Spearker cables..fact or fiction?
1535456585971
  • inspiredsports
    inspiredsports Posts: 5,502
    edited September 2009
    . . . It's like lightman in the bushes in your front yard eek:
    keiko wrote: »
    now i'm really gunna vomit. :p
    yep :D:D:D:D
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • mantis
    mantis Posts: 17,433
    Why must a good topic go bad? Why clown it?
    I'm gonna go on record with the following statements....if anyone is listening.
    Wire makes a difference and I'm going to tell you why.
    First off you need to figure out the job at hand. lets stick with the topic at hand, speaker wire. You need to figure out the spec's of the given speakers. the range which they work in. Are they full range? meaning 20hz to 20khz? Not many speakers can claim that! I'll use mine as a example I own the Definitive Technology Mythos ST for main speakers. They are rated at 14hz to 30khz which means they are full range. They cover the required frequencies that make a full range speaker. So in my settings I will run them Large.( The 14hz I don't believe , I will be testing that very soon, I'm thinking maybe 22hz or so we shall see).
    My amp is a receiver which puts out 140 watts into a 8 ohm load. My speakers so happen to be 8 ohms. Nice. Ok they are also 93db but for speaker wire that does mean a little but not that much.
    So now comes one of the most important parts , the length of the run. Mine are 8 feet long so I need to use the proper gauge which would be 16 gauge. I'm using 14 but I'm anal like that. Not that 16 wouldn't get it done, I prefer for no other reason then I like a fatter wire. There I said it.
    I also choose a wire that is Silver plated. For no other reason I like the way it sounds. It's not a requirement to get the sound to the speakers. Cooper conductors do a fine job without hardly any loss(which is the goal by the way).
    So I make sure I don't make antenna's out of my speaker wire and Away I go. I used to have much higher end wire , I still own some but I achieed the goal in getting the signal there the way I like it and I don't see the need to spend the extra money (That I don't have) on more wire.
    So my advise it this, get it right and be cool with it. All those fancy wires don't Improve the sound quality over any speaker wire that is proper for that task. It's what I have learned over the years.
    I will also add this , Different brands sound different but the difference's are so damn small it's questionable if it's worth the extra money. If you have extra money to throw at your system, then go have fun and spend the time like I did and money and find out the truth on your own. Once you figure it out , you will be at peace with it (like I think I am)
    Dan
    F1nut Posts: 51,794
    Dan speak for, I don't have a clue.
  • SolidSqual
    SolidSqual Posts: 5,218
    I like my MITs because they make me feel superior to people without boxes on their cables.
  • inspiredsports
    SolidSqual wrote: »
    I second that. :)
    Plus if you can handle the challenge MIT cable management presents, you could probably run a small country. :D
    And Dan, it's hard to be serious 1.8 X 10 to the 2 in ! (yes, the post count has gotten so large I need sci. not. to keep track)
    NAD SS rigs w/mods
    GIK panels
  • Cpyder
    Cpyder Posts: 514
    I second that. :)
    I think you mean 1.8x10^3. What you said would be 180.
  • inspiredsports
    Cpyder wrote: »
    Correct, thanks for the catch, I am truly going insane following this thread.
    NAD SS rigs w/mods
    GIK panels
  • TECHNOKID
    TECHNOKID Posts: 4,298
    seafire wrote: »
    Yawwwwwn :d
    Back from the dead, are you? Looks like this is the only thread of interest, right ;) We all tought you were dead but your profile indicates you gets burst of life back each and every time this thread gets a new breath, right ;)
    shack wrote: »
    Ok...maybe using an eq is somewhat humorous. Do they still make those things?
    Tons of EQs are still being made as they are widely used in the proffessional area. We probably have 20 here in our Ottawa office (us and our sister company). Most of them are presently out on events as their seem to be only 3 lefts at the shop. However, I fully agree with you using an EQ as cable management in home isn't as appealing as high end cables but who knows, might be the least expensive of the 2 options in many cases (just depends on the $$$ value of the HE cables). EQs are fine for sound management in large venues where the soundproofing is somewhat not the best. I wonder if the corporate sector has ever tought of using HE cables for such? Probably not as the engeeneers probably tought it is more hobby like than efficient wise ;)
    SolidSqual wrote: »
    Cables are a joke. In fact all speakers sound the same to me. Just buy whatever looks good in your living room.
    SolidSqual wrote: »
    Nope no wife. I just like to impress people with gear that looks outta this world. I don't think I've ever actually turned my system on for more than five minutes at a time. I usually just throw in a Master P track to impress them with sloppy bass.
    Humm, some might be seeing the light ;)
    shack wrote: »
    I keep hearing that...but I have never been able to figure out how to integrate one of these into my rig...:confused:
    Looks like you are using the wrong type of coat hanger :( Maybe you ought to try the metal type :confused::p
    Again, "let it be or let it die?" As many, I tought this thread was dead for good but :eek::confused::p Maybe a little pie for a change right Keiko :D
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    treitz3 Posts: 20,010
    Some folks just don't get the humor.......... :rolleyes:
  • TECHNOKID
    treitz3 wrote: »
    My post was also met to be funny ;) (used the wrong face originally)
    DARE TO SOAR:
    Well then, I guess I'm "some folks" today, eh? My bad. :o
  • anhchungdoan
    anhchungdoan Posts: 760
    There are differences in " sound" from different hi-end cables. The problem is you will not know which one is to your liking. I spent some good money on the Harmonic Technology speaker cables and they sound "dead" / " non-musical" on my Krell 400xi. While a simple Kimber 8 TC makes me happy. Is it a hoax or is it not, only you can try them out and only you can answer. Not necessarily an improvement. Also just to mention that I tried the PS audio Power Cord on my Krell 400 xi, the first few days, it was amazing in details and clarity but after a week or so " where the hell is my treble"...Why? I dunno but a few guys over Audiogon having the same experience. So, as anything else, it's your listening skill, your equipments and your cables= system synergy= happy listening. I agree there is a lot of myth and rip-off about cables but the truth is it 's you and your own ears. If you do not hear an improvement then why bother but if the guy next to you can hear the difference then it's his money let him be.
  • kawizx9r
    kawizx9r Posts: 5,150
    I wish such close-minded people (in terms of speaker cable/IC's/etc) can just go by that last statement I quoted you on. :cool:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • madmax
    madmax Posts: 12,434
    It would be foolish for someone to pay high prices for cables if they cannot hear a difference. Lets face it, there are some cool "looking" cables out there for not much more than the standard grade cost. For that matter you could dress up something yourself for not much $$.
    madmax
    Vinyl, the final frontier...
  • LessisNevermore
    LessisNevermore Posts: 1,519
  • esowden
    esowden Posts: 55
    I can't believe this thread is up to 62 pages...
    Den
    Parasound 2100
    Parasound 2125
    Denon DCM-390
    LG BD390V
    Martin Logan Preface(x2)
    Denon AH-D2000
    Bedroom
    Adcom GTP-350
    Parasound HCA-800II
    Panasonic DVD-S54
    Denon AH-2000
    Polk S4(x4)
    ಠ_ಠ
  • concealer404
    concealer404 Posts: 7,440
    I can't believe how awesome this thread is.
    I'm going to read it from start to finish tonite, and it better have the answer to my life's existence in it's pages, or else i'm going to RAAAGGGEEEEE
  • Flash21
    Flash21 Posts: 316
    esowden wrote: »
    I can't believe you just added...nothing...to a 62 page thread... ;)
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • anhchungdoan
    I have to agree and disagree with both sides of the fence. First of all, if a person own a low-end or mid-end gear, it makes no sense to spend $$$ on ICs and speaker cables since there is not much to hear in improvement. You cannot har something it is not there from the first place no matter how much $$$ you spend on wires. Secondly, the hi-end ICs and speaker cables and power cables ( no I am not talking abt Monster, Mr. Lee) are designed differently and it is not necessary an improvement eventhought they do sound differently. For example, I have been toying with Kimber PBJ, Hero, Silver streak ICs for the last 5/ 10 years but I cannot say which designs are best suit my system. PBJ: high, clear in treble but will be harsh with bright recording, Hero is bloating in bass and mid-range but lacking the "spark" in the hi frequency, Siverstreak is very smooth and open but lacking of bass. I have been playing with Krell, Bryston gear and speakers are the Martin Logan Aeruis I and SL3, no sub involved. I have 2 Diana krall CDs and 2 Fourplay Cds that I have been listening to for the last 10 years almost not everyday but few days a week so I am familiar myself how the hi/mid/bass of certian track sound like among the thre Kimber Kable ICs. The difference as I said may be or may not be an improvement no matter how fancy or how much the cost is, it is a type of band-aid to the imperfect recordings that we inheritage from the industry recording. It took us over 50 years to get to the BlueRay technology and we cannot even get it to its perfection. How many HDMI version to upgrade and how may firmware ( 1.1/ 2.0...) to upgrade? So guys, enjoy what you hear within your mean and your budget. The improvement is very subtle but some consumers are willing to pay for that much improvement and some does not. YMMV. Cheer and happy listenning.
  • inspiredsports
    paragraphs, anyone
    Where's Beuller ??
    NAD SS rigs w/mods
    GIK panels
  • esowden
    esowden Posts: 55
    Flash21 wrote: »
    And yet - here I am - doing it again...:rolleyes:
    Den
    Parasound 2100
    Parasound 2125
    Denon DCM-390
    LG BD390V
    Denon AH-D2000
    Bedroom
    Adcom GTP-350
    Parasound HCA-800II
    Panasonic DVD-S54
    Denon AH-2000
    Polk S4(x4)
    ಠ_ಠ
  • mantis
    Interesting thoughts and experience. What's funny is I basically came to the same conclusion as you did with my experience. It's really a never ending battle. My will for perfection where none exists is pointless.
    Don't get me started on HDMI. I have experienced every conceivable problem I just wanna jump out a window into a fiery pit with everything there is HDMI.
    I so gotta agree with your comments on perfection or really just getting "IT" right. It's like "THEY" are only out to get our hard earned money and leach on all of us with a "taste".
    There's a lot to be said on this topic, not just wire , everything to do with our hobby. Now I'm pissed:mad:
    Dan
  • anhchungdoan
    Hey Mantis, don't be pissed! Look a $ 899.00 Denon @500BTCI is on sale for $299.00 including free shipping @ Vann's. How much $$$ do you think "THEY" make on the double steel cage with cheap Chinese parts with the MSRP of $899.00 ? If Vann's sells it for $299.00 including shipping and still makes some profit, I wonder what the true cost to Denon ? Now you are really pissed, so do I since the dog gone thing does not last more than a year without "technical issue"? Tech, My A$$ !!!
  • TECHNOKID
    +1! Just waiting for the su%ker that will bite and spend the extra money unduly!
    DARE TO SOAR:
  • mantis
    People need to make money I get that. Denon is good enough to fight for there right in there price classes. I don't think they lead the way but they are respectable and most can follow. It's an amount of money you pay to have such quality or better. I get that.
    Wire???? come on man I have Installed 36k wire from Transparent in a 250k system. The speaker wire was 6 feet. Thats a lot of money for a conductor. The whole system was out of this world but hey the guy who purchased it money meant nothing to him. It was all about what he wanted and he was stopping at nothing to have the best audio system money could buy. It sounded incredible and It was audio at the level of perfection but the system was of higher quality then the recording studio that records the music. I think it was over the line of perfection recreating replay system.
    So my words are this once again. Once you achieve the goal , you can't make it any better. You have to get the signal from A to B thats it. I know it's not as simple as that and everyone wants to own nice fancy wire but guys trust me when I tell you, there is a limit to no gain. I learned this the hard way.
    Buy high quality cables and make sure they are terminated correctly , pass spec. Make sure you use the proper length to gauge speaker wire and don't allow interference. Buy good quality is really all I can tell anyone to do. Don't go to home depot to buy your speaker wire and IC's. You can but at your own risk. They do have some wire that will work and work well. Just be careful.
    Know the limits of your speakers and don't buy wire that exceeds them to much. There is no benefit from running 12g wire to small speakers. NONE. 16 gauge to 14 gauge is all you need unless your runs are longer then spec.
    Dan
  • mantis
    TECHNOKID wrote: »
    It happens every single day. Guys walk around looking for the sound they want in there system and are not getting it due to the poor quality of speakers they own. Poor placement. Poor calibration. Poor wire management. I could go on and on here. And it's not like they have poor quality speakers , it's they are asking more out of them then they aare capable of. There are sonic limits to all speakers and trying to get high end sound of a pair of RT series speakers is just not going to happen no matter what MIT wire you have or Sunfire amp you power them with. Lsi's have there limits although they benefit from higher end amps and other gear. You get more out of them because they offer more. It's simple really.
    I have been watching people on this forum make mistake after mistake trying to get to a level of sonic perfection with so so speakers. Buying amps and separates , high end wire and all kinds of crazy things when the problem lays elsewhere.
    I'm not hating on anyone's gear , I'm just point out that maybe the better sound you are looking for doesn't rest in MIT wires or that beautiful Sunfire monster amp. Maybe if you have a higher quality speaker and a good placement , you just might find what your ears are telling you to get. It's funny and I feel bad for some but you can only show them the path , you can't walk it for them.
    End Rant. Carry on.
    Dan
  • inspiredsports
    I rarely find an investment in decent equipment to be a bad investment.
    It simply exposes the next weakest link in the system, be it pre-amp/amp, interconnects, speaker cables, speakers, sources, etc.
    One of the easiest places to cut corners is with speaker wire, making that a great place to start for what I would think is the greatest number of people.
    I think I went from in the neighborhood of 17 cents per foot utlimately to $170 per foot before other components showed their weakness.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    keiko wrote: »
    behind me satan, get behind me!
    . . . the little red thingy, . . . it looks kind of Satanic
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    I say, hook that little devil up with some high-line cables and crank a couple thousand watts through him. That should get him behind you.
    Now, speaking of crazy cables, I was just outbid by 87 cents on a $219 Revelation Audio Labs Passage Cryo-Silver™ Reference umbilical power cable that went for inder $60.
    That cable was to be the final link from my Little Pinkie PSU to my Musical Fidelity X-10v3 tube buffer and I'm going to be losing sleep over it because I don't want to pay list.
    NAD SS rigs w/mods
    GIK panels
    tonyb Posts: 33,072
    I hear ya,I don't think I ever payed list for anything...ever. Try a MAC power cable,you could always re sell if you don't dig it.
