THe Official "Larry's Rings" waiting list
There are prices posted in the FS thread somewhere.
But the prices may change without notice, I mean with Larry's notice.
Found it: http://www.polkaudio.com/forums/showthread.php?134200-Sets-of-Rings-for-Drivers-and-PR-and-Tweeter-brackets&highlight=larry%27s+ring
That post is two years old but will give you general idea.
Under 100 posters cant read it:( -
yeah i saw that too, but i figured what the heck it cant be that bad and these puppies dont come around that often.
IDK if this is appropriate but.....You asked for them and here they are....
SDA SRS/1.2/1.2TL $118.96
SDA 2.3/2.3TL $95.36
SDA 3.1 $79.74
SDA 1C's $70.64
SDA SRS 2's $70.64
SDA 2's (3 drivers) $58.84
SDA 2B"s/studios $47.04
SDA CRS+s $44.34
Monitor 10's $44.34
Monitor 7B's/7's $32.54
If you have something else let me know. shipping is $15
All sets will come with drill templates and Black Zinc 8-32 BHCS for your drivers, and for the passives....
As always thanks...
Larry.
I'm sure there will be some changes.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Larry, you can put me down for a set for my 2B's. Thanks.
I will post a new thread in the next couple of days just to keep it in order for everyone that's wanting them, and we can keep it in order, and that will give me an idea of how many I need to make..
Quick question: On my RTA12's, when I push in the PR the midwoofers stay out indefinitely. They don't recede at all. Am I correct in assuming that I would either not benefit or that the benefit would be negligible if I added rings or hurricane nuts?
My Monitor 5's are another story, they recede after a short amount of time. Being they are set to "small" in my AVR, does that mean they wouldn't see a great benefit either?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I would like a pair for my sda 1b, i assume the 1c is the same thing. I really want in on this. I will be on the look out for the new thread, thanks larry!!
Cool Larry...
I would perhaps recommend getting this thread closed if you don't want it popping up all the time.
I would like a set of rings for the crossover plates if those are a possibility still...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The mid-drivers have to vent and they do so via the dust caps. Not sure why yours are not, but it is an opposite problem.Political Correctness'.........defined
President of Club Polk -
You may want to check if the mid drivers are original as they should be vented and air should pass after few seconds.
It should not stand out forever.
Okay so I had to double check. They do move back in, /VERY/ slightly, but after the slight movement they are still pushed out 80-90% of what they originally were. They don't go back in until I let go of the PR. Is that more normal?The mid-drivers have to vent and they do so via the dust caps. Not sure why yours are not, but it is an opposite problem.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
All four are MW6600XYou may want to check if the mid drivers are original as they should be vented and air should pass after few seconds.
It should not stand out forever.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
There is a resting position. When you push the PR in the mid-drivers move out to their maximum excursion, then slowly recede. When you release the PR it sucks the mid-drivers in to that maximum excursion, then they move back out to their resting position.Political Correctness'.........defined
Need to change my order. It's now for my SDA CRS+.
Thanks!!! -
If and when these come back to life, I'd be in for 1c's and 2b'sVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I try to log on daily and I haven't seen any new posts, please put me down for three,
TY Larry
GlennAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I'm getting close guys.
I am going to tackle the dreadnought cases first.. -
Larry,
I'd like to throw my hat in the ring for a set of monitor 5jr+ and also my srs's. I'm in no rush for the srs's though.
Thanks. Looking forward to the dreadnought box. -
I absolutely need a full set for my SDA-CRS+'s. Tweeters/drivers/passives/xovers if possible and thanks Larry!
Since I am retiring soon I will need something to do with my free time. I would ask for a set for 2.3tl's and CRS+ and 2b's. Tweeters as well.
Thanks for doing this.
NathanHome Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!! -
Need a complete set for my SDA 2B's.
Great news! -
I would like a set for my 10b to complete my up grades. Pm me if possible. Thanks LarryRec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Yes please - SDA 1C's $70.64. How do you prefer payment?- Please don't clean up my mess. You'll only confuse me.
APC 1500, Furman Rack Rider, Cambridge Audio Dac Magic Plus, Parasound P/HP 850, Adcom GTP-880, Luxman M-300, Threshold 400A Cascode, McIntosh MC2505, MC2205, MR-71, MX-113, Sony TA-3200F, Tascam 112 MKII, Sony TC-D5 Pro, Tascam CD-200, Thorens TD-147, Kenwood KT-5500, Kenwood KT-7500, Realistic Minimus Sevens, Behringer MS40s, Boston Acoustics A40s, JBL 830Ts, 'Double' Advent Loudspeakers, Klipsch KSW12 sub, Bose 901s, Polk SDA 2s, Polk SDA 1Cs -
Larry are you sending totals out to everyone or is there a thread I missed with prices? I'd like to get my payment in asap. -
I haven't done anything just yet, I decided a while back to take care of the guys in the group buy for the dreadnought. Juggling the rings and cases would have overwhelmed my PM box since we can only have 70..
Soon!! -
Soon!!
No problem! Sounds good Larry! -
Larry,
I'm already in for a set of rings for SDA1C's and 2.3's. The joy just keeps on coming. Possession hasn't occurred yet, but a purchase agreement made.... please add a set of rings for a pair of CRS+'s to my order.
In for a penny, in for a #.
Thanks much!
M_H2.3TL's - Living Room
CRS+'s (4.1 TL's) - Office
SDA1C's - Famdamly Rm
SDA1C's - Master Bedroom -
Is this still a live thread where I can get on the list? Or is there another thread that's up-to-date.
Thanks!- Please don't clean up my mess. You'll only confuse me.
There is no updated thread yet, I postponed it till I get the dreadnought cases done for the group buy members on the forum..
