SDA CRS+ With an External Crossover Twist.... :-)
    pitdogg2 Posts: 27,884
    Toolfan66 wrote: »
    They sell them that way.. B)
    White is the tweeter.
    Red is the Drivers..
    That is very cool and sexy stuff. I had thought you milled some of that delrin.
    Toolfan66 Posts: 18,414
    Thanks, these will definitely be a one of a kind set of CRS+'s..
  • nikonik
    nikonik Posts: 120
    Very creative and with a twist from the ordinary!
    At home in a blizzard, and I don't have everything to move forward.. :/
  • Mystery
    Mystery Posts: 2,546
    edited March 2016
    Toolfan66 wrote: »
    One car already stuck outside...
  • RandyCroissant
    Save your back It'll be gone in a day or two.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • FTGV
    FTGV Posts: 3,650
    Toolfan66 wrote: »
    Seeing double!!!
    Gret looking boxes Larry.I wish I could find something like that for a phono pre I,m working on.
    edited March 2016
    A little Spike P.o.r.n.
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,102
    Really nice sculpture.
    Harry / Marietta GA
    Going to be a good weekend!! B) got the stands back from paint, spikes are done..
    Woo Hoo!!!
  • Mystery
    edited March 2016
    Toolfan66 wrote: »
    That's enough spikes for the whole block. ;)
    Kinda reminds of ammunition.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited March 2016
    Spectacular Larry!
    Toolfan66 wrote: »
    I would really like to have the veneer re-done on the cabinets while i have them apart, I just don't know where to go to have it done..
    I had my CRS+ cabinets re-veneered as a local custom cabinet shop.
    Toolfan66 wrote: »
    I have wondered the same thing, but I do see where it makes sense in doing so, but at the same time, most all amps, pre amps, CD players, blue ray players etc. have steel housings..
    You find aluminum chassis as you go up in quality and cost. Higher quality, lower noise electronic circuits are more sensitive to environmental electrical noise, and aluminum is a better shield against such noise, plus, aluminum does not magnetically interact with inductors.
  • RandyCroissant
    Talk about a bed of nails wow!!! fall on those and your done..
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    Thanks Ray,
    I will look for a shop here in town.. B)
    Just a mock up to get a feel how it will look..
    Haha, me too!! :p
  • Mystery
    Toolfan66 wrote: »
    I think Polk should hire you.
  • BlueBirdMusic
    Larry,
    I need a smaller TEC Infrared Gas Grill.
    Could it be used as one?
    Harry - GA
    Harry / Marietta GA
    Larry,
    Harry - GA
    Ha, it might!! :)
  • shanedrew
    shanedrew Posts: 84
    I am loving this post!
    shanedrew wrote: »
    Thanks, It was nice talking to you today...
  • agfrost
    agfrost Posts: 2,493
    I love the turnaround time on your projects, Larry. From imagination to fabrication & finishing in just days...
    Looking good!
    Jay
    Well I got the dynamat put down, going to mount a piece of delrin between the 16mh and the crossover board, a piece of delrin will be mounted behind the 16mh as well..
    agfrost wrote: »
    Looking good!
    Thanks, it's a plus when I have the time in the shop, and a few of my good guys to help me out, and make it happen while I take care of other things as well..
  • Nightfall
    Nightfall Posts: 10,083
    Very impressive sir.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mystery
    Overkill^2 but we can't expect less from you.
  • TennMan
    TennMan Posts: 1,266
    Very impressive components and metal work. What improvements do you expect in the sound of the CRS+ without the components inside? I realize you will gain some volume inside the cabinet without the crossovers mounted in there but I thought the passive radiator was turned to the volume of the cabinet. Have you taken that into consideration?
    Thanks, not sure what improvements there will be if any, will just have to wait and see, as far as the internal volume, I'm not messing with that, and if Matt took into consideration the space the crossover would take, than many of us have screwed that up with bigger caps and solen inductors..
    Honestly I don't see taking them out jacking with the tuning of the speakers or the PR's..
    Time will tell, but I think I'm in for a treat, and the best thing is my buddy Brian has a stock set, and we will be doing an A/B shoot out.. B)
