Hardware Rings for your Passives and MW6XXX
1356712
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2010
    I have three pairs of the 1989 version CRS+ and they all only have 4 screws holding the passive. I assumed that Polk didn't find any advantage to using 8 screws for the 10" passive. There is a metal mesh screen the goes over the passive, so that might also be a contributing factor for fewer screws.
    Toolfan66 Posts: 18,082
    edited June 2010
    Should I use all 8 then??? I know the monitor 10's and 7's only use 4 screws as well..
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2010
    The CRS's will be a nightmare with trying to attach the grills on straight and correctly. Might be easiest to run the CRS's with the metal grills off. Majority of the screws are put in at a angle.
    I think 4 screws holding down the 10" passive will be easiest.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Larry, no rush at all! Take your time!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    F1nut Posts: 51,812
    edited June 2010
    I drilled out the extra 4 screw holes for the PR's on my CRS+'s....no biggie. Make them with 8, please.
    heiney9 Posts: 25,450
    edited June 2010
    Larry take your time no big rush. Are you planning on doing an 8" for the PR's in a Monitor 5? I just Mortited mine so I'd prefer not pull it to make a template, but if you need one I can probably do it. I need specific instructions as to what measurements you would need.
  • DarqueKnight
    edited June 2010
    4 is enough, but if you don't mind doing the extra work to add the additional 4 screws, I would like to have screws all the way around. Thanks.
  • comfortablycurt
    edited June 2010
    Are the 10" passives of the CRS's the same size as the 10" passives of my Monitor 7A's?
    If so, I might go ahead and order a set for my 7A's now.
    F1nut Posts: 51,812
    edited June 2010
    Ummmm.....10" is 10".
  • comfortablycurt
    edited June 2010
    Well, I realize that. I guess I should have worded that differently.
    Will the bolt patterns match up the same etc...?
    The MW's and the PR's on my 7A's are mounted on top of the baffle, rather than being set into the baffle. Will this make any differences as far as mounting them with these rings? Would the posts for the screws need to be a little longer or anything like that?
    I'm assuming that they'll work just fine though.
    While we're on the topic...
    I've seen a few people mention here that they drilled out the rest of the holes for their 10" PR's. The PR's on my 7A's use only 4 of the screw holes. Would you recommend drilling them out and using all 8 holes? I've never had any issues with air tightness or anything like that with my 7's. Will using all 8 screws couple the drivers to the baffle more efficiently? It'd be an easy enough tweak to do...so I'll probably go ahead and do it, unless anyone advises otherwise.
    Larry-Any word on whether or not rings will be available for the 8" PR's? If you make 8" rings as well, you should have every vintage Polk driver covered as far as I can tell. I'd assume that the rings for the MW's would work for the 6.5" PR's on the Monitor 5Jr's as well.
    So, here's my total order currently, for my SDA 2A's and my Monitor 7A's.
    2A's-two midwoofers, and one 12" PR per speaker
    7A's-one midwoofer and one 10" PR per speaker.
    So, I'd need six midwoofer rings, two 12" PR rings and two 10" PR rings altogether.
    As myself and others have already stated, take your time! This is an awesome thing that you're doing for Club Polk!! You're truly one of the members that makes this place as great as it is. Keep up the good work!
    edited June 2010
    Rings will hit the laser in the morning.. Yes I am going to work just for you guys!!!!
    H9 I will need some help with the M5's. I'm guessing about 8-1/4"
    Thanks,
    Larry.
  • agfrost
    agfrost Posts: 2,471
    edited June 2010
    Larry, I've got RTA11TLs, but I'll take 4 rings for my MW's, please.
    Jay
    Jay
    edited June 2010
    I cut about 200 6.5 rings before I left work today, I will post some pics tomorrow.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2010
    :eek: Nice Larry!! You da man.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited June 2010
    Larry,
    I'll take 8 6.5" rings for my SRS2s, and 2 15" for the passives, please.
  • geoff727
    geoff727 Posts: 546
    edited June 2010
    Larry, I'm interested in a total of 14 mid-bass rings and 8 rings for the 10" passives.
    Geoff
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2010
    "Ok" I have the Dimensions for the 10" 12" and 15" passives.
    Thanks Jesse!!
    On the 10" passive did Polk ever use all 8 holes in any of the models? I will hardware for all eight but I was just curious.
    This might seem slow for me to get all of this together, but I am slammed at work right now. As soon as I have everything ready to roll I will start going through the list and get PM's to to you guys. I don't want to hold on to your money to long, I want you guys to be able to pay and know you will see them within two weeks max.
    Thanks for being patient,
    Larry.
    Larry, I haven't heard anything, have you taken formal orders yet??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited June 2010
    vmaxer wrote: »
    I will start emailing you guys this week as I get these together..;)
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    Wow, this is great Larry! Glad you are doing this so quickly! :) I'll be doing a upgrade to my SDA 2B's, and would love to have these before I put them back together with the mortite. You Da Man!!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • schwarcw
    schwarcw Posts: 7,358
    edited June 2010
    Hi Larry! I'm in for 12 of the rings for my SDA 2.3's. Just say when and I'll send money.
    Regards,
    Carl
    edited June 2010
    Play Me!!!!
    Click on pic to play..
    nooshinjohn Posts: 25,932
    edited June 2010
    Larry, the work you put yourself through to help us maintain and improve our SDA's is simply amazing. You are one of many reasons this place is such a great place to be... I hereby nominate you for Polkie of the Year.
    As your prize, I think Doro and company need to kick in some LSi-25's with free shipping.
    edited June 2010
  • helipilotdoug
    edited June 2010
    +1 on that!!:D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited June 2010
    Play Me!!!!
    Oh Yeah! That's a amazing machine!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited June 2010
    Beautiful rings! Can't wait to get them!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    edited June 2010
    It is!!! 4400 watts of Amazing.:cool:
  • headrott
    headrott Posts: 5,496
    edited June 2010
    That video is great to watch. It's amazing how fast and yet so precisely it moves. Thanks Larry.
    Greg
  • helipilotdoug
    edited June 2010
    LOL You got that at Wally World for $89.77 right??? :D Seriously, I'll bet the cost of that machine is astronomical! But for the work it can do, well worth the cost.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    edited June 2010
    Between seven hundred, and eight hundred thousand. Depends on the loader you get with it. If you want one that is, but who wants to load 48" X 120" sheets of steel all day? Getting a loader with it is the only way to go.
