Building 400 wpc Tube Monoblocks....
Looks like a great project John.
Is the amp gonna have auto-bias or manual bias for the power tubes?
Are you installing a switch to go from ultralinear to triode mode?SDA SRS 2.3TL's
SDA 2B TL's -
This is just one reason I am glad I joined this forum....
John the granite looks outstanding and just the chassis are spectacular. The detail work outside makes me wonder the detail you are going to take on the wiring which no one will see but you and us (via pictures)."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Updated pics with the binding posts, input terminals and EIC connectors in place...
Wiring will begin as soon as I research what will be best for them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
michaeljhsda2 wrote: »Looks like a great project John.
The tubes will be auto-bias and there will be switching for ultralinear and triode modes...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Doesn't Bob already know that?nooshinjohn wrote: »Wiring will begin as soon as I research what will be best for them.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
nooshinjohn wrote: »The front end is tubed, using two 12ax7's. I am going to be learning a bunch of terminology as these progress and I assume that power rectification is one of them.:eek::)
Not likely. I suspect it is SS retification.Speakers: SDA-1C (most all the goodies)
It appears by looking at the photographs I have that the wire used is common copper wire. I am looking into silver.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'd look into a better RCA jack too, if you're going all out, at least used a gold plated copper jack. Vampire, WBT, etc... As for wire, Neotech solid core teflon jacket chassis wire is excellent."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Those are rhodium plated jacks from Cardas...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I can't wait to hear these John
I can't either Mike... I look forward to hearing them too.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
You got balls of steel. Will these ship with a forklift included for placement?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The original variant of these amps ship at 47 pounds. I expect these will be in the 65 to 70 pound range.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
So how in the world are you going to power this? You going to have a dedicated circuit for them at your house?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Those are some nice looking amps you are building.
I would love to hear them some day. -
bigaudiofanatic wrote: »So how in the world are you going to power this? You going to have a dedicated circuit for them at your house?
They can be powered off the 15 amp circuit in the house, but when we move, I will have a 20 amp setup for them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Just a bit of an update... I have settled on using a bird's-eye Maple for the side panels. The wood will be stained in a warm, natural color with a satin finish. The rear of the amp is being treated to hand-painted lettering for the inputs/outputs/fuses and other details on the back. The stainless trim rings are being plated in silver.
I have also ordered new tube sockets as I was unhappy with the fit of the originals. Once I have them, I will begin wiring them up, and in a month or so, when Bob is ready, I will fit the transformers and order up some cryo-treated KT-120's.
Pics to follow on Monday or Tuesday next week!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I wonder how you will be soldering silver / silver-plated wire, which requires tons of heat to properly reflow/attach. It is damaging to the components, if not done properly/professionally.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Heat sinks~they take the heat off on a different path. It's AMAZING how much heat can be dissipated in this way.
for example:
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
^^^what he said!:D:cool:
I can honestly say this is the most FUN I have ever had in this hobby! Seeing everything in my mind come together in the form of something that will be as much a work of art as it will be functional has inspired me to do even more....
Bob has given his full support and blessings to my doing a limited run of these amps, so long as they are as good in person as they are in pictures. Bob now wants to have me ship these to him for evaluation when I am done. I guess that makes these "prototypes".:):)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That is awesome!! What's next - a "Club Nooshinjohn?" :biggrin::biggrin:
Chris -
nooshinjohn wrote: »^^^what he said!:D:cool:
That's great!! Be sure to keep us posted.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
John,
Great work and great pics! Will be checking in on this thread for your progress. Labor of love but that's going to be one sweet tube amp! -
John,
Great work and great pics! Will be checking in on this thread for your progress. Labor of love but that's going to be one sweet PAIR of tube amps!
Fixed!:biggrin:
And thanks for the kind words.:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Fixed!:biggrin:
LOL! I drooling over your tube amps and forgot my grammar.
Or were you going to ship one of them to me, so that would technically make it "one sweet amp" for you.:biggrin:
Best DIY tube amp project I have seen in a long while! -
thanks for giving me something to look @ while in the hospital this weekend...
EndersShadow wrote: »thanks for giving me something to look @ while in the hospital this weekend...
And perhaps something to listen to if you want to make a trip to Lafayette one of these days.
Get well soon!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »And perhaps something to listen to if you want to make a trip to Lafayette one of these days.
Get well soon!
lol, trust me I have already thought that. Just happy at this point they are going to let me eat. Been Wends since I had food and that sucks lol......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
nooshinjohn wrote: »Just a bit of an update... I have settled on using a bird's-eye Maple for the side panels. The wood will be stained in a warm, natural color with a satin finish. The rear of the amp is being treated to hand-painted lettering for the inputs/outputs/fuses and other details on the back. The stainless trim rings are being plated in silver.
I'm going to suggest using stainless steel for the side panels since you are using some elsewhere. When using too many different materials things start looking out of place. I would also suggest not plating the trim rings.
Stainless steel and granite is manly, adding wood to the mix says kitchen ****.Political Correctness'.........defined
President of Club Polk -
