the V60s. The sound envelop is seamless.
    All that's left to do is replace furniture, carpet, and paint.
  • cfrizzcfrizz Posts: 13,420
    Congrats and Welcome to Club Polk!
    Marantz AV-7705 PrePro, Classé 5 ch. 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
    Ctxx24 wrote: »
    D2Lo wrote: »
    Awesome man
  • Thank you!
    Added the final piece of hardware: Isoacoustics Iso-Pucks.
    These really open up the s35 center channel for those that will not wall mount.hez5072azmjk.jpg
  • mhardy6647mhardy6647 Posts: 25,815
    FWIW. Interesting perspective on the S20 loudspeakers compared to a couple of other recent/current small, low-ish cost darlings, as seen Someplace Else.
    http://audiokarma.org/forums/index.php?threads/wharfedale-denton-80th-anniversary-noobie-review.710399/page-3#post-11584387
  • firsttimerfirsttimer Posts: 87
    Congrats on the purchase I have been enjoying my signature S60 towers since I have purchased them. Wonderful speakers
  • MilitoMilito Posts: 979
    Replaced my 2 Monitor 60's and a CS2 with a pair of S55's and a S30. Nice improvement in sound.
    I'm glad I saw this thread as I was going to get a pair of RTiA7's and decided on the S55's.
    Yamaha RX-A2070, Music Hall A70.2 integrated amp, B&K 4420 Reference, Bluesound NODE 2i, HSU VTF-2 MK5, LSiM705, LSiM704, Technics PD867, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Cullen Gold Power Cable, Signal Power Cables, Furman PL-8C 15 Power Conditioner, Fluance RT85, Parasound Zphono USB Phono Preamp, Sony 65" 900F, Sony UBP-X700, Fios.
    Horder....when did ya pick up the Marantz ?
  • felipefelipe Posts: 423
    Hey guys! I’ve joined the Signature Series club ;). Got these when there was a sale a couple of months ago. These are definitely a step up from the T series I previously had...I even went Atmos :smiley:. Unfortunately, due to budget, my subs are still the same.
    Looks like there is another sale on the Signatures again, and I was thinking of getting either the S50 or S55. Opinions? I’m not looking at the S60 because I’m in a condo on the third floor (in a 5 floor building) and not looking to spend more than 600. Will either of these floorstanders be good enough so that I won’t need my subs?
    My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
    Here’s the front sound stage and the space that I got to work with...sorry for the poor lightning
    felipe wrote: »
    Are you saying you wana get rid of your subs? Imo for music the 55s work great without subs.. For home theater you always need a sub Imo
    Honestly, I’m just exploring options. I moved to this condo a few months ago (coming from a house), so I’m new to this kind of living and adjusting to having people above and below and on both sides of me lol. The subs dont go very low, and the frequency response of these floorstanders look to be similar...so at the same time trying to free up some floor space and simplify.
Howdy, Stranger!
