Bi-Wiring, what exactly is it doing?
135678
  • BlueFox
    BlueFox Posts: 15,251
    PSOVLSK wrote: »
    How can there be "good quality inexpensive cables" if cables don't matter?
    I suspect he means things like good quality copper, good connectors, good insulation, and good construction.
    Of course, as you say, these things do matter, and there is no upper limit on the performance one can achieve with better and better cables.
    F1nut Posts: 51,763
    BlueFox wrote: »
    I believe both pair of wires have the same frequencies between the amps and speakers. The cross overs in the speakers then separate out the frequencies they need.
    Correct.
    tonyb Posts: 33,072
    For the most part, a bi-wired set of speaker cables from most any brand runs the same gauge for both top and bottom. I have seen some that will run a smaller gauge on top but I don't see the benefit there.
    I think where some may run into weird differences is when they try bi-wiring with 2 separate brands of cables, both with different measurements in their build quality.
  • CoolJazz
    CoolJazz Posts: 572
    BlueFox wrote: »
    Same frequencies, but when the impedance climbs from the crossover, the current is what is effected and where the differences may start to occur.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • ukcolin99
    ukcolin99 Posts: 286
    Thanks to everyone for their input, I started this thread with a quote from the Polk Quick Start Guide I received with my new 705's, refurbished 703's & new 706c. Here's a little more from the one page (in English) document: "and one set of (usually heavier gauge) wires to the lower terminals." Surely Polk would not include the statement (my words) "Bi-wire is better & connect heavier gauge to lower terminal" if there was no benefit?
  • afterburnt
    afterburnt Posts: 7,892
    Bratwurst? As usual I cheaped out and used a can of Vienna sausages %^)
  • gp4jesus
    gp4jesus Posts: 2,019
    I cannot understand why some folks think that cables are somehow not an integral part of the rig and skimp on them.
    +1 w/in certain limits. I can't let this continue w/saying the same about the room & passive XO components.
    I scratch my head every time someone "hawks" about cables, some VERY $y, w/the original nickle-dime passive XO in the chain. Anyone remember the $8K cable thread?!
    Or replacing anything & everything to correct "brightness*" because the room has either uncovered hardwood or tile flooring, an undraped 6, 8, or 9' patio door, or, perish the thought, both. My ears thinking about that!
    I have more supportive, but moderate stuff to add about bi-wiring including, gasp(!), the results of same for a pair of dual driver subs.
    Tony
    *all connected w/Premiere ICs
  • gp4jesus
    edited May 2015
    nspindel wrote: »
    How'd I know this thread would turn into an argument about cables?
    They ALWAYS do!! Cables & ICs: the most controversial topic in AV.
    F1nut Posts: 51,763
    I mean an audio cable that advertises its directionality is just nonsense.
    There's nothing about a ground and/or shield drain that is nonsense. Geesh, you don't even know that!?!
  • BlueFox
    While your post about directionality might be accurate, without posting a link so that it can be read in context, the post is not very useful. It could be completely made up.
    However, based on what was posted, it does seem reasonable that a cable could be better for audio in one direction versus the other. Whether it would be worth paying extra for is another matter.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited May 2015
    BlueFox wrote: »
    Bottom of page 10:
    http://www.audioquest.com/pdfs/aq_cable_theory.pdf
    And I agree, it sounds like they just made most of it up.
  • gp4jesus
    Nightfall wrote: »
    Why trust your ears? Useless things they are, right?
    What a novel concept?!
  • PSOVLSK
    PSOVLSK Posts: 5,380
    edited May 2015
    afterburnt wrote: »
    Underrated :D:D:D
    My question to the cable naysayers: Do you really think there could be a multi-million dollar industry that's been around for years if their products didn't work? Seriously??? Multiple companies can sell products that do absolutely nothing and somehow they stay in business?
    I have lots of other very simple questions, but I'll start here.
  • gp4jesus
    In my experience lower impedance and/or more reactive loads "like" heavier wire.
    nbrowser wrote: »
    RTiA7, HK 3490 standard wired... ...two pieces of 12 gauge... ...hear a difference, better attack; bit better bass
    Not surprising. 4 ohms below 125hz - w/lower impedance, size (gage) matters more.
    nbrowser wrote: »
    better top end.
    ? How so?
    nbrowser wrote: »
    Second power source HCA-1200II... ...more noticeable... ...low end gained some weight over single wiring... ...it IS power dependent as well.
    Again not surprising.
    The P'sound thumps the HK w/juice! Higher current, more (8ohm) power & 4 ohm rating w/even more power. Important points given 4 ohms below 125hz
  • CoolJazz
    CoolJazz Posts: 572
    xcapri79 wrote: »
    With an unbalanced RCA cable, the shield with or without a drain wire is typically connected to the RCA sleeve on both ends which also carries the signal on both ends. The sleeve on both ends is connected to a grounded chassis. This actually forms a Faraday cage around the RCA tip (hot) connection to reduce RF noise. There is really no need for an extra drain wire connection. Connecting the shield on one end can increase RF noise by acting as an antenna.
    A terrible concept! Unbalanced done with coaxial style cable is common maybe but not the best way.
    It should have two conductors internally. One for hot and one for return. The shield should be used as a drain. It should be connected only to the output end, as it's lowest impedance and therefore least likely to have the drained signal impressed upon the audio.
    Unbalanced done this way can be successful in intensely hostile for audio environments.
    Sometimes you'll see the foil used with a drain wire physically adjacent to the foil, to do the same thing. But then many find that technique of Belden's to simply not yield the best audio results. Even though it fits with their 'RLC is the only thing that matters' beliefs.
    The copy and paste answers fail yet again when measured against the real world.
    CJ
  • WilliamM2
    PSOVLSK wrote: »
    Seriously? Apparently you haven't heard of homeopathy, a 7 billion dollar a year industry. Magnet therapy alone accounts for over 1.5 billion. People believe all kinds of nonsense.
    http://nationalpainreport.com/study-finds-copper-magnetic-therapy-waste-money-8821693.html
  • gp4jesus
    Hard to deny Psovlsk's point. I completely agree w/ Nbrowser: try it! Have fun along the way.
    I bi-wired a pair of dual driver subs by cutting the original single 10 ga run in half NOT EXPECTING a change! Had to drop the LP drive several dB - EVERYTHING sounded fat!
    So bi wire naysayers, mo' bigga, mo' louder when it comes low impedance (3 ohms!) bass sources. I'm sure that applies up to top of the bass register, say ~500hz.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2015
    cbridle wrote: »
    The Polk Quick Start Guide that came with my 703's, 705's & 706 states "Bi-Wiring can provide noticeable improvements in the overall transparency of your loudspeakers.
    If the speakers are designed so that best performance is achieved if the high frequency and low frequency parts of the crossover are powered from separate wire branches, and if your gear is resolving enough, then the lowering of electrical noise due to bi-wiring can result in audible improvements in sound quality.
    It is similar to the concept of running dedicated AC circuits in order to reduce the noise from devices on one circuit affecting devices on another circuit. All of the AC circuits in a house are fed from the same tap from the power company, but running separate circuit lines from the same current source results in noise isolation benefits. Similarly, isolating low power treble signals from higher power, higher noise content bass and midrange signals can result in cleaner, more detailed sound.
    Running a single pair of speaker cables to a speaker results in the amp "seeing" a single circuit with a single complex load at the end. Running a pair of speaker cables to the low frequency section of the speaker and a second pair of cables to the high frequency section results in the amp "seeing" two different circuits with two different complex load at each circuit end.
    kevintomb wrote: »
    To answer the first bolded part.
    A cable has NO soundstage at all. Nor separation of instruments, placement etc. '
    It conducts an alternating current signal.
    It will either conduct the signal fully intact or degrade it some minimal amount.
    The rest is sales talk.
    You are correct that a cable, or any other audio component does not have a sound stage. Sound stage is a psychoacoustic phenomenon that occurs in the brain.
    However, the electrical performance of a cable can alter the stereophonic perception of sound stage, imaging, and image weight.
    kevintomb wrote: »
    All facets of alternating current can be fully measured, at ALL levels down to below human hearing.
    Sorry it really is that simple.
    There is a lot that is unknown pertaining to how to correlate measurements to perceived audio performance.
    If cable science were really that simple, telecom companies would not have invested billions over decades in cable research. Bear in mind that telco systems primarily transmit a very band-limited range of frequencies for voice. They are not primarily concerned with transmitting complex a complex signal like music. Nevertheless, telco research has resulted in cables with different dielectric properties, different twist geometries, and different copper formulations in order to optimize voice signal transmission. AT&T at one time owned a cable factory in Norcross, Georgia that manufactured cables to their specifications. If "wire was wire", they just would have bought bulk generic cable from outside vendors.
    kevintomb wrote: »
    Not everything alters the sound. That is a myth also.
    Not everything alters the perceived sound, but every thing has a measurable effect on the electrical signal passing through it.
    kevintomb wrote: »
    SOME and even many things alter the sound true, but not truly everything.
    The guys that design all this stuff we listen to, truly know what matters or does not, not the marketing claims.
    Well, the OP started off with a quote from his speaker manufacturer that recommended bi-wiring. Last time I checked, Polk doesn't sell speaker cable. Therefore, if Polk advises that their speakers may sound better with bi-wiring, I am inclined that this may be true in certain situations.
    cbridle wrote: »
    No, they would not.
    WilliamM2 wrote: »
    Bottom of page 10:
    Copper wire, depending on its composition and on how it is drawn, can have different mechanical and electrical properties (directionality) in one direction compared to the other.
    The concepts discussed in the AudioQuest Cable Theory paper are backed by solid science. Again, I would refer you to telco research, most notably that of AT&T Bell Labs, on the subjects of dielectric absorption, twist geometry, copper purity, and directionality. If you go to the IEEE Xplore website, you can search on these key words and find references to many peer-reviewed engineering journal papers on these topics. For example:
    "Murray, H., "Characterization of copper-beryllium alloy C17510," Fusion Engineering, 1991. Proceedings., 14th IEEE/NPSS Symposium on , vol., no., pp.280,283 vol.1, 30 Sep-3 Oct 1991"
    Abstract:
    "The BPX (Burning Plasma Experiment) toroidal field coil conductor is fabricated from plates of C17510, a copper-beryllium alloy. Results of tensile characterizations of this alloy at room temperature and liquid nitrogen (IN2) are presented with room temperature fatigue results at R=0.05. The R=0.05 characterization data represent the constraint on the design curve of stress amplitude versus cycles-to-failure. Data are also presented from precision, four-wire electrical conductivity measurements. These measurements include samples of material extracted from key process steps of the C17510 manufacture and span the temperature range of IN2 to 300 K in increments of 25 K. The grain structure of the material is also reported for key process steps and material orientations. The directionality of key properties is discussed."
    By the way, the electrical and mechanical properties of beryllium copper, as explained in the paper cited above, provide a scientific basis for why higher-end audiophile grade AC receptacles, such as the PS Audio Power Port Premier and Oyaide R1, use beryllium copper rather than the ordinary tough pitch copper used in regular residential receptacles.
    F1nut Posts: 51,763
    That said there are some here that buy into that explanation and believe a bag of charcoal on top of a speaker can improve its sound.
    Once again, your reading comprehension needs serious work. The member who posted about the coal states that it did not make a difference when placed on top of the speakers.
  • DarqueKnight
    edited May 2015
    xcapri79 wrote: »
    The amp doesn't keep track of separate wires. The amp sees the pretty much same complex load with two connections at the same amp terminals as it sees for a single connection at the same amp terminals as long as sufficiently large conductors are used.
    I didn't say the amp keeps track of separate wires. I said the amp (source) becomes connected to two different complex loads with two different impedance characteristics when you bi-amp. In other words, one circuit loop with one impedance characteristic is replaced with two circuit loops with two different complex impedance characteristics. I further said that such isolation can reduce electrical noise just similar to putting different household electrical devices on different AC circuit branches.
    xcapri79 wrote: »
    The amp is a time varying multi-frequency source and the currents from the amplifier will flow into the speaker load in accordance with Ohm's law, and Kirchoff's current and voltage laws. The speaker essentially operates based on Faraday's law of induction. All these are well understood scientific and engineering concepts.
    Again, my point is that splitting a complex, reactive, electrical load into two parts and placing each part on a separate circuit branch is not electrically identical to the same load combined on a single circuit branch.
    xcapri79 wrote: »
    Telco companies are running wires over hundreds of feet if not miles and are involved in numerous commercial, industrial and military applications. The engineering design requirements are different for those applications vs consumer audio interconnects. It is ridiculous to extrapolate extreme properties, requirements and applications to audio equipment based on performance.
    Actually, the signal integrity requirements between telco audio transmission and stereophonic audio are very similar. I have some knowledge of the topic because I spent 12 years in telco engineering and 4 years in telco R&D.
    xcapri79 wrote: »
    The science is misapplied and pseudo-science created to market esoteric cables because they earn tremendous profits.
    Yes, I agree that some cable manufacturer's claims are not grounded in scientific validity. There are scam artists in every field of commerce. However, you make yourself look like someone on a hysterical witch hunt by claiming that all high performance audio cable manufacturers are peddling snake oil.
    tonyb Posts: 33,072
    You guys are wasting your breath. The only thing you'll hear from X is bogus reasons why he WON'T try anything. Which imho, is ok if he's happy where he's at in his musical enjoyment.
    However, others may not be, and that's the whole point of discussing audio related topics or to further your basic knowledge of all things audio.
    Which then begs to question, why are you even here X ? You seem satisfied with where your at, obviously you know more than others....in your own mind anyway, whats the point of your membership then ?
  • skrol
    skrol Posts: 3,450
    BlueFox wrote: »
    Correct.
    Yes, but wouldn't each pair see a different load impedance given the same frequency (except at fc)? Yes, the same signal is applied to both pairs but the signal flow is going to be different through each pair as dictated by the reactive impedance of the high frequency network and the low frequency networks in crossover and the drivers themselves.
    As the wire pairs are an RLC network, you have an RLC network for the high pair in parallel with the mid and tweeter XO and mid and tweeter drivers. Then you have an RLC network for the low pair in parallel with the woofer XO and the woofer driver. The question seems to be, is there a change in the signal quality (shape and/or amplitude at various frequencies) due to the cables or is it simply a matter of reduced impedance for the signal going to the highs and to the lows?
    I should try to simulate the difference between single and bi-wiring in PSpice, though I haven't not had much success in finding such differences.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,450
    I think DarqueKnight is explaining what I am trying to say a little better.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • BlueFox
    In regard to cable directionality, there is a discussion on another forum about it, and this is what Caelin Gabriel of Shunyata said.
    As is the case with many things - the answer depends.
    Gary is right in that the signal is an alternating voltage so the current simply reverses direction. This means that whatever end of the cable is connected shouldn't matter. However, some speaker cables are intentionally designed with asymmetric conductors. That means that the physical size of one conductor is larger than the other. And some cables may have a different winding direction for one or the other polarities.
    Some amplifiers push and pull current from both the positive and the negative terminals while other amps ground the negative terminal and only push and pull current from the positive terminal.
    With an asymmetric cable and a grounded negative terminal amp it will matter sonically which way the cable is connected.
    If a speaker cable is symmetrically made there will be no difference when the cable is first connected. However, as the cable burns in it establishes directionality meaning that you should hook it up in the same direction after that. So the arrows on the cable are simply a convenience for the user to connect the cable the same way.
    The other reason there are arrows is that customers demand to know the direction to hook up the cable. We only make symmetrically designed cables and in the past did not put arrows on the cable. But customers wanted to know which way to connect them even though we repeated said that it didn't matter. It is easier just to put the marks on the cable.
    http://www.audioaficionado.org/cables-galore/31622-speaker-cable-direction.html#post700472
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited May 2015
    I'm no electrical engineer or metallurgist or anything of that sort, but I'm a bit of an "armchair philosopher" and erstwhile logician.
    From my perspective, DK has it right: "Sound stage is a psychoacoustic phenomenon that occurs in the brain."
    As philosopher George Berkeley put it, "Esse est percipi" -- "to be is to be perceived."
    If the hearer perceives a difference in sound from differing "gear" -- including cables -- then there is a difference for that perceiver. If the listener hears a difference, then for that listener the difference exists.
    It doesn't matter whether anybody else thinks such a difference in perception can be explained with differences in materials used or engineering principles applied.
    Differences in materials or engineering design may or may not explain perceived differences -- nevertheless, these differences do exist in the "psychoacoustic phenomenon that occurs in the brain" of the listener.
    I would not presume to tell a listener what he or she experiences in his or her brain, although it is clear from the above thread (and many others) that some people believe they know what goes on in any listeners brain better than listener himself or herself.
  • drumminman
    drumminman Posts: 3,396
    xcapri79 wrote: »
    He actually believed in it enough to actually try it. That was enough for me.
    He said that he heard a difference when he placed this bag of charcoal on top of a bag of treated crystals on his PA transformers, and on his balanced isolation transformers that his power amp and linestage are plugged into, as well as one on top of a filtering choke. Ok.
    Here is the full humorous post.
    drumminman wrote: »
    I frequent Audio Asylum mainly looking at the tweaks and cables categories. There's a guy who posts quite a bit in the former named Uncle Stu, and he thinks outside the box. Way outside.
    I've tried some of the things he describes, usually with good results, and here's the latest.
    Charcoal. You can read the thread here: http://db.audioasylum.com/mhtml/m.html?forum=tweaks&n=185942&highlight=charcoal+tweak&search_url=/cgi/search.mpl?forum=tweaks&searchtext=charcoal+tweak
    What he did was take charcoal briquettes (think Kingsford), put them in a plastic bag and place on top of his floor standers. The results he described were intriguing, so I thought what the heck. It's cheap, reversible, no downside really.
    So I bought a bag and used some zip lock bags I already had. Total cost $8. I filled a large ~ 10' x 10" bag with briquettes and used a hammer to break them into smaller pieces. Initial placement was on top of my 2.3TL's, and the results were: couldn't hear any difference.
    Next I tried placing the bag on top of a bag of treated crystals from Alan Maher that had been placed over the transformers of my PA. Didn't like what I heard. The sound character changed from being open to somewhat pinched, not markedly so but enough to remove the charcoal.
    Then I removed 2/3 of the charcoal from the bag leaving around 6 oz or so and put it back in the same place. Slight change for the better. Inner details of instruments were a little more resolving, slightly more realistic tone, vocals maybe a little more fleshed out.
    Then I took a several more bags and placed one each on the two larger balanced isolation transformers that my power amp and linestage are plugged into, as well as one on top of a filtering choke at the IEC connection for my Oppo, which is used as the source. Improvement was more of the same. It does seem like the improvement in sound quality has continued as the charcoal has remained in place.
    Listening this weekend has been almost a revelation. Before this tweak I would characterize the sound of my system as very clean, well balanced throughout the audio spectrum, extremely easy to listen to at high volume. The charcoal has potentiated the best attributes.
    Sounds crazy I know, but it's so easy - and cheap - to try. Love to hear of others experience with this.
    Please do not reply to this post with negative comments if you haven't tried this or have no intention of doing so.
    Cheers and happy listening.
    And of course, you're too close minded to try anything that can't be explained with scientific measurements. Try not to be so dogmatic and be willing to test your assumptions, especially of a tweak is inexpensive and easily reversible.
    Or don't you trust your ears?
  • BlueFox
    Actually, he does not 'listen' at all. Otherwise, he would not constantly be spouting nonsense.
  • skrol
    skrol Posts: 3,450
    This is basically what you are doing circuit wise when you bi-wire vs single.
    Results likely depend on things cable lengths, speaker impedance (high drivers and low drivers), amplifier impedance and damping factor to name a few (placebo and psycho stuff aside). Perhaps you would get the same results by going with a heavier AWG? Try it and see what I like is my plan.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    msg Posts: 10,452
    skrol wrote: »
    cool. did you do this in PSPICE?
  • skrol
    skrol Posts: 3,450
    Yes, I haven't simulated it yet. I had to get back to doing real work that I get paid for.
    Stan
    Main 2ch:
    HT:
    Other stuff:
