You don't need close to 200wpc
1…789101113»
  • Ricardo
    Ricardo Posts: 10,634
    edited February 2011
    I also know a lot about cables. People say cables don't make a difference, but I know better. I removed the input cables once. Guess what. There was no sound coming out of the speakers, even though they were still connected to the amp. Weird, I know. But it shows that cables do make a difference.
    SOPA
    treitz3 Posts: 20,367
    Hehe
  • shack
    shack Posts: 11,154
    Ricardo wrote:
    I also know a lot about amps. They usually have an input connection, two if they are stereo amps. Then inside this input signal goes through a lot of stuff , and then there's the output connections. Pretty simple. Oh, and they have a power cord for power and an on/off switch.
    Edit: And my amp is not 200 WPC. It's 250 WPC. Not sure what that means, just throwing it out there.
    Ricardo wrote:
    Oh, that's right. Mine has this meter on the front. I think it measures the temperature in the room.
    Let a guy get over 10,000 posts on a forum and he thinks he KNOWS everything....:rolleyes:
    :biggrin:
    mhardy6647 Posts: 35,562
    FTGV wrote: »
    Huh,what iz they are?:confused:
    You "vu" them with your eyes from across the room... and they tell you stuffs about your amp. Important stuffs.
  • FTGV
    FTGV Posts: 3,650
    Ricardo wrote: »
    Edit: And my amp is not 200 WPC. It's 250 WPC. Not sure what that means, .
    It means Jack squat to some, but be all end all to others.:wink:
  • FTGV
    FTGV Posts: 3,650
    So ifs I aints gottz one meanz I izn't Knowledging the important stuffs?:frown:
  • Ricardo
    shack wrote: »
    :biggrin:
    I know, right? Who do they think they are? Geeez.
    SOPA
    ftgv wrote: »
    so ifs i aints gottz one meanz i izn't knowleding the important stuffs?:frown:
    srsly.
  • Ricardo
    I could also tell you guys a story about a subwoofer made with cardboard. Not only that, but it had a hole....to let the air out. And they used black paint....to paint it.
    But you guys wouldn't believe me.
    SOPA
    SCompRacer Posts: 9,407
    Ricardo wrote: »
    Wow....you lost me at two!:eek:
  • shack
    shack Posts: 11,154
    Ricardo wrote: »
    Is that the one with the Big Blue Badass Caps?
    Ricardo wrote: »
    I'd believe you -- unless you said you need close to 200 wpc for it. Then I wouldn't believe you any more (even if you let me VU your meters).
    Ricardo wrote: »
    Single or double wall cardboard?
  • newrival
    newrival Posts: 2,016
    Ricardo wrote: »
    I'd believe it. I saw one made of 2 styrofoam plates. it must've been a protoype, he hadn't painted it yet.
  • Ricardo
    No you would not need close to 200 WPC, as long as you use an Amsoil carboard box.
    SOPA
    heiney9 Posts: 25,724
    newrival wrote: »
    heatsink and chasis size seems a curious thing to base your heavy skepticism. Anyways here it is from the horse's mouth (Robert Adam of Classe Technical Support): "the CA-300 and CA-400 have adaptive biasing... Bias is kept low at idle to reduce heat, and increases under the load as output increases. Both models run class A up to 20% of rated power before running in class B. That means 60W and 80W respectively."
    Ok fair enough but sliding bias schemes aren't pure class A and that's to me what class A is when people mention it. And yes heatsinking and chassis size has a direct correlation to whether or not something is pure class A. That chassis and heatsinking wound never dissipate 80 wpc class A.
    It was just an observation and now we're just discussing semantics as the classe amp is a high bias A/B amp.
    FTGV wrote: »
    Really Brock,I assume your reference is an NP article that you will gladly link for us.There have been a number of fine true Class A amplifiers that utilized them.Think early Krells,and Classic ML2's etc.
    Pure class A, single ended? I was under the impression Bi-polars weren't rugged enough to be stable run like that.
    I sense people are tired of me and this thread so I'm out guys.
  • megasat16
    megasat16 Posts: 3,521
    FTGV wrote: »
    They are used for skin tanning....
    And that too if you are looking at it....
    FTGV wrote: »
    But only important if you open the eyes and listen to music. If you close the eyes to listen, you can't VU anymore. But still good for skin conditioning. :tongue:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • megasat16
    heiney9 wrote: »
    BJT are pretty rugged and stable for using Pure Class A. In fact, BJT love heat. They comes alive as a fish in the water when BJT is biased very hot before thermal breakdown. It's a magical biasing region for the BJT that's akin to Tubes.
    And pretty stable to low load impedance as long as you have many of the BJTs in parallel as output transistors.
    No, we are not sick of this thread and you. :biggrin:
  • BlueFox
    BlueFox Posts: 15,250
    Ricardo wrote: »
    Does it need an airhole?
