SDA-2B-TL & Recap Completed
1246789
  • sda2mike
    sda2mike Posts: 3,131
    edited May 2011
    seriously, to the OP...all the advice was good...for now, the best upgrade you can do is either placement in your current room or your future digs...that alone will blow you away...then more current..then maybe the 194s....then the TL mod..
    heiney9 Posts: 25,432
    edited May 2011
    sda2mike wrote: »
    He did the TL mod with 198's........it all still need to break-in too.
  • sda2mike
    edited May 2011
    my bad....long thread...i was going in the order in which i did my upgrades...and ROOM was the most revealing
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited May 2011
    Impressions around to 100 hours: (to lazy to actually calculate it)
    You wouldn't believe who stopped by today....his name is BASS.
    So, the low-end punch hasn't opened up the way I thought it would with close to 100 hours on the "burn in" process. So I pressed a little button called "loudness" which I normally stay away from, and :eek::eek::eek:
    I usually keep all EQ flat, with the occasional treble reduction. Well, this Loudness button really turned the speakers into bass monsters. I mean, I've always seen the button. I just always thought it's more pure flat. Do you guys bump up bass or use the loudness button on your pre-amps?
    The punch is there, the low end is there. I don't know what else to say. All it's getting is a measly 45 wpc from my vinatge Marantz 2245. I'm interested to see what will happen when the Carver TFM-45 @ 370 wpc gets in.
    One complaint though, and I guess things still need time to adjust, but the highs may need to be padded down some. They aren't harsh, it just doesn't feel balanced at this point.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited May 2011
    300 hours is pretty much when the Sonicaps will settle down.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Conradicles
    Conradicles Posts: 6,343
    edited May 2011
    TennMan wrote: »
    Testing with a 1.5 volt battery would tell if that is the problem.
    This test is amazingly fast and accurate.
    :cool:
  • audiocr381ve
    edited May 2011
    :cool:
    How exactly do you do that test and what for?
    Good to hear inspiredsports!
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2011
    Using a battery to test your speakers......
    1. Take some speaker wire. Enough to reach around the speaker..
    2. get a 1.5 volt battery. AA, AAA, C, or D. Just one now.. Do not use a 9volt as it may damage the speakers.
    3. Connect speaker wire to the speaker.
    4. Paying attention to what wire was in the positive side and what wire was in the negative side,
    5. Connect the negative wire to the battery by holding it or taping it to the negative side of the battery.
    6. Now tap the positive wire to the positive side of the battery and watch the mid drivers. If you are wired correctly the drivers should push forward. If something is wrong one of or both of the drivers may pull in.
    Now you know if there is a problem with your wiring.
  • audiocr381ve
    edited May 2011
    Impressions as of today: (Modded on 5/16. Today is 5/27)
    The speakers are sounding pretty good. The honey-moon phase is over so to speak. My initial shock and wow has faded, and now I listen with sober ears.
    The TL mod made these speakers very different. Nothing is recessed. Vocals are up front as they should be. The highs are nice a sparkly. Not a hint of harshness. The only thing I hear that sounds a little off is that the RD0-198's don't blend very well with the mid-range drivers. I literally have to turn the treble down 3 or 4 notches to balance it out. It's not my room, I can't tell you how many speakers have come through this room and have sounded fantastic and coherent. At lower volumes these speakers sound small and thin. Almost as if they were small-not-so-good sounding bookshelf speakers. As of today they don't stack up well against other speakers I've owned in terms of detail, my favorite being the Monitor Audio Silver RS6. Nothing special until your in that sweet spot with the volume turned up, which unfortunately most times I'm not. But when I am, wow, that's where the magic is. I guess I can boil it down to them not being the best off-axis speaker.
    Don't get me wrong, I'm enjoying my speakers. They sound good. They don't sound phenomenal but I'm really enjoying the music which is all the matters. I just wanted to be the first to say that I could have enjoyed these either way, with or with out the modifications done. I liked the old smooth riding Cadillac I had before. I'm definitely enjoying the new engine. I feel like I could easily get a better sounding speaker for under $1,000. These need to be enjoyed as they are, a piece of audio history that's strength is the incredible 3D soundstage.
  • audiocr381ve
    edited May 2011
    BTW, I will post more impressions after I get the Carver TFM-45 back from the repair shop which will be connect to my new Emotiva XDA-1 DAC/Preamp combo that should be here in a few hours. That might make all the difference in the world.
  • nspindel
    nspindel Posts: 5,343
    edited May 2011
    Two words - better amp.
    edited May 2011
    nspindel wrote: »
    I was going to say that, but not everyone or every situation is going to like SDA's. Perhaps they aren't for him, but I hope he keeps trying to get the sound he wants. My 1C's have none of the issues he describes, but they did when I had less than optimal gear running them.
  • Joe08867
    edited May 2011
    Have you tested them to see if they were wired wrong internally?
    And like nspindel and H9 said. A better amp will help immensely.
  • audiocr381ve
    edited May 2011
    Joe08867 wrote: »
    No I haven't tried that yet. Is their any easy test with out having to take out the drivers?
    I have the Carver TFM-45 @ 375wpc @ 8 ohms coming back from repair next week. I'm excited to hear what that will do.
    edited May 2011
    9V battery test which I'm sure you are aware of, but you have to remove the drivers.
  • audiocr381ve
    edited May 2011
    Wow, new DAC/Preamp has made a major improvement. I'm really hoping the Carver is the missing puzzle piece.
    http://www.polkaudio.com/forums/showthread.php?t=120164
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2011
    As the owner of 2BTL's and a high current amplifier and some experience with Carver gear, IMHO Carver does not have the enough current output. Without naming names I would recommend an amp with high current abilities.
    My 2 cents.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • audiocr381ve
    edited May 2011
    My 2 cents.
    Scott
    I know wattage and current are different, but it puts out 375 wpc! Could you elaborate a little on this?
    I like when people name names, I don't mind :smile:
  • Joe08867
    edited May 2011
    Yes, Follow the instructions I wrote earlier in this thread. I wasn't talking about removing the drivers. Use the drivers in the cabinet. Connect the Battery to the positive and negative terminals on the back of the cabinet and look at the drivers. If they push out they are wired correctly if they pull in they are not wired correctly.
    You may also see the SDA driver in the other cabinet move. and the same rules apply. If it pushes out good in bad...
  • audiocr381ve
    edited June 2011
    Joe08867 wrote: »
    Thanks Joe, I didn't catch this earlier. I'm gonna do it just so I KNOW.
    Anyway, many of you are probably picking up just by reading my posts that I need to learn a bit of patience and just SLOW down most of the time. Story of my life... But let me tell ya, I don't know if it's because things are settling down in the crossovers, or because I had an awesome breakfast with some friends this morning, but my goodness I'm enjoying everything about the sound I'm getting right now. I love these speakers. I still believe I could find some technically better speakers under a $1000, but these just have the "it factor".
    I love me some SDA-2B TL :biggrin:
    edited June 2011
    I don't think you could for less than $1K, and why would you want a more techincal speaker (whatever that is) if these have the "it factor". This hobby is about the subjective reproduction of sound, not the technical merits one can squeeze out of a speaker. (see my sig) :biggrin:. I'll take a slightly slower more enjoyable to drive car over a "technically" faster car lesser enjoyable to drive car.
    I'm sure it's the cross overs *starting* to settle in just as many of us have explained over and over :wink:.
  • nspindel
    edited June 2011
    heiney9 wrote: »
    Yup. 200 hours minimum, 300 even better.
    It's amazing to me that people even question whether or not things need to break in. There is simply no question about it. I just purchased a new pair of Signal Silver Resolution xlr interconnects to replace the copper interconnects between my dac and my preamp. I've also acquired a W4S DAC2 to evaluate against my Benchmark DAC1 Pre. Out of the box, let me tell you - things sound awful. Bright. Rough. Shrill. Narrow soundstage. Very narrow. Completely closed in and harsh sounding. I wouldn't even dream of doing any kind of critical evaluation yet. W4S recommend 200 hours break in for the DAC2, it's right there in the instructions. And silver cable can require 500 hours!!
    It would be easy for someone sitting down and listening to my system right now, for the first time, to look at my components and think - "hmmmm, you need better speakers." Nope. I need more break-in.
    I simply will not render any opinions on how these changes sound until these silver cables have 500 hours on them. Yeah, kind of inconvenient to need to keep my system playing on a loop for almost three weeks! But it is what it is. As long as I don't need to have the speakers on, then it's exactly that - an inconvenience. But when that's done, I'm convinced it will be well worth it!
  • audiocr381ve
    edited June 2011
    heiney9 wrote: »
    You're right, and you're repeating my point :wink:
    I'm still unsure about burn in. I'm not sure if it's me or the gear! I'm as fickle a man as they come which leads me to believe it's more me than anything.
    But man do they sound right today...
  • sda2mike
    edited June 2011
    my 2Bs were TLd around april of last year....the romance continues!:wink: i have WAY more than 300 hrs, fo sho...but lately when i listen, they sound like what i would imagine the artist had in mind when they made their art in the studio...naturally, with good spkrs, a lousy recording is unbearable...some new releases come to mind..way too hot, but that's another thread..
    enjoy your TLs!
    mike
  • audiocr381ve
    edited June 2011
    sda2mike wrote: »
    enjoy your TLs!
    mike
    Good to hear you're still diggin' em!
    I should mention that I swapped out a pair of KnuKonceptz stereo cables for some Blue Jeans cables. For the first time, I'm actually turning UP the treble. Wild. What the heck is happening??!?!
  • sda2mike
    edited June 2011
    the xovers are settling in...don't worry they won't stay there...
  • audiocr381ve
    edited June 2011
    sda2mike wrote: »
    No, it's a good thing! I like the highs rolled off slightly.
    What types of setups have worked best with your 2B TL's? (amps, preamps, etc)
  • nspindel
    edited June 2011
    My 2B's were mint through that NAD amp I'm selling:wink:
  • sda2mike
    edited June 2011
    i have an Adcom GFA 555..which was in place before the upgrade...reliable tank power
    for the pre: i was using my Marantz 2270 for awhile...even before the Adcom that was my amp..
    then i get into tubes...i now have an Aric Audio pre..it's hand wired and assembled...i go into tube-rolling phases..then settle on a pair for awhile..then it starts all over again...just one part of the overall sickness, i suppose:wink:
  • audiocr381ve
    edited June 2011
    nspindel wrote: »
    Haha, don't tempt me, I already have 2 beastly amps on the way!
    I hate people that type in all caps, but I feel like I must say this in caps.
    I JUST LISTENED TO SOME MICHAEL JACKSON IN 24 BIT AND OMG OMG OMG OMG OMG OMG OMG OMG. Their was a section of one song where it literally sounded like someone was outside of the house playing a percussion part. I had to turn down the music to make sure someone wasn't out there!
    These speakers are VERY different than they were yesterday. No kidding. I'm popping in all of my familiar tracks and the tweeters are now TAME and beautiful. Nostalgia comes to mind. Goodness gracious.
