Show me your TT's !!!
1456810
    nooshinjohn Posts: 25,917
    mhardy6647 Posts: 35,006
    there seems to be a theme, a leitmotif, if you will, developing this morning...
  • verb
    verb Posts: 10,176
    Yes uncle Jesse sightings all over!
    msg Posts: 10,452
    Clipdat wrote: »
    My vinyl/DJ setup powered off with dust covers in place, and then powered up and ready to go.
    The black bag on the lower left is also full of records. And I have another 6 cube storage unit full of vinyl in the other room.
    awww sheet, pardy at Drew's!
  • verb
    verb Posts: 10,176
    Sweet setup!
    Tony M Posts: 11,617
    edited February 2018
    How heavy could a TT be? Maybe one like John's. Yup, I just read the sentence below the video. It must be just like John's.
    https://www.facebook.com/audiogon/videos/10155028619695740/
    Clipdat Posts: 13,095
    Time for her to retire.
    Should've used a dolly or hand truck to get it off the truck and up to the door. Since when does UPS advocate rolling a package like that?
    Yet another reason why I will only use FedEx if possible.
    Tony M wrote: »
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    OMG! That is ridiculus! I can only imagine their faces when they opened up the box! Ouch!
    I'm surprised they didn't just immediately refuse the shipment, and have her roll it right back down to the truck.
    At least they had a nice high resolution video to submit with the shipping insurance claim.
    verb wrote: »
  • halo
    halo Posts: 5,616
    dr1978 wrote: »
    halo wrote: »
    Technics SL-Q3 w/ Shure M95ED
    Bottlehead Reduction Phono pre with Integration upgrade (Amperex white PQ 6922 tubes) & Mahogany base
    Is that the "definitive version" of Fragile that just came out? One of my favorite albums ever and the new version is packaged perfectly and sounds great.
    dr1978 wrote: »
    halo wrote: »
    dr1978 wrote: »
    halo wrote: »
    This is the standard version of the latest 180g 3-record set/release/pressing from the nin.com store. The store had major issues getting these newer releases out to those, like me, who preordered them. The site has periodically been “under maintenance” ever since. The previous release/pressing is said to be not very good. I can’t find any faults with these. I just need a better cart and a SUT to take full advantage! lol.
    SCompRacer Posts: 9,112
    verb wrote: »
    A unique concept. Making a comeback?
    I have a vertical table in the downstairs retro system!
    https://youtu.be/T8OjlcJjSEE
    My air bearing linear tracking a warp...
    https://youtu.be/YYD9CIWJELc
    My Nottingham Space 294 with 12" Moerch DP-6 arm and Wave Mechanic (Nottingham's speed control power supply). FF to 1:30 for the vinyl part... This was my go to table before the Lenco idler drive.
    https://youtu.be/BIJX9TmlaSM
  • dr1978
    dr1978 Posts: 424
    halo wrote: »
    Yeah, that's the one. I think they branded it the definitive edition. I wanted to do the preorder as soon as they announced it but (luckily it turns out) I didn't have the cash. I heard about the delays but then kind of forgot about it. Hopped on their site not long ago when I ran into some cash and it was available to ship immediately. This just might be the first album I spin once I get my new setup put together.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
    Awesome Trentemoller album, love that one - have the same vinyl.
    That's a great KLF track as well.
    Nice tune choices sir :)
    SCompRacer wrote: »
    SCompRacer wrote: »
    I had a Yamaha YP-D10 once upon a time...this table had adjustable VTA.
    Clipdat wrote: »
    Thanks! Remember Wanda Dee? We likes to have some fun along with serious music!
    This falls in under..
    * Other gizmos, speed adjust, pitch, anti skip, etc.
    I was trying different turntables and often didn't have protractors for them. This also allowed for marking and drilling arm board - spindle center to center.
    *Other gizmos, speed adjust, pitch, anti skip, etc....
    I was a beta tester for the 25 watt Phoenix power supply. The Lenco has a high torque motor, ~ 22 watts. Previously he only offered a 6 and 15 watt controller, IIRC. Adding the RoadRunner tach meant having platter speed automatically controlled.
    The Lenco has 4 speeds. You moved the idler postion for 16, 33, 45 and 78. I olny need 33 and 45, so now I push a button between 33 and 45 speeds instead of moving the idler.
    Sadly he retired and closed shop. His approach was better than some of the previous high dollar analog speed controls. Ones that shifted speed as they warmed up.
  • Jhayman
    Jhayman Posts: 1,548
    My little slice of Heaven
    [/i]sbrkx58oo908.jpg
  • Jhayman
  • verb
    verb Posts: 10,176
    Sweet TT @Jhayman !
  • verb
    verb Posts: 10,176
    You've been holding out on us @SCompRacer ! Nice TT's! The speed control unit is way cool! Too bad he closed up shop.
  • verb
    verb Posts: 10,176
    SCompRacer wrote: »
    verb wrote: »
    I knew someone on CP would have one of those babies! What are your thoughts on it? Pros/Cons? Very curious.
    verb wrote: »
    It doesn’t see a lot of use in the basement, but it works every time I use it. It was in nice shape, all it needed was a belt, clean and lube. The belt had melted onto the pulleys from age. I view it as more of a curiosity than a daily driver.
    It sounds pretty good, but it can be bested by a horizontal table. You have a long main bearing lying on its side and what can be a finicky arm to repair if it gives you trouble.
    I used to bring it upstairs after folks were intoxicated. If they never seen one before, reactions could be amusing. Heck, sober folks have done great double takes…lol
    The innards...actually pretty well constructed.
    The vertical turntable thing freaks me out in the same way that The Beatles freak out @msg
    Viking64 Posts: 7,549
    Clipdat wrote: »
    Imagine playing a Beatles album on a vertical turntable? You could shoot arrows at the apple on the Apple Records label as it spun around just like William Tell. That would freak just about ANYONE out.
    I find the thought of The Greatful Dead on a vertical table a bit more freaky...
  • vcwatkins
    vcwatkins Posts: 1,993
    Nothing fancy, but I like it. Kinda hard to make out. It's an RP6 on a Cloud.
    I find the thought of The Grateful Dead on ANY turntable to be disturbing. :p
