Power distribution and conditioning
Interested to see what is being used and recommended.
I want to protect my equipment and "clean" the power going to my electronics.
Looking for the best bang for the buck.
Thanks in advance!
Keith
Thanks in advance!
Keith
Interested as well.
I'm using a PS Audio quintet. Lower in their lines of PC'ers but gets the job done and keeps my system quiet as a church mouse. Run everything through it, including cable.HT SYSTEM-
lsi 9's -
Nice looking unit. Appears to be discontinued now though.I'm using a PS Audio quintet. Lower in their lines of PC'ers but gets the job done and keeps my system quiet as a church mouse. Run everything through it, including cable.
You can still find them, used or demo's, Ebay has one I think. Used they sell for about 250. Nice thing about them too is they are not current limiting and are modular. Mines been going on roughly 6 years now without a hiccup.HT SYSTEM-
lsi 9's -
I used the PS Audio P5 for a bit. I will try something else. Will try the furman 20 ref and then Shunyata in the futureMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
A friend of mine that works at a local HiFi store recommended the Furman Elite 15pfi. Said it is the best value in the store.
$2,500 though. That's a tough pill to swallow.
Especially when you think about what kind of speakers you could buy for that.A friend of mine that works at a local HiFi store recommended the Furman Elite 15pfi. Said it is the best value in the store.
I use the PS Audio Power Plant 3 that I picked up on sale for $1500 (reg 2500) and am very happy.
Everything I've been reading points to PS Audio being the "endgame" when it comes to legit power distribution/conditioning/regeneration.I use the PS Audio Power Plant 3 that I picked up on sale for $1500 (reg 2500) and am very happy.
I just got this beauty from a fellow CP member @Jetmaker737 from the classifieds:
Furman Elite 15pfi !!!
http://forum.polkaudio.com/discussion/180272/furman-elite-15#latestBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
And how do you like it? Notice any aural improvements?I just got this beauty from a fellow CP member
/quote] -
I don't know to whom you are speaking in your silly, backwards-quoting world, but the Furman Elite 15 PFi can be had new for $750 shipped.$2,500 though. That's a tough pill to swallow.
My bad, I got it confused with this one: https://www.crutchfield.com/p_756ITREF15/Furman-IT-Reference-15i.html#&gid=1&pid=2
The Reference 15i.I don't know to whom you are speaking in your silly, backwards-quoting world, but the Furman Elite 15 PFi can be had new for $750 shipped. -
See what kind of dooshbaggery happens when the quote comes AFTER the response?
Not sure what you are referring to.See what kind of dooshbaggery happens when the quote comes AFTER the response?
Verb's post at xx:45p.m. (Your results may vary as local time zones come into play.)
Appears to be a standard case of user error (PEBKAC).Verb's post at xx:45p.m. (Your results may vary as local time zones come into play.)
I agree with the dooshbaggeryNESS!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Audio Advisor has both the Furman Elite 15 PFi and the 15DMi open box, full warranty for $533 and $426 respectively. They also have the best 30 day return policy around....absolutely no questions asked.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Reference. Not the elite. I think that’s what the other poster was suggesting.
I’ve been on the lookout, if I find one I’ll nab it.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I really dig the pull out lights on the Furman.
@Joey_V Audio Advisor has an open box Furman IT Reference 20i for a pretty good price. I purchased my 15i from them and it was essentially new.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
I'm thinking when I get my new rack, installing one of these would be worthwhile and easy: http://www.audioadvisor.com/prodinfo.asp?number=PGNPR
Anyone upgraded their power receptacle and noticed a positive improvement? -
Was just looking up guides for replacing an electrical outlet, and came across this photo:
/young-woman-checking-socket-with-multimeter-643782351-582875875f9b58d5b1b5ed20.jpg)
God DAMN! I'd let her work on my "outlet" any day, if you know what I mean. -
Most everyone has construction grade outlets, and if your home is older, even more sucky outlets. Just a simple hospital grade outlet should yield some benefits. PS Audio makes nice ones too....highly recommended.HT SYSTEM-
lsi 9's -
I'm trying to decide between the Pangea SE and the PS Audio.
They're both $50.
http://www.audioadvisor.com/prodinfo.asp?number=PSPP
http://www.audioadvisor.com/prodinfo.asp?number=PGNPRSE
Looks like the PS Audio uses polished nickel as the metal of the grips, and the Pangea 24k gold plated phosphor bronze.I'm thinking when I get my new rack, installing one of these would be worthwhile and easy: http://www.audioadvisor.com/prodinfo.asp?number=PGNPR
Go with the PS audio.
