Vintage Monitor and SDA Speaker Deals
1…2627293132…262
  • BKphoto
    BKphoto Posts: 409
    edited March 2014
    he needs a tape measure
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2014
    hey go over there TNHNDYMAN and tell him hey the woofers don't even work then ask him to remove one and then say they are Fakes offer him $50 for the pair LOL :-)
    BKphoto wrote: »
  • Mystery
    Mystery Posts: 2,546
    edited April 2014
    if someone needs to replace damaged cabinets.
    http://denver.craigslist.org/zip/4394359153.html
  • Nightfall
    Nightfall Posts: 10,083
    edited April 2014
    SDA 2.3TL's w/upgraded crossovers and extra midwoofers good condition $950
    http://fortcollins.craigslist.org/ele/4408988476.html
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mystery
    edited April 2014
    Nightfall wrote: »
    it's in 'For Sale' section for $900 by squeeb.
  • Bugstyvy
    Bugstyvy Posts: 119
    edited April 2014
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Pro-ject Record Player
    Sony 200 disc CD Changer
    Basic Wiring
    60" Samsung Series 8
    SDA-1.2TL
    SDA-3.1TL (unused at the moment)
  • Nightfall
    edited April 2014
    Doh! I imagine this is breaking the post rule for newbies to see the FS section then, Ken if you see this can you delete my post? Sorry!
    afterburnt wrote: »
  • Mystery
    edited April 2014
    Nightfall wrote: »
    No it's okay.
    FS section is limited to members with certain posts.
    Your post is a link to local CL ad so that's not the same thing even though it's the same speakers.
    I just wanted to inform that the seller is a polkie and has them in FS section.
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2014
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited April 2014
    Just out in todays central Jersey's C/L. These seem to be in good enough shape but from what I've learned here I think the asking price is out of bounds. 0 affiliation just cruising.
    http://cnj.craigslist.org/ele/4416737767.html
  • pglbook
    pglbook Posts: 2,267
    edited April 2014
    Definitely way overpriced! Even half of the amount he is asking would be too much!
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited April 2014
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Irrenhaus
    edited April 2014
    More SDA's SRS 2 or are they SRS for $700.00 in the Bay Area
    http://sfbay.craigslist.org/eby/ele/4437432397.html
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2014
    tygr1955 wrote: »
    These wouldn't be the same 2.3TL's you picked up in Dallas, would they? The ones with the dented dust caps?
    http://www.polkaudio.com/forums/showthread.php?160251-Got-the-2.3-TLs-home-today!&p=2037853#post2037853
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • tygr1955
    tygr1955 Posts: 45
    edited May 2014
    HTguru1982 wrote: »
    Ummmm, yes. Is that a bad thing?
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2014
    PolkieMan wrote: »
    http://www.soundandvision.com/content/onkyo-tx-sr806-av-receiver-ht-labs-measures
    You should get more WPC at 4 vs 8 ohms but distortion and heat will increase.
    That all depends on the design of the amplifier. If it was made to only handle 8 ohms then it may very well put out less wpc into 4 and possibly even be a dangerous situation for the equipment. Some that are 4 ohm compatible drop wattage into 4 ohms because they band aided it to handle 4 ohms. Putting a 4 ohm load on an amp rated for 8 ohms makes it pull more current through the transistors and can lead to a thermal mess that causes parts to burn up. it can also send a spike through to the speakers and make them toast. Remember not all amps are created equal, and if they were we would all be using the same thing.
  • xjghost
    xjghost Posts: 1,115
    edited May 2014
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • cmarks2701
    cmarks2701 Posts: 20
    edited May 2014
    Same type speakers and names on a CL ad in Quad cities IA.
  • PolkieMan
    edited May 2014
    Something strange? he even states they are "2" not 2.3
    Besides if I was selling something like that I would provide more and better pictures
    ZLTFUL wrote: »
    Seems strange to me that the first 2 pictures are most definitely 2.3s with the donut drivers and the third picture is of the back of an SRS 2...
  • xjghost
    edited May 2014
    I thought it was just cut off.
  • cincycat13
    cincycat13 Posts: 887
    edited May 2014
    More than 1 set of SDA 2.3 are labeled as simply "2"
    Here is where I got mine and they were also listed as "2" by the seller...fortunate for me. Believe the front pictures, not the label.
    http://www.polkaudio.com/forums/showthread.php?101691-Srs-sda-2.3/page2
  • PolkieMan
    edited May 2014
    Well with Polk you never know till you look deeply at two or three things to make sure :-)
  • Zentish
    Zentish Posts: 127
    edited May 2014
    Old-school polk subwoofer. Seems a little pricey but definitely unique!
    http://seattle.craigslist.org/est/ele/4453094320.html
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited May 2014
    Garage | Polk Monitor 5B's
  • cmarks2701
    edited May 2014
    See the 4-23 thread titled "Everyone needs a good laugh . . ." I guess the seller is learning more about the market.
  • leftwinger57
    edited May 2014
    Cruising todays C/L this set came up. I don't think they have been listed before. No affiliation.
    http://cnj.craigslist.org/ele/4426911621.html
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2014
    Zentish wrote: »
    That could be some of the rarest Polks around anywhere. You just don't see them.
  • Nightfall
    edited May 2014
    What's rare, the subwoofer? Does the crossover take out all midrange on that thing? Pretty interesting, using the bottom half of an RTA12 as a subwoofer.
    afterburnt wrote: »
  • Schurkey
    Schurkey Posts: 2,130
    edited May 2014
    Nightfall wrote: »
    Well...it's a woofer, but is it really a SUB-woofer?
    As I recall, one mid/woofer is driven by each channel, so the crossover would be very different from an RTA12.
