cable break in believer
15681011
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2010
    treitz3 wrote: »
    Your test is flawed. Let me repeat that since you have a hard time grasping things around here, your test is flawed. Now, before you go spewing BS out of your Johnson licker, hear me out.
    I didn't purport any test. The receiver of the cables gets to test in whatever manner of their choosing. I am simply providing a some parts that go into the testing rig.
    treitz3 wrote: »
    Nobody would be able to pass your test accurately. If they do [and I doubt anybody could], it would be just plain dumb luck. First and foremost, the test would obviously have to be done in stereo. That's 2 channels. Count them, 1, 2. That's it. OK, now that we have established that the test will have to be done on two channels we have now determined the fundamental flaw in your challenge.
    Two channels is normal to stereo listening, no?
    treitz3 wrote: »
    How can you tell if 1 IC is broken in when you have 2 separate channels with 2 separate signals? You can't. Even if it were a mono signal, the changes in room acoustics between the R & L channel [in an estimated 98% of board members listening rooms] would alter the outcome. Stereo effect is just that, stereo. Without it, you completely lose the sound stage that stereo presents.
    Other people are stating there is a difference in their setup, room acoustics between R&L channels, et al. That is when everything is the same excepting x or y there was a change. Are the people that hear a difference only listening in mono? Either burned in cable makes an audible difference (follow the ball under cup) or it doesn't. 1.0/2.0/5.0 what have you.
    treitz3 wrote: »
    That stereo image is the #1 thing I [personally] pick up on when hearing changes within the system. Those that have well trained ears would most likely agree. Sure, the frequencies may change but with the test you presented but....even if someone was to pick out the pair of burnt in cables....it might sound better or worse to them in their rig. Same goes for the new pair. Let me repeat, your test is flawed.
    You don't understand: I am not performing any test. I don't know how to make that any more clear. You get the benefit of evaluating said cables any way you see fit.
    Explained another way: You aren't picking out 2 burned in cables in actuality. You are grouping cables together based on audibility. When you either group the non-burned in or burned in correctly you will ALSO have identified the 2nd group correctly. The discriminate in this is simply a change in audibility.
    treitz3 wrote: »
    That said, since your intentions have obviously been pre-planned? I wouldn't doubt for one second that you have planned to give out 1 burned in cable and all the rest being new or even no burned in cables at all being sent. In other words, I don't trust you. With your blatant intentions of thread crapping and predictions of what's to go down? I doubt anybody else on this board would either.
    My intentions/hope was to get some one to take up a friendly wager. My predictions is that no one would. So I'm a **** because I knew how it was going to go down? Just like I know how a thread with Emotiva in it will go? Doesn't take a rocket scientist to figure it out.
    The offer still stands.
    Just like you I am allowed to make predictions based on past information. Since when is forecasting a crime? Stock brokers do it all the time. Again I have two cables that are in my setup currently and another 25 foot coiled up unused. On the trust issue: don't participate then.
    treitz3 Posts: 20,205
    edited October 2010
    I have talked to brick walls that are smarter than you.
  • WilliamM2
    WilliamM2 Posts: 4,809
    edited October 2010
    I am practially speechless as to how utterly ridiculous that is.
    It's your beliefs that are ridiculous. Tell me, if there really is a difference, why can't it be demonstrated?
    I could ask you why you argue your side as well. And why you continually give people bad advice about cables, based purely on a myth.
  • WilliamM2
    edited October 2010
    treitz3 wrote: »
    Nice.
    I wonder if he "predicted" you'd say that? :D
    You seem more the type to believe in predictions and future telling. Probably all kinds of nonsense.
  • kevhed72
    kevhed72 Posts: 5,187
    edited October 2010
    WilliamM2 wrote: »
    I am completely nuetral in this debate, but if I could ask, what ICs and speaker cables do you run in your system?
  • WilliamM2
    edited October 2010
    treitz3 wrote: »
    You talk to brick walls? And then question his intelligence?
  • jinjuku
    edited October 2010
    treitz3 wrote: »
    You simply can't grasp the fact that I'm not the one performing a test. Wow.
    F1nut Posts: 52,139
    edited October 2010
    jinjuku wrote: »
    My prediction was correct, you are a troll.
  • WilliamM2
    edited October 2010
    kvetched wrote: »
    How is that relevant? I use a mix of 12 guage and 14 guage wire, I didn't concern myself with the brand. IC's are from parts express, stock weren't long enough. What IC's and speaker wire do you use?
    F1nut Posts: 52,139
    edited October 2010
    Ken,
    Shut this troll infested thread down......PLEASE!
  • kevhed72
    edited October 2010
    WilliamM2 wrote: »
    Just a curious question. I have Terminator 4 speaker cables I bought used and AQ Sidewinders / King Cobras, also used. I started off with Blue Jeans Beldin 10 white about 4 years ago, now this wire is used for surround duty only.
    heiney9 Posts: 25,575
    edited October 2010
    WilliamM2 wrote: »
    Why do you care, you already admitted you can't/don't hear a difference. Why on this earth do you care?
    WilliamM2 wrote: »
    How do you know it's a myth? Your belief is, if YOU can't hear it then it doesn't exist? But, others have to prove to you, through their own hearing, that they hear it, just so you continue not to hear it. :confused::confused:
    Why?
    Why?
    Why?
    Are you trying to save someone from spending too much on audio gear?
    Seriously, WHY? I have an idea why, but I'll hold my words
  • WilliamM2
    edited October 2010
    Sure you can hear a difference. Why are you so threatened that others don't believe your fairy tales?
  • steveinaz
    steveinaz Posts: 19,546
    edited October 2010
    Why do the birds go on singing
    Why do these eyes of mine cry
    Don't they know, it's the end of the world
    It ended when you said goodbye...
    Sorry, Karen Carpenter moment.
  • headrott
    headrott Posts: 5,496
    edited October 2010
    WilliamM2 wrote: »
    The difference can be demonstrated. You (and other "non-believers") simply cannot hear the difference (as you stated). End of story. Sorry, there's no way to prove something to you that you cannot hear (if we are talking about audible differences as Jinjuku stated). I would simply accept that you cannot hear what some others hear and be done with it. It would save you and others a lot of time and wasted banter.
    Greg
  • sm88
    sm88 Posts: 353
    edited October 2010
    Maybe it would save someone from keeping a piece of audio gear that they otherwise would not, based upon the idea that at some point the cables that they spent their money on and didn't like would miraculously get better. There are plenty of purchases made entirely on hype, and when someone says they don't like how a cable sounds they should get rid of it rather than keep a poor investment.
    And once again 'level headed' people make the absurd statement that the cables have to be expensive in order for burn in to take effect. Why would a piece of aluminum coated in rubber "burn in" less than a piece of silver coated in Teflon? And what changes within the metal that makes the music sound better?
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • steveinaz
    edited October 2010
    WilliamM2 wrote: »
    William
    The difference is, non-believers seem to not be content with just stating their opinion, they then want to discredit those who feel premium cables make a difference. Attack, and you shall be attacked. You & I have seen it in every cable thread. I respect your opinion--I too think there are more important things to focus your audio dollars on, but if someone wishes to experiment with other cables, why does that have to become a voo-doo science free-for-all everytime? I think the most important aspect with cables is good construction, good materials, and a topology that I can relate some sense to--but, if that cable sounds dry and 2-dimensional in my system--it has to go. I also believe that you don't have to spend alot of money to get there, of course that's my personal opinion.
    Bottom line, no one is interested nor needs to explain their choices.
  • steveinaz
    edited October 2010
    The problem is, the topic is discussed (both sides) as if it were fact. It's not, on either side of the argument. It's personal opinion and observance by individuals. You may as well discuss creationism vs evolution--people will believe what has been demonstrated to them in a personal, meaningful way.
    Brock's "ice cream" analogy was spot-on. It's just that simple.
  • jinjuku
    edited October 2010
    headrott wrote: »
    Greg
    Hence the friendly wager :rolleyes:
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2010
    steveinaz wrote: »
    As someone who doesn't really care either way, I agree with this.
    Someone compared it to a color blind person insisting that the color red doens't exist. The problem with that comparison is that you can show a spectrum analysis of light and show that red DOES exist. These differences that people claim to hear with things like broken in cables aren't measurable that I have seen, nor is there some concrete science to any of it. So for someone who doesn't hear it, it makes it hard to accept. Those of you who do "believe" and hear these things, you have to understand this on some level, don't you?
    edited October 2010
    WilliamM2 wrote: »
    Why don't you answer my question as to why you care so emphatically? Why?
    I'm not trying to convince you there is a difference, I'm trying to debate and understand why you care so much about proving there is no difference when you have clearly stated you can't hear a difference. And why you need my ears to prove/disprove what you've already stated you hear with your ears.
    I get it, I undestand not everyone can or does or cares to hear a difference; that's all fine and dandy. You can't hear a difference case closed, I'm not trying to convince you otherwise. I don't understand why you want me or Steve or Mike or Larry to experiment with our ears and prove to you, an admitted person who can't hear a difference, that we can hear a difference.
    How do you benefit from that kind of experiment? This question has been asked several different times in several ways, yet you and others elude it. I'm not sure why, unless you are just arguing to argue or some sort of chest pounding. Or perhaps you enjoy beating a dead horse.
  • vc69
    vc69 Posts: 2,500
    edited October 2010
    bobman1235 wrote: »
    Absolutely. The problems in discussing it openly surface when people who can't hear the difference insist that those of us who can (like the op) are fools.
    We can accept their inability to hear the difference. They appear to be unable to accept the FACT that we can.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • jinjuku
    edited October 2010
    vc69 wrote: »
    Then take the wager...
  • WilliamM2
    edited October 2010
    heiney9 wrote: »
    I'm curious why other's continue to cling to beliefs that have been disproven time and time again. And why they try to push them as fact.
    And for someone who's not trying to convince anyone, you sure have posted a lot in this thread. Although I sure wouldn't call it a debate.
  • ohskigod
    ohskigod Posts: 6,505
    edited October 2010
    WilliamM2 wrote: »
    no one is threatened that you do not hear a difference, they are insulted when you say people's experiences are "fairy tails"
    how can you honestly look at your above quote and think your not one of the instigators here? not a people person are ya.
    you never hear a differenc with cables? god bless ya. it's not like I spend huge money on cables, it isnt worth it to me...but I have heard differences and believe cables do make a difference.
    I dont care if you dont believe it, I do care when you emphatically tell me they dont, to me, despite what my ears tell me.
    good grief, how can facts be so hard nosed in something as subjective as audio anyway?
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
    edited October 2010
    I am trying to understand why it's up to me to prove to you a difference exists? I never asked you to prove to me, with your ears, that a difference doesn't exist. I have always accepted what people believe based on whether or not they have tried to hear a difference.
    You and others seem hell-bent on forcing those of us who have heard differences prove it to you, with our own ears, that a difference exisits when you've already stated in your experience a difference doesn't exist.
    That is the most ridiculous paradigm I've ever heard of.
    edited October 2010
    Operator, please connect me back to planet Earth.
  • vc69
    vc69 Posts: 2,500
    edited October 2010
    jinjuku wrote: »
    I am not in least bit interested in your wager. Unlike you, I have absolutely zero interest in listening to YOUR cables. I love to listen to MY cables, which are the finest I can afford and which, by way of much trial and error, suit me best.
    Break in? I dunno, all my cables were purchased used. So as to that, I have no real-world experience. I will say that given the information I have read and given the kind of cables I have found to sound best in my rig, cable break-in is not a myth.
    Like Steve said, I can't tell you which of your cables are new and which are not, but I'd bet a hundred dollars I could hear the difference between yours and mine in my rig. Any day of the week.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • steveinaz
    edited October 2010
    nevermind.
  • ohskigod
    edited October 2010
    vc69 wrote: »
    but would you invite these people into your home? :D
