Are you READY for some FOOTBALL!!!
12324262829153
  • bikezappa
    bikezappa Posts: 2,463
    Need to know both initial pumping temperature and pressure to know change in pressure as your formula states. I believe we are in agreement. Would also like to know the accuracy of pressure gauges.
    There may not even be a issue here.
    nooshinjohn Posts: 25,900
    bikezappa wrote: »
    HEHEHEH HEHEHE... he said PUMPING! heheheh
  • bikezappa wrote: »
    This topic maybe a red herring. If you do the calculations based on the gas laws, PV=nrT and know the temperature/pressure of the football when pumped and the temperature during the game, 51F I think, you can get close to a 2psi difference in pressure change. Also I have worked with PSI pressure gauges at work for 40 years and they are not very accurate at low PSI pressures under 30psi. These gauges have a +/- 1psi accuracy.
    What's this all about then?
    Publicity?
    The other team may have pumped the footballs at a much lower temperature. Need to know first pump pressure and temperature.
    Not necessarily. I get what you are saying, but the balls were checked by a game official prior to kick off. Now I do not know if the balls were checked indoors at room temp. or outside at said 51 degrees and whether the ball had time to properly acclimate before being checked, but in either case the balls passed inspection. Therefor, assuming the official did his due diligence then the psi was likely altered afterwards. I agree with you the ambient temp can make the air in the ball more dense and affect pressure but the amount of change ,as measured in psi, is dependent on the proportion of temperature change as well as the volume of air within the container. A football being a small container with relatively low pressure wouldn't be affected a great deal given a temperature change of 25 degrees or so. Also there are plenty of pressure gauges that are accurate to +/-.01% at any given pressure.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2015
    Polkie2009 wrote: »
    I haven't been following every single detail of this case, but it seems like after the Seahawk's player intercepted the pass , didn't he immediately notice the ball was slightly deflated and walked off the field with it? What about questioning the center for the Patriots who was handling the ball(s) also.
    The one detail you didn't follow was that the Patriots were playing the Colts.... :)
    Garage | Polk Monitor 5B's
  • bikezappa
    jeremymarcinko
    I understand what you are saying. It would be very interesting to know what type pressure gauge was used, the 3" dial type are not very accurate. It would also be very interesting to know the temperature of both team foot balls when they were first pressure tested. And it's possible the pressure gauges were damaged. I know this is possible because I have worked with pressure gauges for 40 years.
    What is the NFL doing to investigate? Where are the footballs and pressure equipment kept now? Could the footballs leak? All I hear are opinions and little data.
  • bikezappa
    Ken
    Now that was funny.
  • mmqb.si.com/2015/01/22/deflategate-video-how-nfl-officials-check-game-ball-pressure/
    Here you go, the ball pressure check procedure. Indoors with a crap $12 gauge.
  • bikezappa
    jeremymarinko
    Amazing you found that. Those 2" gauges really suck and are not very accurate.
  • kevhed72
    kevhed72 Posts: 5,139
    Are we talking about footballs or testicles at this point (sorry, just wanted to check if the forum considers balls a dirty word in this context)
  • Polkie2009
    Polkie2009 Posts: 3,834
    Polkie2009 wrote: »
    Someone please slap me silly. I realized a few minutes after I had turned off my computer that I wrote Seahawk's and I had to leave for a few hours,lol.
    tonyb Posts: 33,069
    kevhed72 wrote: »
    I'd say both, judging by the responses of a pretty irrelevant event. Even the talking heads on sports channels are calling it their "Watergate"....wtf ? People are just idiots...well paid ones to boot.
    tonyb wrote: »
    kevhed72 wrote: »
    Imagine if the lame-stream media took questioning and investigating our leaders as seriously as they are this red herring...
    gudnoyez Posts: 8,159
    Not liking either team the only reason I want the Seahawks to win is to see Pat Williams get a super bowl ring. I must say it sure took a lot of ex Vikings for Seattle to win the first one, it will take another one to win a second one. I hope Pat gets one he deserves it he's a class act.
    Pat Williams deserves a ring for sure. He also said he wants to retire a Viking... I hope he gets his ring.
    F1nut Posts: 51,719
    tonyb wrote: »
    I've come to the conclusion that Polk Audio is a Patriots fan. After experiencing this new forum, they both seem to play with deflated balls.
    WAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • Dabutcher
    Dabutcher Posts: 2,604
    1. game was a blowout! Colts sucked spring water that day.
    2. If there was an issue w balls. Officials should have noticed something?
    3. Tom Brady is setting an NFL record by being the only player to play in seven Super Bowls.
    4. This will be the highest rated Super Bowl ever! Why should the NFL care?
    5. Go Bears!
    6. WW3 is about to jump off. Its just a game!
    7. Peace
    I just saw some Marshawn Lynch highlights... what a douchenozzle this guy is. If ever I needed a reason to be anti-shehawk, I have one now....
  • gce
    gce Posts: 2,158
    I'm having a had time picking which team I want to win. I guess it would have to be the team I hate the lest. LOL
    Anaheim Hills CA,
  • Msabot1
    Msabot1 Posts: 2,098
    Too much hype over nothing...all the BS hype has ruined the meaning of the game...
  • dromunds
    dromunds Posts: 10,117
    I'm not even watching.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    When you remove the emotions from the game and all the distractions, this really should be a great game. I am not a fan of either team at all, but am hoping for a good game.
    tonyb Posts: 33,069
    I'm just gonna watch for the commercials.....
  • Msabot1
    Maybe Perry will have a wardrobe malfunction.....best play of the game!!
    tonyb Posts: 33,069
    Msabot1 wrote: »
    We can only wish. Not a fan of anything she sings though, but she does have a rockin' bod.
  • pongshi
    pongshi Posts: 376
    As a fan of the team that was victimized by the "tuck rule" I sincerely hope the Patriots lose, unfortunately, I have a feeling New England will win :(. Go Seahawks!
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
  • gce
    gce Posts: 2,158
    tonyb wrote: »
    There ya go...now I have a reason to watch!
    Anaheim Hills CA,
  • Moose68Bash
    Moose68Bash Posts: 3,843
    DSkip wrote: »
    gce wrote: »
    tonyb wrote: »
    Do you? They haven't been that great during years past.
    Can you believe that they are even previewing the commercials for days in advance of the game?
    What has the world come to?
    PETA already had a couple pulled down...
  • gce
    gce Posts: 2,158
    So Katy Perry shows up in Arizona and they have a press conference. The first question they ask her she answered "I'm just here so I won't get fined." LOL
    Anaheim Hills CA,
