Vintage Monitor and SDA Speaker Deals
1…2627293132…259
  • Bugstyvy
    Bugstyvy Posts: 119
    edited April 2014
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Pro-ject Record Player
    Sony 200 disc CD Changer
    Basic Wiring
    60" Samsung Series 8
    SDA-1.2TL
    SDA-3.1TL (unused at the moment)
  • Nightfall
    Nightfall Posts: 10,083
    edited April 2014
    Doh! I imagine this is breaking the post rule for newbies to see the FS section then, Ken if you see this can you delete my post? Sorry!
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mystery
    Mystery Posts: 2,546
    edited April 2014
    Nightfall wrote: »
    No it's okay.
    FS section is limited to members with certain posts.
    Your post is a link to local CL ad so that's not the same thing even though it's the same speakers.
    I just wanted to inform that the seller is a polkie and has them in FS section.
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2014
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited April 2014
    Just out in todays central Jersey's C/L. These seem to be in good enough shape but from what I've learned here I think the asking price is out of bounds. 0 affiliation just cruising.
    http://cnj.craigslist.org/ele/4416737767.html
  • pglbook
    pglbook Posts: 2,267
    edited April 2014
    Definitely way overpriced! Even half of the amount he is asking would be too much!
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited April 2014
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Irrenhaus
    edited April 2014
    More SDA's SRS 2 or are they SRS for $700.00 in the Bay Area
    http://sfbay.craigslist.org/eby/ele/4437432397.html
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2014
    tygr1955 wrote: »
    These wouldn't be the same 2.3TL's you picked up in Dallas, would they? The ones with the dented dust caps?
    http://www.polkaudio.com/forums/showthread.php?160251-Got-the-2.3-TLs-home-today!&p=2037853#post2037853
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • tygr1955
    tygr1955 Posts: 45
    edited May 2014
    HTguru1982 wrote: »
    Ummmm, yes. Is that a bad thing?
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2014
    PolkieMan wrote: »
    http://www.soundandvision.com/content/onkyo-tx-sr806-av-receiver-ht-labs-measures
    You should get more WPC at 4 vs 8 ohms but distortion and heat will increase.
    That all depends on the design of the amplifier. If it was made to only handle 8 ohms then it may very well put out less wpc into 4 and possibly even be a dangerous situation for the equipment. Some that are 4 ohm compatible drop wattage into 4 ohms because they band aided it to handle 4 ohms. Putting a 4 ohm load on an amp rated for 8 ohms makes it pull more current through the transistors and can lead to a thermal mess that causes parts to burn up. it can also send a spike through to the speakers and make them toast. Remember not all amps are created equal, and if they were we would all be using the same thing.
  • xjghost
    xjghost Posts: 1,115
    edited May 2014
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • cmarks2701
    cmarks2701 Posts: 20
    edited May 2014
    Same type speakers and names on a CL ad in Quad cities IA.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2014
    Something strange? he even states they are "2" not 2.3
    Besides if I was selling something like that I would provide more and better pictures
    ZLTFUL wrote: »
    Seems strange to me that the first 2 pictures are most definitely 2.3s with the donut drivers and the third picture is of the back of an SRS 2...
  • xjghost
    edited May 2014
    I thought it was just cut off.
  • cincycat13
    cincycat13 Posts: 887
    edited May 2014
    More than 1 set of SDA 2.3 are labeled as simply "2"
    Here is where I got mine and they were also listed as "2" by the seller...fortunate for me. Believe the front pictures, not the label.
    http://www.polkaudio.com/forums/showthread.php?101691-Srs-sda-2.3/page2
  • PolkieMan
    edited May 2014
    Well with Polk you never know till you look deeply at two or three things to make sure :-)
  • Zentish
    Zentish Posts: 127
    edited May 2014
    Old-school polk subwoofer. Seems a little pricey but definitely unique!
    http://seattle.craigslist.org/est/ele/4453094320.html
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited May 2014
    Garage | Polk Monitor 5B's
  • cmarks2701
    edited May 2014
    See the 4-23 thread titled "Everyone needs a good laugh . . ." I guess the seller is learning more about the market.
  • leftwinger57
    edited May 2014
    Cruising todays C/L this set came up. I don't think they have been listed before. No affiliation.
    http://cnj.craigslist.org/ele/4426911621.html
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2014
    Zentish wrote: »
    That could be some of the rarest Polks around anywhere. You just don't see them.
  • Nightfall
    edited May 2014
    What's rare, the subwoofer? Does the crossover take out all midrange on that thing? Pretty interesting, using the bottom half of an RTA12 as a subwoofer.
    afterburnt wrote: »
  • Schurkey
    Schurkey Posts: 2,130
    edited May 2014
    Nightfall wrote: »
    Well...it's a woofer, but is it really a SUB-woofer?
    As I recall, one mid/woofer is driven by each channel, so the crossover would be very different from an RTA12.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited May 2014
    i;ve been watching those as well
  • PolkieMan
    edited May 2014
    It's kinda cool I hope someone in the club gets it.
  • Dennis Gardner
    edited May 2014
    Nightfall wrote: »
    http://www.polkaudio.com/forums/showthread.php?122143-Polk-Audio-LF14-subwoofer-(Dorokusai-et-al.)
    LF 14s are the rarity as they have a crossover setup that passes the highs onto a satellite set, can be used in stereo if you have two of them, or 2.1 as this set is being sold. Not your best size combo for a sub rig, but cool for 1976, as sub/sats were rare.
  • Nightfall
    edited May 2014
    Thanks for the info! For the time period, the LF14 and Monitor 4 combo is interesting indeed. I also hope that someone in club Polk that knows how to take care of their stuff is the next owner of these. They appear in VERY good shape for their age and it would be a shame for something so rare and pristine to get into the hands of someone that would trash them.
    afterburnt wrote: »
  • boston1450
    boston1450 Posts: 7,759
    edited May 2014
    Zentish wrote: »
    at first glance i thought those were 10's. Interesting
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
