Amazingly disappointed
1356
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    jaxwired wrote: »
    1. We'll just have to disagree on that one. Half the listening public doesn't even acknowledge the existence of "burn-in" and I think the half that does believe in it would tend to side with me regarding the relatively subtle nature of the changes.
    2. Have you compared them side by side? Nope. How do you know how they compare. Your impression is entirely based on reputation and conjecture. The OP has actually heard them both.
    3. The What HiFi review IS very pertinent because many response to the OP write him off as being an ignorant newbie. I think most people will agree that the What HiFi review staff are NOT ignorant newbies. So it's possible that the OPs assessment is correct as it does concur with certain seasoned audio reviewers.
    4. Same answer as number 1.
    5. LOL. Again, I don't believe burn-in can be so dramatic that an amp will appear to actually be defective it sounds so bad prior to full burn-in. But apparently you do. Again, we differ.
    6. Possible? Please...
    That's pure BS ONE guy made an accusation of the OP having an alterior motive the rest of us have been trying to educate the OP.
    So you don't believe in burn-in? Why then do manufacturers include in their manuals that a burn-in period is necessary? They designed it, they know what components they used to build it, they've tested it, etc, etc....
    "Seasoned Audio Reviewers" with an agenda.
    I've experienced burn-in with every new product I've purchased, including cables and the difference from out-of-the-box to after burn-in is NOT subtle.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited January 2010
    Sounds like the Krell was defective. Having to dial it up to 80% for sound is very suspect.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • hearingimpared
    edited January 2010
    Hawkeye wrote: »
    Gordon
    Or a massive impedance mismatch between the pre and the amp. If that's the case then no amount of burn-in is going to fix that particular problem. It may tone down a bit like having to turn the volume up to 60%. I have the same problem with all my front ends having an impedance mismatch with my integrated. With my TT/phono pre, I sometimes, depending on the LP have to turn the volume up to 3:00 before getting the proper volume and SQ I like.
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2010
    It's an integrated, so scratch that.
    SOPA
  • jaxwired
    jaxwired Posts: 201
    edited January 2010
    I never said if I believe in burn in or not. I merely stated that burn in won't turn "crap" into "wow". I'll stand by that. I also think that 99% of manufacturers would agree with my position on that. I've never heard a manufacturer state something like "prior to completed burn-in, the sound will be dramatically different and so poor the listener may be convinced the product is defective." The idea that burn-in has that dramatic an impact on the sound quality is absurd. I've read dozens if not hundreds of reviews and burn-in is almost always described as a subtle change.
    NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    xcapri79 wrote: »
    He has it working with the UPA-2 but not the Krell.
    And? That doesn't have anything to do with the impedence mismatch scenario.
    Nonwithstanding, the Krell is an integrated.
  • concealer404
    edited January 2010
    jaxwired wrote: »
    I've had a few pieces that the sound quality was pretty dramatic. One very recently, as in in the lat two days.
    treitz3 Posts: 20,185
    edited January 2010
    jaxwired wrote: »
    I've never heard a manufacturer state something like "prior to completed burn-in, the sound will be dramatically different......The idea that burn-in has that dramatic an impact on the sound quality is absurd. I've read dozens if not hundreds of reviews and burn-in is almost always described as a subtle change.
    I can attest to burn in being quite real and undeniably dramatic. Not on all amps I have owned, but here's an example.
    The Odyssey Stratos SS amplifier. It's even stated in the Owner's manual as to what you should expect to hear. I heard the changes even before I read the manual and what he describes is what I heard to a "t".
    That said, burn in is not absurd. Manufacturers have stated it and most of the time, changes will be subtle. However, there are amps out there that apparently you haven't auditioned that will have a dramatic change during the burn in process.
    The Stratos aforementioned even has a three day warm up after being unplugged. There are various stages the amp will go through in a 3 day period after it is unplugged and allowed to cool that can make it go from decent, to sounding like ****, to sonic bliss on day three. I have observed it too many times as I had the amp for about two years in various rig setups.
    edited January 2010
    xcapri79 wrote: »
    I agree Jax, same with cables, they won't turn "crap" into "wow" either.
    BS. See above post. Damn, you guys need to get your ears on some more gear before you go shooting off at the mouth.
  • jaxwired
    jaxwired Posts: 201
    edited January 2010
    One thing that I've noticed about the "burn-in" process that I find suspicious and has never been answered by "burn-in" believers is, if burn-in is changing the sound of all this equipment, why is that "burn-in" always, 100% of time makes the sound better? Seems like since this mysterious process that is the subject of much conterversy exists, the change would sometimes be for the worse. I've yet to ever read a review that stated "sounded fantastic right out of the box, but after burn-in the sound quality degraded."
    I guess the manufacturers are just so good at designing for burn-in, that they get it right everytime. Always makes it better, never worse. Seems odd though...
    Still not saying I'm not a believer. It definately makes sense for speakers at the very least.
  • hearingimpared
    edited January 2010
    Ricardo wrote: »
    Whoops! My mistake.
  • hearingimpared
    edited January 2010
    jaxwired wrote: »
    Well you can read all you want but it is not the same as experience.:)
  • Zitro
    Zitro Posts: 864
    edited January 2010
    jaxwired wrote: »
    Agreed; this is what I never understood. I can understand break in for things with moving parts, so speakers makes sense. Car engines make sense, it being metal and the constant temp changes and friction and such. But a solid state amplifier with no moving parts? How can burn in really affect it that much. There are temp changes internally, yes, but can it really make THAT much of a difference? I noticed my NAD integrated sounds a bit better after it warms up, but I didn't notice any difference in sound as the days went by using it on a regular basis; sounded great out of the box. Eh, not going to say its not true, since I am pretty new to audio, but I've just never experienced it.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • hearingimpared
    edited January 2010
    Zitro wrote: »
    When you keep moving up the chain, you will.
  • concealer404
    edited January 2010
    jaxwired wrote: »
    I've actually had that happen to me with a couple pieces of gear. It could also be attributed to the "wow" factor wearing off, though.
  • doctor r
    doctor r Posts: 837
    edited January 2010
    The Krell website and numerous reviews refer to this Krell integrated as having "input trim controls" It could be that these came from the factory turn to minimal gain and need to be reset (going along with the thought that this amp should do "better" at 80% than is being described)
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • Matt34
    Matt34 Posts: 318
    edited January 2010
    Speaker burn in, yes it can happen and can be verified through measurments as the T/S parameters change(and it is still debatable if those changes are percivable by the human ear). Soild state electronics AFAIK have not been shown through credible 3rd party measurements to require a burn in process. I've experince what I believed were audiable changes but after measuring the amplifier it shows the same as when first measured. Its more than likely that your ears get used to the sound over a period of time hence why many manufactures support the burn-in process. Manufactures number one goal is to make money, I would take most of what they say with a grain of salt.
    So in other words, go with what you like. If within the returnable time period you still don't like the krell, send it back. You really have nothing to lose either way.
  • Matt34
    Matt34 Posts: 318
    edited January 2010
    Most importantly have fun with it and try out different settings and/or crossover points if you are using a sub as well as different kinds of music.
  • Hawkeye
    edited January 2010
    My amps sounded thin out of the box. It took about 75-100 hours until they opened up. What is interesting, they have to warm up for about 30 minutes before they sound full. This warm up period even happened with the SS pre I had so I know it's not the tubes in the new pre.
    Gordon
    2 Channel -
  • concealer404
    edited January 2010
    My amp sounds TERRIBLE for the first 45 minutes or so, then it starts to open up. This is why i just leave it on, so i don' have to plan ahead if i want to listen and not be infuriated by the crap that comes out of the system for the better part of the first cd.
  • Face
    Face Posts: 14,340
    edited January 2010
    Most preamps and amps have passive components in the signal path which need to break in, it's not as simple as a speaker's surround or spider breaking in.
  • hearingimpared
    edited January 2010
    Matt34 wrote: »
    "If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen
    Great quote Mike!
    edited January 2010
    Matt, you don't need a measurement to know what's going on. Your ears are the only tool required.
  • adabro
    adabro Posts: 212
    edited January 2010
    I'm a nervous buyer and super critical of my new components, waiting for burn in (whether valid or not) calms me down so I can get used to the new sound and be happy...
    heiney9 Posts: 25,549
    edited January 2010
    Hawkeye wrote: »
    Gordon
    This is because the amp, pre-amp, etc needs time to bias the output tranny's so they are working in their "sweet spot". My Aleph takes about an hour and you can hear it change.............from closed in, muffled, lack of dynamics, to very open, dynamic, precise, sweet, 3D, etc.....it's a fact.
  • concealer404
    edited January 2010
    Yeah, that and the fact that i'm working with 20+ year old caps in my amp. :p
    The pre i've got doesn't really take any time at all to "warm up."
  • hearingimpared
    edited January 2010
    My pre didn't come with a power switch because it's supposed to be on all the time. The manufacturer purposely designed it that way. I spoke to an engineer (quite a few times) of the company and he recommends that if I ever need to shut it down, when powering it up it would take 45 minutes to stabilize. I've noticed that after shutdown, (thunder storms or power outages) I've found it sounds best after being left on for two days.
  • concealer404
    edited January 2010
    I should research that... mine has a switch, and a standby button on the front. I wonder if putting it on standby keeps it "primed," if you will.
  • concealer404
    edited January 2010
    xcapri79 wrote: »
    Yeah. He and selkec aren't real subtle.
    Amusingly, even on that hilarious forum, there's still people telling him to let the Krell break in. Imagine that.
    edited January 2010
    xcapri79 wrote: »
    Sounds like he fits right in over at the Emo-lounge. What a newbie tool, giving a new piece of gear about an hour before deciding. He;s not at all serious about this hobby. No skin off my back.............just frustrating when someone comes here for opinions, advice and experience and totally dismisses what he's given. He belongs over there.
