Vintage Monitor and SDA Speaker Deals
Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Pro-ject Record Player
Sony 200 disc CD Changer
Basic Wiring
60" Samsung Series 8
SDA-1.2TL
SDA-3.1TL (unused at the moment) -
Doh! I imagine this is breaking the post rule for newbies to see the FS section then, Ken if you see this can you delete my post? Sorry!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
No it's okay.Doh! I imagine this is breaking the post rule for newbies to see the FS section then, Ken if you see this can you delete my post? Sorry!
FS section is limited to members with certain posts.
Your post is a link to local CL ad so that's not the same thing even though it's the same speakers.
I just wanted to inform that the seller is a polkie and has them in FS section.
http://hudsonvalley.craigslist.org/ele/4414546401.html
Seem like a nice pair of RTA8TLsHome Theater/2 Channel:
dhsspeakerservice.com/ -
Just out in todays central Jersey's C/L. These seem to be in good enough shape but from what I've learned here I think the asking price is out of bounds. 0 affiliation just cruising.
http://cnj.craigslist.org/ele/4416737767.html2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »Just out in todays central Jersey's C/L. These seem to be in good enough shape but from what I've learned here I think the asking price is out of bounds. 0 affiliation just cruising.
Definitely way overpriced! Even half of the amount he is asking would be too much! -
Polk RTA's 11,12 and 15 speakers in the Bay Area...
http://sfbay.craigslist.org/pen/ele/4423413371.html
http://sfbay.craigslist.org/sby/ele/4395611604.html
http://sfbay.craigslist.org/sfc/msg/4433562869.html
And also Monitor 10's for $60.00
http://sfbay.craigslist.org/scz/ele/4429841804.html
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
More SDA's SRS 2 or are they SRS for $700.00 in the Bay Area
http://sfbay.craigslist.org/eby/ele/4437432397.htmlHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
These wouldn't be the same 2.3TL's you picked up in Dallas, would they? The ones with the dented dust caps?
http://www.polkaudio.com/forums/showthread.php?160251-Got-the-2.3-TLs-home-today!&p=2037853#post2037853Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
HTguru1982 wrote: »These wouldn't be the same 2.3TL's you picked up in Dallas, would they? The ones with the dented dust caps?
Ummmm, yes. Is that a bad thing? -
http://www.soundandvision.com/content/onkyo-tx-sr806-av-receiver-ht-labs-measures
You should get more WPC at 4 vs 8 ohms but distortion and heat will increase.
That all depends on the design of the amplifier. If it was made to only handle 8 ohms then it may very well put out less wpc into 4 and possibly even be a dangerous situation for the equipment. Some that are 4 ohm compatible drop wattage into 4 ohms because they band aided it to handle 4 ohms. Putting a 4 ohm load on an amp rated for 8 ohms makes it pull more current through the transistors and can lead to a thermal mess that causes parts to burn up. it can also send a spike through to the speakers and make them toast. Remember not all amps are created equal, and if they were we would all be using the same thing. -
Not a deal but: http://greensboro.craigslist.org/ele/4399058977.htmlHT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Same type speakers and names on a CL ad in Quad cities IA.
Something strange? he even states they are "2" not 2.3
Besides if I was selling something like that I would provide more and better picturesSeems strange to me that the first 2 pictures are most definitely 2.3s with the donut drivers and the third picture is of the back of an SRS 2...POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I thought it was just cut off.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
More than 1 set of SDA 2.3 are labeled as simply "2"
Here is where I got mine and they were also listed as "2" by the seller...fortunate for me. Believe the front pictures, not the label.
http://www.polkaudio.com/forums/showthread.php?101691-Srs-sda-2.3/page2 -
Well with Polk you never know till you look deeply at two or three things to make sure :-)POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Old-school polk subwoofer. Seems a little pricey but definitely unique!
http://seattle.craigslist.org/est/ele/4453094320.htmlReceiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
did ya see these?
http://www.ebay.com/itm/281331755768?_trksid=p2055119.m1438.l2661&ssPageName=STRK%3AMEBIDX%3AITMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
See the 4-23 thread titled "Everyone needs a good laugh . . ." I guess the seller is learning more about the market.
Cruising todays C/L this set came up. I don't think they have been listed before. No affiliation.
http://cnj.craigslist.org/ele/4426911621.html2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
That could be some of the rarest Polks around anywhere. You just don't see them.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
What's rare, the subwoofer? Does the crossover take out all midrange on that thing? Pretty interesting, using the bottom half of an RTA12 as a subwoofer.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Well...it's a woofer, but is it really a SUB-woofer?What's rare, the subwoofer? Does the crossover take out all midrange on that thing? Pretty interesting, using the bottom half of an RTA12 as a subwoofer.
As I recall, one mid/woofer is driven by each channel, so the crossover would be very different from an RTA12. -
i;ve been watching those as well2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
It's kinda cool I hope someone in the club gets it.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
http://www.polkaudio.com/forums/showthread.php?122143-Polk-Audio-LF14-subwoofer-(Dorokusai-et-al.)
LF 14s are the rarity as they have a crossover setup that passes the highs onto a satellite set, can be used in stereo if you have two of them, or 2.1 as this set is being sold. Not your best size combo for a sub rig, but cool for 1976, as sub/sats were rare.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks for the info! For the time period, the LF14 and Monitor 4 combo is interesting indeed. I also hope that someone in club Polk that knows how to take care of their stuff is the next owner of these. They appear in VERY good shape for their age and it would be a shame for something so rare and pristine to get into the hands of someone that would trash them.Dennis Gardner wrote: »http://www.polkaudio.com/forums/showthread.php?122143-Polk-Audio-LF14-subwoofer-(Dorokusai-et-al.)
LF 14s are the rarity as they have a crossover setup that passes the highs onto a satellite set, can be used in stereo if you have two of them, or 2.1 as this set is being sold. Not your best size combo for a sub rig, but cool for 1976, as sub/sats were rare.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
at first glance i thought those were 10's. InterestingOld-school polk subwoofer. Seems a little pricey but definitely unique!
http://seattle.craigslist.org/est/ele/4453094320.htmlRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
