Jim Salk gives Emotiva as an amp recommendation
1567810
    pitdogg2 Posts: 27,184
    edited September 2013
    MikeC78 wrote: »
    Thanks WL! You're more than welcome to stop by for a demo, If you happen to be in the area. I'm located in Bloomington, IL 61704. Hopefully by then, I have some GIK panels. ;)
    do tell ....we're neighbors who'd a thunk:cool:
    SCompRacer Posts: 9,121
    MikeC78 wrote: »
    Yep. Don't forget that "airy" sound they portray... it is definitely very lively sounding. I can remember the first time I heard them, you couldn't wipe the smile off my face...
    Hey Mike! Them are beauts! High marks!
  • WLDock
    WLDock Posts: 3,073
    MikeC78 wrote: »
    Cool, I'm in Crown Point, IN a few hours away. Would be cool when it starts to cool off before the snow starts. I really want to try something different someday...a ribbon or air motion tweet. So, listening to the Salks would be cool. I'm also want to listen to a set of diy Statements that I have been reading a lot about. Been networking trying to reach a guy in MI that has a set.
  • Face
    Face Posts: 14,340
    megasat16 wrote: »
    It can't be the BE version your talking about? Now, can it be? You means I gotta buy a pair of RAAL too?
    If you can get your hands on a pair of OEM RAAL tweeters, they're worth every penny. More so if you're working with a small mid and have a highish crossover point, but can be used low too, but not for the faint of heart.
  • megasat16
    megasat16 Posts: 3,521
    Face wrote: »
    Who should I start talking to get a pair of OEM RAAL? :D
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Habanero Monk
    Habanero Monk Posts: 715
    edited December 2013
    Had a chance to speak with Jim Salk today. Really great guy. I asked him about his amp recommendations as related to the article:
    Likes all three. Think's BAT is best suited to overly analytical / forward speakers due to it's rolled off top end. He uses the XPA-2 for both his personal use and demonstrating his line up.
    He says when customers come in and start talking up the electronics roulette that they are better off just enjoying the music as the speakers are where the SQ comes from predominantly. Basically nothing to worry over when it comes to differences in the three.
    + 1 to Jim Salk being a good guy. I was there mid November picking up my SoundScape 8's and the wife and I got a tour of the facility. One of the highlights was the veneer vault!
    http://www.polkaudio.com/forums/showthread.php?154420-I-ve-been-Salked
    My speakers were packed so he demo'd a pair of SS8's for me. There is no showroom, just a large open area filled with his speaker offerings that doubles as an office. He was using the Emo amp with a Van Alstine preamp and an Auralic Vega DAC. It sounded great. Better than great, fantastic. Not to say it couldn't sound better, but I could live with that sound. He also said the amp is inexpensive and reliable. (They don't always shut down gear when swapping speaker cables).
    Now the other day another SS8 owner posted reply # 20 in his thread:
    http://www.audiocircle.com/index.php?topic=120311.20
    "I'm powering them with an Emotiva xpa-2 (300w/ch). I've found that at louder volumes, I will start to overheat the amp. I love the tight bass and response of the SS8's but I grew tired of having to give the amp a break. Now I'm crossing them over at 80Hz and sending the rest to the subs. "
    The SS8's are spec'd at nominal 4 Ohm, 87dB sensitivity. Now I don't know if his amp has a problem, his speakers have a problem, his pre has an issue, source has an issue, or how loud and how long he had it loud, but I'd want to know more before buying one and using it on my Salks.
    So far the Sanders ESL amp I tried (700WPC @ 4Ω, stable to 1/3 Ohm) and the Wyred SX-1000 mono blocks (1,140W at 4Ω) I am currently using have performed without any issues no matter how loud I play them. But they do cost a lot more.
  • Face
    Face Posts: 14,340
    Your W4S monos are 2ohm stable too. Maybe the Salk's impedance curve dips too low for the Emu?
    Not sure Mike. If I were having an issue I might ask...;) but it would be good to know. I know of one instance where an SACD player sent unwanted frequencies that you couldn't hear or the speaker was unable to play cause an amp to get hot, so that's why I mentioned source. Some oscillation issue.
    I should have the Class A Krell amp early January. The fellow that loaned me the Wyred's said I could hang on to them until then. IF I get blown away, the Krell will stay. If not, these cool running and low cost to operate SX-1000's will stay.
  • Jhayman
    Jhayman Posts: 1,548
    how much do these SS8's go for normally?
    I'm in the process of thinking where and what I can upgrade now , maybe my TT or different speakers?
    I even thinking of a VPI Scout 1.1 or 2.0 I know I might hear something on this..lol
    My votes for speakers......the worlds your oyster for musical speakers.
  • megasat16
    That statement is a mixed bag of right and wrong. A good speaker design is critical to ensure the delivery of the natural sound but it's not the predominant factor. It is a part of the very important aspect of music reproduction in the chain. Every other piece in the chain influence the final sound coming from the speaker and if the speaker are $HITTY, you won't hear what you suppose to hear.
    If you think the tip of the mouth (the lips) are the most critical part in how you sound, think again. I am sure the vocal cords, the tongue, the cheeks, the teeth and the Adam's apple all influence the tone of the voice.
    Remember, a good speaker can make or break your system. And a revealing speaker should be able to discern the difference in electronics used in the chain. If the speakers can't differentiate the el cheapo electronics from the better made ones, there is something wrong with that speaker!
    Well said ^^^
  • CoolJazz
    CoolJazz Posts: 572
    I also think that Salk's preamp choice is illustrative of the electronics chosen. Garden variety and proud of it!
    Why leave quality on the table ignored and lost at every listen?
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    Jhayman wrote: »
    SS8's start at $7,999. Plenty of options to make the price go up, like with veneer, cap upgrades. The xovers do have high quality parts to start with. Mine are in black limba and Jim said that added a few hundred. With real exotic wood you can push into four digits. I snagged a year old pair with a veneer I really liked at the Salk 'available now' circle (at Audio Circle) for less than new. And they are in perfect condition. Jim devoted a forum for available now speakers and will list his customers used speakers for sale. Used Salks hold their value well though.
    Lots of folks in the Van Alstine camp and very happy to be there. ;) He is a no frills guy.
  • Habanero Monk
    megasat16 wrote: »
    My take on my conversation with him is there are quality electronics at relative plebeian price points. I'm sure you aren't saying there is anything wrong with his speakers. Are you saying that Mr Salk is incorrect or that his speakers aren't up to snuff?
  • aboroth00
    aboroth00 Posts: 1,106
    megasat16 wrote: »
    Man... If my speakers can sound awesome with el cheapo electronics, i'd think i had hit the jackpot!
    2Ch Tube Audio Convert
    No...I don't believe he is. Just a general statement is all.
  • megasat16
    I will rehash a previous post I made (Post #5) in this thread. I don't share Jim Salk passion of the electronics. :) He does make good speakers for the money. I don't mean his speakers aren't up to the snuff. I meant in General terms. If the speaker doesn't change the sound with the change of electronics, there is something wrong with that speaker.
    I highly doubt Jim Salk speakers fall in this category. I highly admire of Jim Salk choice of drivers in his speaker.
    I will also quote ScompRacer (Rich) assessment on his Salks tower. He said he is happy with the demo he received with the Emo XPA-2 amps but I doubt he is content with it. I think he is rolling amps and electronics with Salk tower and it must meant Salk speaker doesn't sound the same if different electronics are introduced to them. It is a high mark and definitely doesn't make them fall in my general statement above.
    megasat16 wrote: »
    Jim Salk makes awesome speakers and have my respect for his products. But it doesn't mean he earns my respect for his taste in electronics.
    tonyb wrote: »
    Thanks Tony! It is exactly what I meant.
  • WLDock
    WLDock Posts: 3,073
    megasat16 wrote: »
    IMO, I think this is what Sault was getting at with the comment. Its almost as if he is saying, hey...I'm a speaker builder, I will let the customer get into rolling amps and electronics in their own room to bring out the sound they are after. Maybe he feels the EMO is good enough to Demo the general character of the speakers? Why else would he not Demo $8K speakers with $8K of electronics?
  • headrott
    headrott Posts: 5,496
    And those who believe that Emo is in the same league as BAT need to listen again and re-think that assessment.........
    F1nut Posts: 51,899
    headrott wrote: »
    That's sig material.
    megasat16 wrote: »
    True dat! I know you so I know what you meant. ;)
    Audio is both subjective and relative to what you have experience with. By owning or hearing different gear you gain perspective. Jim Salk is worthy of having a successful speaker building business. Imagine how many speakers he would sell if you were required to spend big dollars for gear to make them sound good. They sound good with an Emo amp and VA gear. They sound really good! If they didn't I wouldn't have bought a pair. His speakers are capable of allowing higher resolution gear to make them sound even better.
    Speakers get you [you fill in the blank] %. The rest is the gear, the room it's in and what you do about any room issues.
  • bobsauto49
    bobsauto49 Posts: 973
    headrott wrote: »
    Good post! The same people don't take the time to try higher end gear, or simply can't afford it!
    I've owned Emo, and BAT! And there's a difference. A BIG difference!
    Jim Salk is not only a speaker designer, but a salesmen to! And a damn good one at both I reckon;-)
    "Everything I ever did in my life worthwhile I caught hell for"
    SCompRacer wrote: »
    Bingo....so your saying...."everything matters" ? LOL
    tonyb wrote: »
    When did I ever say it didn't? ;) I think Jim believes the same thing. What I stand behind is his speakers sound good enough to buy with an Emo amp.
    Too bad his BAT amp was broke I could have asked him to swap the Emo out...lol
  • megasat16
    SCompRacer wrote: »
    I know you wouldn't buy it if it doesn't sound good. I am sure you wouldn't move from the Sander's ESL panels if these Salk doesn't sound good and I know how much you love the ESL. :)
    A few years back, I was seriously looking at the Salk Songbirds but a certain islander you know whom told me DIY is the way to go. lol
    SCompRacer wrote: »
    Now, this is a secret that you mustn't let out. The EMO works and Damn BAT ain't. It explains a lot why Jim loves EMO. lol
    megasat16 wrote: »
    Different animals, that's for sure. No regrets, just have to put the effort into getting them to sound their best like I did with the ESL's.
    Yeah that islander you refer to thought I'd be able to pull off the speaker diy thing too, but I took the other way out. I sold off most of the good tools after I finished the lighted lower level here. Took me a year, didn't want to ever see a wood working project again.
  • megasat16
    SCompRacer wrote: »
    Yes, different animals for sure! But I think the Salks have dipole radiation for the mids and the tweeters as you mentioned in another thread. I think they would be a bit more easier to drive than the ESL so lower wattage Class A amps may be ideal. The Krell Class A and the Krell KSL pre may just be the ticket to make them sounds great!
    I don't regret going DIY for the speakers. I was too lazy to go DIY but it's all Thanks to Mike for pushing me DIY route. It sure is a lot of work and a lot of learning but I like to get my hands dirty when I am free. The problem is that the Free time is hard to come by. :)
    Happy Listening to the Salk Tower, Rich! I am sure you will be grinning from eyes to eyes listening to them.
    If I had the experience like you guys, I'd have went the diy speaker route.
    The Raal tweet is sealed at the back so you only get the dipole option out of the Accutron mid. The KSL is a warm sounding Class A SS pre. It was a good combo with the Sanders ESL amp on my ESL's; the KSL pre is also a good combo with the Wyred mono blocks on my SS8's. We tried the Sanders amp in Blake's system (Revel F52's) with a BAT SS pre but the amp was too neutral sounding. Never tried my KSL pre in his system. The Krell KSA-250 amp was an excellent fit in his system with the BAT SS pre so it remained there. I think he said you can take it with but I ain't helping you get it to the car...lol
    If I go too warm with the KSL/KSA combo, I can always try this Krell KRC-HR pre. This pre with my Sanders ESL amp was fatiguing on the ESL speakers. Extremely detailed. Great with the Class A Krell amp though. Not that it matters to me, the KRC-HR is a Sterophile Class A recommended pre. It got there due to the way it was built and sounded. That's what matters to me. The remote volume has 300 discrete attenuation steps. I'll get to where I want to be.....enjoying the process now, wasn't at first.
