SDA CRS+ With an External Crossover Twist.... :-)
They sell them that way..
White is the tweeter.
Red is the Drivers..
That is very cool and sexy stuff. I had thought you milled some of that delrin.
Thanks, these will definitely be a one of a kind set of CRS+'s..
Very creative and with a twist from the ordinary!
At home in a blizzard, and I don't have everything to move forward..
Ya, I'm not digging out either.
One car already stuck outside...
Save your back It'll be gone in a day or two.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Gret looking boxes Larry.I wish I could find something like that for a phono pre I,m working on.
Seeing double!!!
A little Spike P.o.r.n.
Really nice sculpture."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Going to be a good weekend!!
got the stands back from paint, spikes are done..
Woo Hoo!!! -
Spectacular Larry!I would really like to have the veneer re-done on the cabinets while i have them apart, I just don't know where to go to have it done..
I had my CRS+ cabinets re-veneered as a local custom cabinet shop.I have wondered the same thing, but I do see where it makes sense in doing so, but at the same time, most all amps, pre amps, CD players, blue ray players etc. have steel housings..
You find aluminum chassis as you go up in quality and cost. Higher quality, lower noise electronic circuits are more sensitive to environmental electrical noise, and aluminum is a better shield against such noise, plus, aluminum does not magnetically interact with inductors.
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Talk about a bed of nails wow!!! fall on those and your done..Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Thanks Ray,
I will look for a shop here in town..
Just a mock up to get a feel how it will look..
Larry,
I need a smaller TEC Infrared Gas Grill.
Could it be used as one?
Harry - GA"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
BlueBirdMusic wrote: »Larry,
Harry - GA
Ha, it might!!
I am loving this post!
I love the turnaround time on your projects, Larry. From imagination to fabrication & finishing in just days...
Looking good!Jay
Well I got the dynamat put down, going to mount a piece of delrin between the 16mh and the crossover board, a piece of delrin will be mounted behind the 16mh as well..
A little overkill? Maybe, but I have it, so why not..
Looking good!
Thanks, it's a plus when I have the time in the shop, and a few of my good guys to help me out, and make it happen while I take care of other things as well..
Very impressive sir.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Overkill^2 but we can't expect less from you.
Very impressive components and metal work. What improvements do you expect in the sound of the CRS+ without the components inside? I realize you will gain some volume inside the cabinet without the crossovers mounted in there but I thought the passive radiator was turned to the volume of the cabinet. Have you taken that into consideration?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Thanks, not sure what improvements there will be if any, will just have to wait and see, as far as the internal volume, I'm not messing with that, and if Matt took into consideration the space the crossover would take, than many of us have screwed that up with bigger caps and solen inductors..
Honestly I don't see taking them out jacking with the tuning of the speakers or the PR's..
Time will tell, but I think I'm in for a treat, and the best thing is my buddy Brian has a stock set, and we will be doing an A/B shoot out..
