Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
So how's it sound?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Neil,
So far its been playing for a couple of hours, and it sounds better than the 670VA Toroid of Maryland transformer that it replaced. It has added depth and clarity to the rendering, and it is clear that my normal listening level for my preamp will be on 16-18 rather than 22-24 (on a scale of 0-59).
More later.
Thanks again for pulling this together!
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
I have a question for those in the know. I've done a bit of poking around here and I haven't found the answer yet. Correct me if I'm wrong but there's out of phase signals from the left speaker going to the right dimensional drivers and vice versa for the sda effect. I'm wondering just how the speakers get these out of phase signals when it's isolated from the opposite speaker's signal with the dreadnaught?
The out of phase signals are passed from one speaker to the other through inductive coupling in the transformer. What the transformer prevents is an electrical connection between the speakers which would cause an electrical short circuit with non common ground amps.Proud and loyal citizen of the Digital Domain and Solid State Country!
I am still waiting delivery. I leave out of town next Tues morning, not returning till late Friday afternoon. No doubt with my luck, delivery will attempt 3 times while I'm gone and send back ( I assume signature required?) May have to touch bases with A-L to see where my delivery is at and possibly make arrangements if not too late.2.3TL's - Living Room
CRS+'s (4.1 TL's) - Office
SDA1C's - Famdamly Rm
SDA1C's - Master Bedroom -
Thanks once again DK. I had to google "inductive coupling" to get a grasp on exactly what that is and now I have a pretty good idea on how the dreadnaught works.DarqueKnight wrote: »The out of phase signals are passed from one speaker to the other through inductive coupling in the transformer. What the transformer prevents is an electrical connection between the speakers which would cause an electrical short circuit with non common ground amps.
One more question if you don't mind. Why should the dreadnaught make the speakers so much easier to drive? It's quite noticeable that to get the same listening levels as pre-dreadnaught levels it takes a much lower setting on the volume knob. My amp puts out the same wattage at any impedance so it's not lowered impedance that's causing the increased sensitivity in my case. I'm still in awe of the overall upgrade the dreadnaught has given me and I'd like to understand a little bit better just why it's having such a profound effect
I, too, understand the theory behind how the Dreadnought works and, therefore, solves the problem of using non-common ground amps with SDA speakers.
Yet, the Dreadnought in my system that uses a common ground amp also delivers much higher sound quality with the Dreadnought v. the standard SDA interconnect that came with my 1Cs.
Moreover, going from the 670VA toroidal transformer to the 1000VA transformer also yields a palpable improvement in sound quality.
This part of it, I don't understand.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
I picked mine up from the post office yesterday and can't wait to get it hooked up! VR3 mod binding post plates with speakon connectors were installed this morning which means I'm totally without SDA effect until the dreadnaught is completed.
Thanks again to all who made this possible. ____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
You've got a great incentive to get it built! Have at it!
motorstereo wrote: »Why should the dreadnaught make the speakers so much easier to drive? It's quite noticeable that to get the same listening levels as pre-dreadnaught levels it takes a much lower setting on the volume knob. My amp puts out the same wattage at any impedance so it's not lowered impedance that's causing the increased sensitivity in my case. I'm still in awe of the overall upgrade the dreadnaught has given me and I'd like to understand a little bit better just why it's having such a profound effect
The ground plane of an amplifier contains a lot of electrical noise. The Dreadnought provides isolation from that noise, therefore the signal sounds apparently louder, although, if you measured the pre-Dreadnought and post-Dreadnought signals with a sound level meter, they would measure the same. These analogies illustrate the concept:
Assume the pre-Dreadnought signal is at a level of 85 dB and that the signal contains 90% music and 10% noise. If the installation of the Dreadnought results in a signal that is 98% music and 2% noise, yet still at 85 dB sound level, the music will sound louder because you are hearing 8.8% more music and 80% less noise. Therefore, you find yourself turning the volume control down to "get back to" the sound level you were used to.
Another way to look at it is a conversation in a noisy, crowded room. If everyone else in the room stops speaking or if they lower the level of their voices to whispers, the person speaking to you will sound louder even though they are talking at the same level as before. The sound level that was adequate for a conversation in a noisy room is now unnecessarily, and perhaps uncomfortably, loud in a quiet room.
Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight,
As always, a great and clear explanation.
I think you've also explained the reason the SQ improves -- i.e., less noise in the signal, hence clearer music.
Thank you.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
I understand how the isolation transformer is needed with non common ground amps. That makes sense.
I have no doubt that the transformer does work to improve the quality of sound because you guys say it does. But, it seems odd that an isolation transformer can do a better job of connecting two speakers together than a straight piece of wire. It also seems odd to me that you can add a much much longer length of wire to the circuit that ties two speakers together (the windings in the transformer) and the volume of the speaker will increase. I'm not an electrical engineer but that all seems very odd to me.
Also, Anytime I mention installing a high quality switch in a circuit for some reason I hear "Don't do that. You don't want to add anything extra that might cause distortion." but adding a transformer seems to be OK. Doesn't that seem inconsistent at best?- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
DarqueKnight gave a good explanation of how the dreadnaught works while I was typing and it makes sense. Thanks for explaining!
Thanks once again Darqueknight for answering another one of my questions in a way that I can now understand how this works.
If you don't mind I have yet one more. Since the ground plane of an amplifier has so much noise this now has me wondering. Would it be beneficial to add another one or possibly 2 more dreadnaughts to the negative wire going to the speaker? Would this reduce what little noise must be left yet even further or would this simply be overkill and not noticeable? -
motorstereo wrote: »Since the ground plane of an amplifier has so much noise this now has me wondering. Would it be beneficial to add another one or possibly 2 more dreadnaughts to the negative wire going to the speaker? Would this reduce what little noise must be left yet even further or would this simply be overkill and not noticeable?
Polk speakers designed for use with the AI-1 have the effects of the transformer accounted for in the design of the speaker. If you were to add more transformers, you will be exceeding the speaker's design and performance parameters in a bad way.
Also, a transformer is a four terminal device, meaning there are two input leads and two output leads. Putting a transformer in series with the negative speaker wire would mean that only one input lead and one output lead could be used and you would have an incomplete circuit.
Once again I thank you for your easy to understand explanation Darqueknight. I'll leave well enough alone then and enjoy the huge upgrade the dreadnaught has already given me.
I'm speechless. I can't believe how good this thing sounds and it doesn't even have 5 minutes on it yet.____________________________________________________________
Direct quote from the wife: "It sounds so much more detailed. Where did you put it and what does it do?"
Tell her it's magic"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Give it some time..........it gets even better. I'd have to rank this one as one of the very best mods I've done to mine and quite possibly the best ever. I've made electronics upgrades in the past that didn't have near the effect that the dreadnaught has. -
drumminman wrote: »Tell her it's magic
It is magic!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
What are folks using for feet on the cases?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I use through-hole Rubber Feet on the ones I make, others have spiked them. You can buy the stick-on Rubber Feet too, if you never intend to move it. I don't like using that type, because they tend to shift around, and the adhesive isn't usually that strongHome Theater/2 Channel:
dhsspeakerservice.com/ -
I have spikes on one Dreadnought and through-hole rubber feet on the other.
The one with spikes sits on 3/4" MDF on am industrial shelf system that holds my heavy gear in the basement.
The one with rubber feet sits on a wire shelving system whose shelves I shall one day cover with 3/4" MDF. Then, I shall also replace the rubber feet with spikes.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
I used spikesGood music, a good source, and good power can make SDA's sing. Tubes make them dance.
Picked up my A-L xformers today from the Post Office after finding the weathered USPS notice that had blown in to the landscaping. Have most all parts ready for assembly. Need to find time to get assembly done.. work hasn't been kind.. but I need to burn a bunch of vacation before year's end so should find time to 1) assemble the dreadnoughts & 2) assemble the 2C's with all the upgrades during this last two months of the year! Happy Christmas to me!2.3TL's - Living Room
I presently have my dreadnaught sitting on it's own shelf and on it's side. Is this the preferred resting position or should I spike it on the wider and more stable bottom?
motorstereo wrote: »I presently have my dreadnaught sitting on it's own shelf and on it's side. Is this the preferred resting position or should I spike it on the wider and more stable bottom?
Some people hear an improvement in sound quality with the Dreadnought on its side. If you do not hear a difference between the two orientations, then there is no reason to put it on its side.
Mine has made a huge difference. It has about 5 days of time on it now.
Great upgrade to say the least!!!"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
It's surprising how much of a difference 3 more days made to the sound quality.
It think it should be almost be fully burnt in by now.
My tenant just loves me... My rigs been running 24/7 plus some.
DarqueKnight you nailed this mod dead on, plain and simple... Great job!!!
Now I just need to save up for the next group buy. I picked up some 3.1TL's and it totally transforms the sound of those also.
