Spearker cables..fact or fiction?
1505153555671
  • lightman1
    lightman1 Posts: 10,796
    edited May 2009
    Wow...your life must be pretty dull if you have to make up stories in an attempt to seem interesting
    Damn Curt. I make up stories all the time and I don't think I'm boring.:rolleyes:
  • Lord Vader
    Lord Vader Posts: 167
    edited May 2009
    Kex wrote: »
    Don't you think that the term "cockmonkeys" may be too flattering a description?!
    I beleive the term you seek can be found in an ACME unabridged dictionary, medical edition...
    Needilus Microdicktum- a person who's **** is so small that it can only be found with a scanning electron microscope. So small is this appendage that a common housefly or mosquito is hung like a horse by comparison.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2009
    Kex wrote: »
    Not at all. A cockmonkey is someone who has no common sense, can't understand logic and generally is a narrow minded twit.
    Essentially, Seafire is the equivalent of a monkey playing with it's ****, thus, he is a cockmonkey.
    This is one of my favorite words as of late. It can be used to describe all sorts of things.
    For instance, earlier today, the original battery in my dads truck went dead. We were trying to get it out to replace it, and the way it's built into the truck is really stupid. There's roughly an inch or so of room to work with while trying to get the bolts out of the battery terminals, which are side mounted. They could have been top-mounted, and eliminated the whole problem.
    There's also a filler neck for the radiator fluid which conveniently sticks right over the top of where the battery needs to be pulled out, so it has to be removed to get the battery out. It could have been angled to the side instead of towards the back and eliminated the whole problem.
    The battery compartment in my dads truck was designed by a cockmonkey.
    Get it now?:p;)
    lightman1 wrote: »
    Your stories are much different though Russ. They're entertaining, and not at all cockmonkeyish in any way.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Flash21
    Flash21 Posts: 316
    edited May 2009
    LBrize wrote: »
    What happens is, I'm sure many of you know, when an amplifier is clipping, the signal is no longer being sculpted by the amp. It's not a sign wave with peaks and dips, it's straight 120V, from the wall outlet to the speaker. That's why clipping an amp blows speakers more easily than overpowering a speaker.
    That's not clipping...it may be something else, but it's not "clipping". Clipping is where the amp doesn't have enough power to push the full amplitude of the called-for sine waveform, so the wave is chopped off and becomes more of a square wave. Very damaging indeed, but not "straight 120V".
    I now return you to your regularly scheduled Chinese-Fire-Drill-In-An-Insane-Asylum...
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • lightman1
    edited May 2009
    Kill this thread, Patrick, Justin, whoever!!!!
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Justin left has departed from this thankless crowd, and patrick hasn't been active much. This thread needs to disappear like seadoo.
    Ben
  • lightman1
    edited May 2009
    bobt wrote: »
    I don't under stand the price for speaker cables....some cost more then the equipment there hookup to....The price is insane. The Stereophile mags review these....of course there not going to say anything bad about them..they get paid to do this...then sit there and try to tell you....oh yes we hear this one gives you more highs, or this one is more clear.....BULL...
    Sorry..it's a piece of wire...when you get to a certain point...thats about it.
    I have a 12 gauge speaker cable, I will not say which kind. I went and spent $250 (on sale)...some supposed great cable......NO DAM DIFFERENCE.
    No way you could tell the difference between the 2. Now OK...."MAYBE" if your playing some violin thing........MAYBE you could hear something different, but my guess would be NOT. If I changed cables on these "reviewers"...they would not have a clue............
    OK, I play mostly rock and blues, but do throw in some classic music.
    If Stravinsky, or Tchaikovsky..sound the same to me, over different cables..well I get the fact.....basically you have just been riiped off, because it's called "audiophile"....and no I'm not tone deaf...I've mixed CD's for people , run PA mixers...I know what good sound is.
    It's like Boats...if it's marine..you pay a ton....same crap you can buy for cheap...Audiophile.....the price goes up.....
    Most of this "sound" is precived..just because you spent..300 plus on a cable.
    Thanks Bob....
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    High end cables and such are for High End equipment....period.
    If I spend $1000 on spearkercables, then im stupid because I would have no benefit from it other than looking like a badass in front of my friends:D
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    heiney9 Posts: 25,447
    edited May 2009
    So how is Seafire and this thread still here?
  • Knucklehead
    edited May 2009
    its a trap!:eek:
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • phuz
    phuz Posts: 2,372
    edited May 2009
    Holy moly. Epic thread. This one will not die.
  • Flash21
    Flash21 Posts: 316
    edited May 2009
    heiney9 wrote: »
    The lights are on but nobody's home...
    Steve Carlson
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2009
    phuz wrote: »
    It sure can die if we simply all vow not to post in it no matter what. I'm definitely willing to do this so peace comes back to PC ;)
    Cheers :)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    its a trap!:eek:
    Yepper:p
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Lord Vader
    edited May 2009
    Keiko wrote: »
    Turn him into Mynok food Lord Vader. Make him suffer with an anal probe droid.
    I am glad you thought of mynoks. They feed on cables and other wiring. Perhaps they could be of some use to us... I wonder if they could be used to eat the bs in this thread, then track the source of it back to the Seafart's hidden base. Once located my Super Star Destroyer could be dispatched and destroy him...
    Thanks Keiko... I leave now for I have work to do...
  • comfortablycurt
    edited May 2009
    Lord Vader wrote: »
    Good luck Lord Vader...and May The Force Be With You!!:D
  • ben62670
    edited May 2009
    Guys don't bait the troll. Let the stupid thread die.
    Ben
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    As strange as it may seem, I am starting to like this thread. The way it morphs is simply amazing and, in a sense, a reason why it should not die. Tense moments, productive moments, troll moments and silly momements. It's got it all!
  • lightman1
    edited May 2009
    You got a purty mowth Lee.
    Anybody...????
    Think about it...
    Hillbilly?
    I'm just sayin.....
  • Knucklehead
    edited May 2009
    my wife and kids keep asking why i say "spearkers", thats what they are reffered to from here on out.:D
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • TECHNOKID
    edited May 2009
    Keiko wrote: »
    It was dead until the maggot resurfaced...Sorry though, couldn't resist. :rolleyes: :D
    And yet you keep the thread alive giving new comers potential to get in the game still... Sorry, couldn't resist :);)
    You all remember the old Beatle song "Let it die" :D
    DARE TO SOAR:
    nooshinjohn Posts: 25,932
    edited May 2009
    TECHNOKID wrote: »
    you mean Live and Let Die by Wings....
  • TECHNOKID
    edited May 2009
    Let it be! However, this is good in many ways ;)
    DARE TO SOAR:
  • comfortablycurt
    edited May 2009
    TECHNOKID wrote: »
    That wasn't a Beatles song, and it wasn't called Let It Die...;)
    Nooshin got it right.
    Paul McCartney & Wings-Live and Let Die.
    It was also the title song for the Bond movie, "Live and Let Die".
  • Hillbilly61
    edited May 2009
    Bump. Let's keep this thread alive!!!!!
    It's like guaging how far slime mold colony creeps across a damp concrete floor when one checks in from day to day. Today, I told the car salesman that the 6 spearker system sounded nice in a vehicle I was looking at. He responded along the lines "Yes, if you buy this baby today, you can have sparklers on it during the 4th of July!"
    lightman1 wrote: »
    Anybody...????
    Think about it...
    Hillbilly?
    I'm just sayin.....
    Russ, how does your legs look when they are not donning assless chaps? Curiosity is getting the better of me. :eek:
  • TECHNOKID
    edited May 2009
    Keiko wrote: »
    Here you go Keiko! Just change "let it be" to "let it die" or use them both meaning let it go :D Too bad the recording is so crappy :( I sure can "live" with "live and let die" too, works well too and I always were a fan of both the Beatles and (Paul McCartney and...) the Wings. Beatles => Mccartney <= the Wings as both groups "lived and died" through McCartney's talent/ingeniosity ;)
    Sorry for trolling ;)
    DARE TO SOAR:
  • inspiredsports
    inspiredsports Posts: 5,502
    edited July 2009
    In recent months, I've been more out the forums than in, devoting nearly every spare moment to vinyl. I've been expanding my collection, and more important, refining my turntables.
    In the past 6 months, I have sold off six Thorens turntables, kept five Thorens turntables, and purchased one Thorens and one Linn. I've purchased 15 or 16 different cartridges and styli, both new and used. I've purchased and made several variations of silver and copper connection wires and experimented with several variations of Thorens, Grace and SME tonearms and arm-wands. I've accumulated several brands of platter mats and clamps.
    During my treks around the Internet searching for various pieces/part, owner's manuals and information, I hope I've learned a bit. The best part of the journey is that I've been rewarded with the best "trust" in my ears that I've had in the past 30 years. I've experimented and listened so much that I can finally hear subtle differences, and actually categorize what those differences are.
    I've read opinion after opinion, and some of the the most astute observations about sound that I've read came from a 20 year old article by John Atkinson in Sterophile Magazine . . .
    http://www.stereophile.com/tonearms/395
    Atkinson doesn't come right out and say it, but he is talking about synergy. The COMBINATION of pieces/parts, different pieces/parts, is what makes up the whole
    After considering some of the venomous threads here where those on each side of the argument vehemently defend their positions, I came to understand both camps are right. Simply put, the addition of two or more Class A components does not guarantee Class A sound.
    To those of you who have never sought or found a good synergistic combination, my condolences. To those who have, Bravo!
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    edited July 2009
    were we go... Again.:o
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2009
    I've been wondering where you've been.
  • inspiredsports
    edited July 2009
    I've been learning as much as possible about analog. I think I'm up to about 7% :)
    NAD SS rigs w/mods
    GIK panels
