Vintage Monitor and SDA Speaker Deals
With the proper modifications, the original 2s can be quite formidable. The Dimensional tweeter should be disconnected.OldSchoolPolk wrote: »SDA II listed on Raleigh's CL for $100. No affiliation, unless of course I buy them.
http://raleigh.craigslist.org/ele/4619792981.html
But there's my question. Don't know much about SDA's and this seems too good to be true. I can't keep up with all the SDA models. Are the SDA II a lower end iteration?
Do the twin tweeters smear the image, do the mids have to be balanced between SD and non-SD. Thanks for the insight.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks WMG. Would've never thought of just disconnecting the Dtweeter. Would disconnecting them change the impedance the crossover sees?
Anything else to check when I go look at them? Ad did not mention the SDA cable so don't know if he has it. Assuming all drivers work, even if they are a little beat, the price seems right correct? Of corse there's the pursuit of a common ground amp to power them. Until I get the proper amp I can power them w/ non common grd amp w/o using the SDA cable, correct?
I've emailed the OP but no response yet.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
They look pretty decent, just need a good cleaning. Disconnecting the tweeter will not affect the overall impedance. You will need a amp with common ground, and it must be able to handle 4 ohms or less safely. You can use them as a stereo pair, with a non-common groundOldSchoolPolk wrote: »Thanks WMG. Would've never thought of just disconnecting the Dtweeter. Would disconnecting them change the impedance the crossover sees?
I've emailed the OP but no response yet.Home Theater/2 Channel:
Well i sure hope you get those. Thats stealing them at that price. The parts are worth more than price & those look very nice. Good LuckRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
No affiliation - but if you're local to Denver, CO might be worth a trip - http://www.shopgoodwill.com/auctions/Polk-Audio-Tall-Floor-Speakers-17436411.html - not sure of the model but I'm sure someone here will recognize!
RTi150's I have a pair - really like them. -
Looking for MW-6510's and MW-6511's ? Check this out $220 for 4 each.
Lot-of-4-Polk-Audio-MW-6510-Drivers-and-4-MW-6511-Drivers
At $27.50 each these would gone if I didn't have a stash of them already. :cheesygrin:
P.S. he's also got the passives & crossovers (early 2 piece versions).“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Polk srt System for $1750
http://denver.craigslist.org/ele/4622534449.html
I looked for some of these for a while and gave up when I got my 5's. No affilaiation.
http://myrtlebeach.craigslist.org/ele/4621767653.html
Monitor 7's for a c note.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I saw these and actually posted on FB to my friends to see who I knew in Akron area that could pick them up for me and sit on them till I could get them a ride to SC. Then the ones in Myrtle showed up. Still I need them like I need a hole in my head.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
I missed out on the pair of SDA II in Raleigh's Clist by about 8 hours b/c my original email went to his spam box. Oh well, maybe next time.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
Looks like a good deal on some SDA-1s if you are in the Los Angeles area. Pretty sure they are 1Cs. $300.
http://losangeles.craigslist.org/sfv/ele/4650309381.htmlSpeakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
GospelTruth wrote: »Looks like a good deal on some SDA-1s if you are in the Los Angeles area. Pretty sure they are 1Cs. $300.
Those look to be 1c's to me!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
A pair of project 2.3TL's in the Midwest http://www.ebay.com/itm/Polk-Audio-SRS-2-3-TL-Speakers-Vintage-audiophile-/231298513238?pt=Speakers_Subwoofers&hash=item35da773956
No affill. These don't come up very often in this part of the country, original owner ta boot. -
No Affil - while we're at it - local FL pickup those look like a good deal. Original Stands and Peerless Tweets - Mon10's for $99! http://www.ebay.com/itm/Polk-Audio-Model-10-Speakers/281409346212?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=3acfaa5fabd54609b7d839b2a587d230&pid=100005&prg=20131003132420&rk=6&rkt=6&sd=231298513238&rt=ncVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
RTA-12s. Appear to be in great shape:
http://worcester.craigslist.org/ele/4612997109.html
No affiliationHome Theater/2 Channel:
just saw these big boys in the central Jersey C/L.Whether or not a good deal I have no idea. I would prefer the brown cherry wood myself but I both can't afford them nor do I have the room. No affilliation.....
http://cnj.craigslist.org/ele/4658751341.html2chl--Adcom555~NAD1020a pre~JVC-QL200 tt~ Grado FT+1 cart~Denon 1940ci-cdp~Niles 6 selector~Samson 9 outlet surge~ DCM TF 350s~ADC 303ax~ KLH 331s-'87 Polk Audio 2Bs( dynamat, rings, 194s, VR3-xovers-gaskets,BH-5)~Signal i/c~ BJ Belden i/c~10gu BJ Belden to Polks
H/T-Toshiba AU40''~Yamaha RX-V665-Sony ce375 5disc-YDS-Dock-I-pod-Klipsch #500 spkr set w/ 8''pwrd sub-Shure Pro 240 h/p
BDRM--Nikko 6065 receiver~Sony NS300 cd/dvd~ JBL -G200 bookenders -
Crazy prices
westmassguy wrote: »RTA-12s. Appear to be in great shape:
No affiliation
My Buddy Mario would give his right arm for those, he kept emailing a dude on ebay trying to get him to frieght them to him lol and nobody would do it.
Those 12's sure do look sweetRandy-Maine
by David WMG
IDK if this is a deal or not but I stumbled across these 3.1TL's.
http://www.ebay.com/itm/Polk-Audio-SDA-SRS-3-1TL-speakers/171451477618?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=6bc6166beb2646b2ba04578654b3a010&pid=100005&prg=20131003132420&rk=5&rkt=6&sd=231298513238&rt=nc
US $400.00
No Affiliation!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
US $400.00
No Affiliation!
Thats a very good buy even at 600 given their condition.
And they are in IL near lots of the IL fella's.....
I got enough projects that I dont need to add SDA's to that list lol...
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Those 3.1's are tempting, but I don't like that area much."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
There is a guy on Ebay in. Michigan selling in three auctions his SDA home theater system. Two sets of SDA SRS and SDA CRS centers. Pricing is a little high but if a guy was to see before bidding or offering ? Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Looks like someone bought them, the auction has ended early. I seriously considered them, but a 12 hour round trip was more than I wanted to make. Hope somebody here got them.
Better prices on Craigslist. I'd be all over the first pair if I had the dough: No affiliation:
http://detroit.craigslist.org/wyn/ele/4663428656.html
http://detroit.craigslist.org/wyn/ele/4663338363.html
http://detroit.craigslist.org/wyn/ele/4663353158.html2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Mike Reeter wrote: »
You already have them... trying to keep all to yourself eh?
$1.2k with upgraded tweeters is good price.
Well, uh, you know, YES! They are a rarity for sure, I'd like to have another "backup" pair just for the heck of it.
