Bi-Wiring, what exactly is it doing?
123457
    tonyb Posts: 33,066
    Yep, 5 rounds of MIT cable demo's and everyone of them must be some sort of delusional, uneducated caveman....on LSD no less.
  • skrol
    skrol Posts: 3,437
    Just finished my 2nd bag of popcorn.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ken brydson
    ken brydson Posts: 8,988
    skrol wrote: »
    Only 2??
  • headrott
    headrott Posts: 5,496
    edited June 2015
    xcapri79 wrote: »
    tonyb wrote: »
    This is my nomination for post of the year. :o
    Perhaps, instead of following the usual pattern, you could address some of the questions brought up in this thread and the "sound quality and time of day" thread?
    I think we could all potentially learn something if you would make the choice to do so?
    What do you say?
    Post edited by headrott on
  • BlueFox
    BlueFox Posts: 15,251
    LOL. Greg, you are an optimist. :)
  • DarqueKnight
    DarqueKnight Posts: 6,765
    vmaxer wrote: »
    There was a time I couldn't tell the difference, but as I have upgraded over the years it is almost unbelievable how much difference cables can make. I love the hobby (if that's a correct way to say it). I just wish I could afford the really high end.
    There have been lots of times (documented on this forum) when I sent a cable back because I didn't hear a difference or improvement, and had the opposite result when I revisited the same cable after an equipment upgrade.
  • DarqueKnight
    vmaxer wrote: »
    Just tired of the trolls, ...
    If you starve them they will die.
  • BlueFox
    I don't mind the trolls per se, but I have decided I am no longer going to be insulted by those clowns. Implying that people who can hear differences with cables are delusional, or weak minded, is crossing the line.
  • headrott
    BlueFox wrote: »
    Keiko wrote: »
    Highly doubtful, Greg.
    Just pointing out that rather than trying to follow the same behavioral pattern(s), it would be much more constructive to answer the questions asked in the two threads (opposed to trying to get them shut down with the motive of avoiding the questions).
    Let's see if @xcapri79 and @kevintomb can do as much?
    I do see your points however; believe me.
    F1nut Posts: 51,686
    And Bingo was his name!
    tonyb Posts: 33,066
    vmaxer wrote: »
    Bingo.....again.
    We've been saying this all along. Cables making a difference isn't as cut and dry as some want to make it out to be. Simply way too many variables.
    You'd be hard pressed to find anyone who does a review like DK does, even from audio magazines who get paid to review stuff. Plus he backs it up with measurements/science.....which some say is always missing.
    If you can/can't hear a difference on your system with your ears, doesn't mean someone else can/can't in theirs. If you can subscribe to that statement, then we can be done with silly cable threads like this.
  • ukcolin99
    ukcolin99 Posts: 286
    vmaxer wrote: »
    [quote="What equipment??
    Yamaha RX-A3020, Polk: LSiM705's, LSiM706c, LSiM703's, TL2's, BIC America F12.
    tonyb Posts: 33,066
    cbridle wrote: »
    vmaxer wrote: »
    all depends on your budget, if your looking for something in the same price range, stay with what you have. Personally though, for surrounds and center, in HT applications, it's fine. Music though is another story and I might try another cable for the front left and right.
    For cheap, Gregg Straley Reality cables offer a well balanced sound for not a lot of coin. Someone here just picked up a 6 ft pair for 75 bucks, so you don't need to break the bank to try new stuff.
    Better...Mit shotgun S3 speaker cables. If you can't tell a difference with these cables, as an old forum member used to say....I'll eat my flat hat.
  • concealer404
    concealer404 Posts: 7,440
    vmaxer wrote: »
    You guys sure like to care about what others think a lot, don't you?
    Just tired of the trolls, I am willing to bet on my actual experience, not what can be read on the net.
    No, i get it. Part of why i took a hiatus from this site. "Good" to see that the eternal debate is still alive and well.
    My original comment wasn't necessarily directed at you, btw. I hear a difference in cables (sometimes large... Ben's silver cables made my setup sound like it was broken), but i just don't care enough if any other people hear a difference to start the discussion. I'll engage, as you have, but if someone feels the need to post a 3 part novel on why swapping cables can't affect your personal enjoyment of your stereo, then they just get ignored, because how do they know?
    I don't care if it's placebo effect.
    If i enjoy the perceived differences that cables make in my setup, then it's scientifically disproven that i can hear a difference, does my increased enjoyment magically go away?
    No.
    Delicious snake oil is still delicious.
  • ukcolin99
    Thanks tb I want to spend enough (on the fronts) that I am bound to hear a difference if I can't hear any difference, I can stop worrying about it. Thinking the MIT's are the way to go, would u still bi-wire MITs?
  • tratliff
    tratliff Posts: 1,763
    kevintomb wrote: »
    I think the general consensus is to simply bash anything fairly low priced, and anything that is AVR.
    I have owned about a half dozen receivers over the last several years, and on a whim bought an entry level Sony AVR a few years ago, for my one home threatre set up and expected it to sound like crap after reading comments in a few forums.
    To my surprise it sounded quite good. In fact all the bad comments I had read, turned out to be mostly not true.
    I still like my one HK from 1981, but honestly it cost 219.99 at the time, which was a decent bit for a 20 WPC basic receiver.
    But I got my sony for $169.99 on sale, and it does a lot more, and still sounds fairly good.
    Not perfect mind you, and not the final word on anything, but not even close to as bad as how some describe them.
    I think this quote, from another thread, might help us understand the level of equipment that our friend Kevin might be using. I NOW understand all his comments.
  • BlueFox
    LOL. Deja Moo. Good one.
  • tratliff
    Keep dancing..... We have been exposed to some of the equipment but nothing worthy of a discussion.
  • vc69
    vc69 Posts: 2,500
    tratliff wrote: »
    Yeah, that explains a lot.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • vcwatkins
    vcwatkins Posts: 1,993
    kevintomb wrote: »
    My main media is 128kbps MP3, and Cassette and low quality streaming.
    I am running some Sound Design speakers from a 3 piece system from the 1980s.
    My panasonic thrusters are still belting out the tunes!
    Okay, clearly trolling. Added to ignore list.
  • vc69
    vc69 Posts: 2,500
    kevintomb wrote: »
    I think the point here is that you are expressing your opinions among a group of people that aspire to a high-fidelity listening experience. You clearly do not. Which is fine I suppose, but totally invalidates your input regarding such matters and makes your input unwelcome and inappropriate.
    If fidelity is your goal, why not come clean and tell us what your reference system is?
    I don't necessarily disagree with some of your points, but I would like to know what your baseline for fidelity is. Judging by the above quote, and the previous one from @tratliff, you have a low bar.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • ken brydson
    kevintomb wrote: »
    vc69 wrote: »
    tratliff wrote: »
    That explains A LOT!
    tonyb Posts: 33,066
    I for one don't agree, but your certainly welcome to stand in the minority.
    F1nut Posts: 51,686
    I think we can at least now partially agree, though, that speaker cables falls into that realm.
    That would be a big, HELL NO WE DON"T.
    tonyb Posts: 33,066
    LOL.....ya know, for someone with "no dog in this fight", he certainly wants at least some to believe in this supposed "audio myth". Put the shovel down Kevin, you won't like North Korea.
  • BlueFox
    kevintomb wrote: »
    Still trolling. It never stops.
  • headrott
    edited June 2015
    kevintomb wrote: »
    Okay guys, leaving the discussion at this point.
    It is pointless to get into a discussion of anything that is considered an "Audio Myth".
    But....but....but, you @kevintomb (and @xcapri79 ) still haven't adressed any of the questions that were asked in this thread and the ".....time of day" thread. What happened to a friendly debate and reasoning things out using logic?
    Also, you have yet to prove that speaker cables fall into the "audio myth" category. So, I believe that a majority of us do not agree with your sentiment.
  • gp4jesus
    gp4jesus Posts: 2,016
    RECOMENDATIONS?
    This thread unfortunately morphed into yet another IC/wire mudslinging thread.
    That said: lF one was in the market for bulk length inexpensive light speaker wire in the 18-20 gage range for, say, tweeters - either rewiring or true bi-amping.
    I have some Monster cable I got free about that size but appreciate other opinions.
    Thanks in advance for mature responses.
    Tony
    *all connected w/Premiere ICs
    tonyb Posts: 33,066
    BJC or Canare....but you can find great deals on the used markets too.
