Spearker cables..fact or fiction?
1585961636471
  • inspiredsports
    inspiredsports Posts: 5,502
    edited October 2009
    Here is the name that you wanted from the AVS forum, I gave it up the search. You do it yourself: Penngray ( twice threatened physical fight in Florida to other posters in two different posts for disagreeing with him) . I have better thing to do in line than sitting here shooting the bull. Have a good life!
    Post #2001 a Spacey Club Polk Oddity :D
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    jimmydep wrote: »
    Gentlemen, why don't you take your disagreement back to the AVS forum, and lets keep this thread on topic........Please.
    That being said....
    I see some cable's implement many thinner strand's in their product whereas some use less but thicker strand's, why?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • phuz
    phuz Posts: 2,372
    edited October 2009
    That being said....
    Skin effect.
  • sTiLlLeArNiNg
    edited October 2009
    phuz wrote: »
    Skin effect.
    Ok thank's:)
    And which is better for what? I see some cable's costing $15+ per foot with both the many thin strand's and other's (also priced at $15+ per foot) with less strand's but thicker gauge :confused:
    I also see some cable's that implement both in the same cable! They have many small gauge conductor's only on the positive lead and less but thicker gauge on the negative lead. Sorry for all the Q's just trying to get my around all these different type's of cable's :o
    Cheer's!
    Media Room 7.1
    HTPC
    F1nut Posts: 51,798
    edited October 2009
    If you're still pricing cable by the foot it isn't going to matter what that cable is made out of.
  • sTiLlLeArNiNg
    edited October 2009
    I was merely adding a price per foot as a refference, care to add something usefull to the thread?
    Media Room 7.1
    HTPC
    F1nut Posts: 51,798
    edited October 2009
    I've been making useful posts on this forum for the last 7 years. When are you going to start?
    treitz3 Posts: 20,012
    edited October 2009
    Actually, what he said was useful. Pay attention.
    F1nut Posts: 51,798
    edited October 2009
    You know Tom, I was going to say something about that, but figured that since it already buzzed the tower once that a second time wasn't worth the effort.
  • sTiLlLeArNiNg
    edited October 2009
    Sorry i sounded like a dick but i'm looking for a more "in depth" answer than a one liner....
    :o
    Media Room 7.1
    HTPC
  • SolidSqual
    SolidSqual Posts: 5,218
    edited October 2009
    IF you want some solid advice . . . go buy some MIT cables. They are one of the single most effective and notably beneficial upgrades I have ever made. They are truly the same as making a significant preamp, amp or speaker upgrade. F1Nut makes a valid point. To a large degree, cables sold by the roll (foot) are very similar sounding and do not offer dramatic increases in performance.
  • sTiLlLeArNiNg
    edited October 2009
    Why do i need a set of $500 Mit's? In most case's i/you/we can buy the SAME cable as what is used in "premade" set's for cheaper and finish them of ourselve's :o
    It's not hard to find termination's, cable sleeveing, heat shrink, quality solder, cable pant's etc....
    like i said i'm just trying to understand all of this so i can make an informed purchase and get the best "bang" for my buck. That's why i refferenced price by the foot :o
    TBH ihave a VERY limited income but i do like to have the best of what i can get....
    Media Room 7.1
    HTPC
  • SolidSqual
    edited October 2009
    First, you don't need MITs to listen to music, but you did say you want the best. Well MIT is close to what some consider to be the best.
    Two, MIT is not just heatshrink and wire. Those boxes and the electronics therein are more than you could ever make in your garage workshop, and they do a lot to improve the sound.
    Third, Bruce Brisson has a DIY homepage for making your own MIT cables, but they are not the best of what MIT has to offer. http://www.diyaudiocable.com/.
    Fourth, if you are really serious about this hobby, the only way to really measure results is by hearing the product your self. And remember: "Not everything that can be counted counts, and not everything that counts can be measured." - Albert Einstein.
  • phuz
    phuz Posts: 2,372
    edited October 2009
    :o
    You should probably put forth your best effort to try different things on your own and come to your own conclusions. Nobody here can tell you what cables will be better or sound better to you.
    Why don't you try some of the different cables that you're speaking of, and report back with your findings so we can all learn from your experiences.
    You can find Kimber on the cheap if you look in the right places. I'm a fan of Kimber, and I also have very positive but limited experience with MIT. I too would like to put MIT cables in one of my systems some day, but am not in a position to do so right now. So there you have it. Go to your local hi-fi shops and talk to the guys there. Many places will let you take cables home to try before you buy. Or try Signal Cable. I think Frank will let you try some before you buy as well. Signal Cable is probably one of the best budget bang for the buck wires out there. Compare them all to some home depot lamp chord. Maybe you'll notice a difference, maybe you won't.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited October 2009
    phuz wrote: »
    +1 regarding Signal Cable
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • inspiredsports
    edited October 2009
    oops, edited
    NAD SS rigs w/mods
    GIK panels
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2009
    ...and in closing, there's no such thing as a "spearker" cable.
  • speakergeek
    speakergeek Posts: 555
    edited October 2009
    What the heck is spearker cable????
    tonyb Posts: 33,072
    edited October 2009
    Stop making me spit coffee at the screen.....jeez man.:D You are right though,once around for the slow folks,after that,the hell with it.
  • inspiredsports
    edited October 2009
    Same difference as "spearkergeek" :D
    NAD SS rigs w/mods
    GIK panels
  • Face
    Face Posts: 14,340
    edited October 2009
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Face wrote: »
    Who'd a thunk we weren't just justifying our expenditures?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    F1nut Posts: 51,798
    edited October 2009
    Face wrote: »
    Gotta love the comments at the end of the article. Naysayers will be naysayers to the grave. :rolleyes:
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2009
    So I see the Signal Cable offers 30 day in home trials. You just have to worry about the shipping. Cool.
    From the Signal Cable website on their 'Analog Two' HT RCA snake cable: this is a reference quality interconnect
    I believe AQ unfortunately charges a 20% restock fee. I don't know about KK or MIT.
    With a decent amount of ID speaker companies allowing for in home trials I am not sure why with something that isn't as labor intensive or bulky to ship as cables isn't offered. I would think it would be a way to increase sales.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2009
    Gotta love the way "believers" will accept anything the manufacturer's claim without question. :rolleyes:
  • jinjuku
    edited October 2009
    As far as their research: For it to have any scientific merit it has to be reproducible. That is the gist of what some of the comments are getting at. I would simply wait for the peer review process to finish.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited October 2009
    Gotta love the comments at the end of the article. :rolleyes:
    I do love them. I really do.
    "On the other hand, if you want to insult us "wallpluggers" then expect to be mocked since you are apparently unable to understand basic science." Posted Tue Oct 6, 2009, 8:59 AM — By Tim L
    I did not see in this case, and never have seen, an example of a cable enthusiast insulting or mocking someone only because they chose not to use a higher performance power cord.
    "It really irritates me when I see a five or six figure system sitting in a room with glass walls and marble floors. Inevitably these are the systems with the most expensive cables and other sorts of "tweaks"". Posted Tue Oct 6, 2009, 12:05 PM — By Tim McGeary
    I often see comments like this. I don't see any rational reason for anyone to get "irritated" by the wall and floor finishes someone else chooses for their listening room. Some people just like a more "lively" room. It's their house.:)
    By the way, I have been working on some power infrastructure upgrades for my home theater system. The discontinued xStream Statement SC and xStream Premier SC power cords are being "dumped" at xStreamly attractive prices.
    I just picked up nine 2 meter Statement SC power cords at $125 each (+$10 each for shipping) for the components in my HT system. Regular retail was $629. I am replacing all of the Signal Cable MagicPower cords.
    More later.
  • inspiredsports
    edited October 2009
    WilliamM2 wrote: »
    Hi William,
    We've never "met" before in the forums I guess, but from what I've read above, it seems you've been at it a long time and don't give much credence to the effectiveness of expensive wire.
    I'm sure some do, but I don't give a lot of weight to published specs.
    I do listen to music between 6 and 10 hours a day, 6 and sometimes 7 days a week sitting dead center in the "SDA sweetspot" of a fairly decent system.
    I've personally found by listening, that various interconnects and speaker cables make a huge difference in the quality of sound coming out of my speakers. I've also found, almost to a 100% correlation, that the higher priced wires sound better.
    Respectfully,
    Greg
    NAD SS rigs w/mods
    GIK panels
  • SolidSqual
    edited October 2009
    I find criticisms such as the one described here are brought by people who may not be able to afford nicer gear, and feel someone who can afford nice gear and furthermore has the audacity to put it in a nice house . . . well, that person is a real snobby **** in their book.
  • WilliamM2
    edited October 2009
    Respectfully,
    Greg
    I used to think the same thing. Then I did an honest blind listening test. Suddenly those "huge" differences disappeared, not just for me, but for all the other participants as well.
    For some reason, we could all hear the "huge" differences when we knew which cables were being used, go figure.
