SVS PB-13 Ultra Subwoofer
My room is 3750cf with 1500cf opening and my PB13 has no problems preasurizing the room
My room is 3072cf and a single Ultra-13 is more than enough.
But like Magasat16 says, you can never have too much GOOD bass!:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Who has two of these Monsters???
I would think you would need a large room(3750cubic ft or larger)
I have a pair of the rosenut PB13s. I love them dearly...:D I actually prefer the 20 Hz tune for music. I'll occaisionally run the 15 Hz tune. My set up was calibrated in 15Hz tune and gave a veryflat response with useable bass down to about 12 Hz. -
Yep its a big-boy with tons of output in the 20hz mode.
Yep, the duals are sick man! -
speakergeek wrote: »I have a pair of the rosenut PB13s. I love them dearly...:D I actually prefer the 20 Hz tune for music. I'll occaisionally run the 15 Hz tune. My set up was calibrated in 15Hz tune and gave a veryflat response with useable bass down to about 12 Hz.
Where do you have the Phase set 0, 90, 180?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Are they stacked or on opposite sides of the room?Speakers: SDA-1C (most all the goodies)
Stacked. It gives me a good FR actually. No major peaks or suck-outs. I may try opposite sides of the room though just to see how it sounds.
Here's my FR with the "stack" in 15 Hz tune:
I am looking forward to that!
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
landry_p2000 wrote: »I am looking forward to that!
The 15hz mode is very impressive, the Bass is a lil tighter and goes
a lil lower.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
speakergeek wrote: »Set at zero.
Yep, I prefer the 15hz mode with the 0 phase for now.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
You should post some pics...:) -
speakergeek wrote: »Stacked. It gives me a good FR actually. No major peaks or suck-outs. I may try opposite sides of the room though just to see how it sounds.
Nice ! You gotta love REW.Speakers: SDA-1C (most all the goodies)
Yep. It is pretty good. That's about as flat as I think I'll get it. -
speakergeek wrote: »Yep, the duals are sick man!
It must be nice!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
speakergeek wrote: »Yep. It is pretty good. That's about as flat as I think I'll get it.
Yep, I don't think you graph is even smooth. Good job.Speakers: SDA-1C (most all the goodies)
Both the VTF-3HO and SVS PB12-Ultra are excellent. You cant go wrong with either.
You might want to direct your question to Craigsub, as I believe he has tested these subs in an A/B type comparison.
Keep in mind that even if the VTF-3HO edged out the PB12-Ultra, SVS plans to unveil its next-generation subwoofers PB13-Ultra, etc in less than two weeks. If you arent in a rush, and dont mind spending a few hundred more 1200-1400, you might want to consider those too. -
JotGloky73 wrote: »SVS plans to unveil its next-generation subwoofers PB13-Ultra, etc in less than two weeks. If you arent in a rush, and dont mind spending a few hundred more 1200-1400, you might want to consider those too.
... did you mistype or are you just a couple of years late? The new sealed box subs are rolling out next year, SB12NSD, SB13Plus and SB16Ultra.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »
... did you mistype or are you just a couple of years late? .
Yeah, no kiddin'... (LOL!):) -
speakergeek wrote: »You should post some pics...:)
MY kid broke the dig camera at the Homecoming Dance, I will try to
pickup one this weekend. The Ultra-13 is in the Rosewood finish.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
The SVS PB-13 Ultra did a great job on the Max Payne Blu-Ray.
The Max Payne disc must have alot of low bass,because the SVS really
delivered:D:D:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
delivered:D:D:D
So did you actually end up trading the Klipsch dual subs for the PB13-U?
Not yet, but Im thinking about it-This PB-13 is a monster.
I would like to have two PB-13Ultras:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
The PB-13 Ultra Subwoofer is a Keeper:D
In the 15hz mode it is a MONSTER, it did an AWESOME job
on the new Transformers Blu-Ray. Maybe two???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Dual Wins!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Dual Wins!
If they are setup right but a single setup right will sound betterthan 2 that are not.Speakers: SDA-1C (most all the goodies)
This is true!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
The better job you do positioning your sub and eqing it before running Audessy the better result you will get out of Audessy.
A lot of people miss this point and think Audessy will fix it, wrong.Speakers: SDA-1C (most all the goodies)
What do you think about corner placement of the Sub?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I wonder what kind of correctly setup single sub will sound better than duals that are setup correctly.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
