Spearker cables..fact or fiction?
sTiLlLeArNiNg wrote: »I was merely adding a price per foot as a refference, care to add something usefull to the thread?
I've been making useful posts on this forum for the last 7 years. When are you going to start? -
Actually, what he said was useful. Pay attention.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
You know Tom, I was going to say something about that, but figured that since it already buzzed the tower once that a second time wasn't worth the effort.
Sorry i sounded like a dick but i'm looking for a more "in depth" answer than a one liner....
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
IF you want some solid advice . . . go buy some MIT cables. They are one of the single most effective and notably beneficial upgrades I have ever made. They are truly the same as making a significant preamp, amp or speaker upgrade. F1Nut makes a valid point. To a large degree, cables sold by the roll (foot) are very similar sounding and do not offer dramatic increases in performance.
Why do i need a set of $500 Mit's? In most case's i/you/we can buy the SAME cable as what is used in "premade" set's for cheaper and finish them of ourselve's
It's not hard to find termination's, cable sleeveing, heat shrink, quality solder, cable pant's etc....
like i said i'm just trying to understand all of this so i can make an informed purchase and get the best "bang" for my buck. That's why i refferenced price by the foot
TBH ihave a VERY limited income but i do like to have the best of what i can get....Media Room 7.1
HTPC
sTiLlLeArNiNg wrote: »Why do i need a set of $500 Mit's? In most case's i/you/we can buy the SAME cable as what is used in "premade" set's for cheaper and finish them of ourselve's
First, you don't need MITs to listen to music, but you did say you want the best. Well MIT is close to what some consider to be the best.
Two, MIT is not just heatshrink and wire. Those boxes and the electronics therein are more than you could ever make in your garage workshop, and they do a lot to improve the sound.
Third, Bruce Brisson has a DIY homepage for making your own MIT cables, but they are not the best of what MIT has to offer. http://www.diyaudiocable.com/.
Fourth, if you are really serious about this hobby, the only way to really measure results is by hearing the product your self. And remember: "Not everything that can be counted counts, and not everything that counts can be measured." - Albert Einstein. -
sTiLlLeArNiNg wrote: »Sorry i sounded like a dick but i'm looking for a more "in depth" answer than a one liner....
You should probably put forth your best effort to try different things on your own and come to your own conclusions. Nobody here can tell you what cables will be better or sound better to you.
Why don't you try some of the different cables that you're speaking of, and report back with your findings so we can all learn from your experiences.
You can find Kimber on the cheap if you look in the right places. I'm a fan of Kimber, and I also have very positive but limited experience with MIT. I too would like to put MIT cables in one of my systems some day, but am not in a position to do so right now. So there you have it. Go to your local hi-fi shops and talk to the guys there. Many places will let you take cables home to try before you buy. Or try Signal Cable. I think Frank will let you try some before you buy as well. Signal Cable is probably one of the best budget bang for the buck wires out there. Compare them all to some home depot lamp chord. Maybe you'll notice a difference, maybe you won't. -
+1 regarding Signal CableHT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
oops, editedVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
...and in closing, there's no such thing as a "spearker" cable.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
What the heck is spearker cable????
Stop making me spit coffee at the screen.....jeez man.:D You are right though,once around for the slow folks,after that,the hell with it.HT SYSTEM-
lsi 9's -
NAD SS rigs w/mods
GIK panels -
Who'd a thunk we weren't just justifying our expenditures?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Gotta love the comments at the end of the article. Naysayers will be naysayers to the grave. :rolleyes: -
So I see the Signal Cable offers 30 day in home trials. You just have to worry about the shipping. Cool.
From the Signal Cable website on their 'Analog Two' HT RCA snake cable: this is a reference quality interconnect
I believe AQ unfortunately charges a 20% restock fee. I don't know about KK or MIT.
With a decent amount of ID speaker companies allowing for in home trials I am not sure why with something that isn't as labor intensive or bulky to ship as cables isn't offered. I would think it would be a way to increase sales. -
Gotta love the way "believers" will accept anything the manufacturer's claim without question. :rolleyes: -
As far as their research: For it to have any scientific merit it has to be reproducible. That is the gist of what some of the comments are getting at. I would simply wait for the peer review process to finish. -
Gotta love the comments at the end of the article. :rolleyes:
I do love them. I really do.
"On the other hand, if you want to insult us "wallpluggers" then expect to be mocked since you are apparently unable to understand basic science." Posted Tue Oct 6, 2009, 8:59 AM — By Tim L
I did not see in this case, and never have seen, an example of a cable enthusiast insulting or mocking someone only because they chose not to use a higher performance power cord.
"It really irritates me when I see a five or six figure system sitting in a room with glass walls and marble floors. Inevitably these are the systems with the most expensive cables and other sorts of "tweaks"". Posted Tue Oct 6, 2009, 12:05 PM — By Tim McGeary
I often see comments like this. I don't see any rational reason for anyone to get "irritated" by the wall and floor finishes someone else chooses for their listening room. Some people just like a more "lively" room. It's their house.:)
By the way, I have been working on some power infrastructure upgrades for my home theater system. The discontinued xStream Statement SC and xStream Premier SC power cords are being "dumped" at xStreamly attractive prices.
I just picked up nine 2 meter Statement SC power cords at $125 each (+$10 each for shipping) for the components in my HT system. Regular retail was $629. I am replacing all of the Signal Cable MagicPower cords.
More later.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Hi William,
We've never "met" before in the forums I guess, but from what I've read above, it seems you've been at it a long time and don't give much credence to the effectiveness of expensive wire.
I'm sure some do, but I don't give a lot of weight to published specs.
I do listen to music between 6 and 10 hours a day, 6 and sometimes 7 days a week sitting dead center in the "SDA sweetspot" of a fairly decent system.
I've personally found by listening, that various interconnects and speaker cables make a huge difference in the quality of sound coming out of my speakers. I've also found, almost to a 100% correlation, that the higher priced wires sound better.
Respectfully,
GregVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
DarqueKnight wrote: »
"It really irritates me when I see a five or six figure system sitting in a room with glass walls and marble floors. Inevitably these are the systems with the most expensive cables and other sorts of "tweaks"". Posted Tue Oct 6, 2009, 12:05 PM By Tim McGeary
I find criticisms such as the one described here are brought by people who may not be able to afford nicer gear, and feel someone who can afford nice gear and furthermore has the audacity to put it in a nice house . . . well, that person is a real snobby **** in their book. -
inspiredsports wrote: »I've personally found by listening, that various interconnects and speaker cables make a huge difference in the quality of sound coming out of my speakers. I've also found, almost to a 100% correlation, that the higher priced wires sound better.
Respectfully,
Greg
I used to think the same thing. Then I did an honest blind listening test. Suddenly those "huge" differences disappeared, not just for me, but for all the other participants as well.
For some reason, we could all hear the "huge" differences when we knew which cables were being used, go figure. -
OK, I think the issue is material that is not suitable for sound (IE: Glass walls and marbles) ratter than the looks. Big $$$ in sound equipment which is not optimized due to poor sound management material used for walling/ceiling/flooring. That is the point being made, NOT the looks or the expense.SolidSqual wrote: »I find criticisms such as the one described here are brought by people who may not be able to afford nicer gear, and feel someone who can afford nice gear and furthermore has the audacity to put it in a nice house . . . well, that person is a real snobby **** in their book.
Now, if you go back up in the discussion, you will notice that many don't see blind testing as an accurate mean to prove the usefullness or uselessness of the cable comparision.I used to think the same thing. Then I did an honest blind listening test. Suddenly those "huge" differences disappeared, not just for me, but for all the other participants as well.
This subject has proven to be a very sensitive issue and there is no way to solve this issue with any technical, scientific or practical experience. Technical and scientific will say nay while the listener will say yay and your own post proves this by your own statements:
Your personal listening experience said YES while your technical experiment said NO. So, now you choose to trustt the technical/scientific testing over the listening experience while many choose to trust their listening experience instead. Thus, the entire discussion is simply subjective to ones preference, belief and/or experience.Then I did an honest blind listening test. Suddenly those "huge" differences disappeared,
Cheers!
TKDARE TO SOAR:
Yes, I understand that. I'm just talking about the underlying motivation whether subliminal or otherwise.
EDIT: Some people like to badmouth gear they can't afford. And then, they convince themselves the gear is not worth the money so they can feel better about it. It's the "snobby audiophile" complex. -
SolidSqual wrote: »Yes, I understand that. I'm just talking about the underlying motivation whether subliminal or otherwise.
Touche' .:D -
SolidSqual wrote: »Some people like to badmouth gear they can't afford. And then, they convince themselves the gear is not worth the money so they can feel better about it.
What? You think it's "sour grapes"?
Nahhhh...it couldn't be that. That would be wrong...and remember: naysayers are the "good" guys.;)
I absolutely HATE, HATE, HATE expensive cables.
Why? What have expensive cables...and the people who use them...ever done to you?~DK
Nothing! I'm just mad because the only kind of cable that can take the heat down here is 0 gauge steel welding cable. Proud and loyal citizen of the Digital Domain and Solid State Country! -
What's worse is some people like to badmouth good gear (IMO) that every one can afford cough Emotiva cough
The irony here is, he is an ex-Emotiva owner.What's worse is some people like to badmouth good gear (IMO) that every one can afford cough Emotiva cough
