Holy SonoSub!
OK, I don't feel bad buying a sub that only goes down to 20.
Best of luck tuning that beast!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
My port is too long I checked with a couple programs, and I need to shorten it to 15 inches. I will be flat to 20, and then roll off real quick.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
When you finish you adjustments let us know the does and don't for making a SonoSub. Good work!engtaz
So your going to limit that monster to 20hz?...AAWWWWWW:(Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
What did you use the measure the SPL? If you used the Radio Shack SPL Meter did you correct the values? If those are uncorrected values then you're more linear than you realize.Proud SOPA Member since 2005!
Man I wish I could build one, the excitement from all the tuning alone would be worth it.Shoot the jumper.....................BALLIN.............!!!!!
corrected SPL's
10-88
15-92
20-91
25-91
30-96
35-98
40-97
45-98
50-92
55-93
60-92
65-94
70-92
75-90
80-92
This is in a 24*24 room with 8' ceilings, with the sub in a corner. I have not yet played with the port. The reason I would play with the port is to mainly get rid of that huge bump from 30-45. I realize that I would lose some max dbl, but I would prefer a flatter response. I also realize that I would lose quit a bit at 15, and a bunch at 10. The speaker over travels at I am guessing 30-45 any way.
What do you guys think?
Thanks BenPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I think you need to increase the length of the port. Can you use WINisd? The bump between 30 and 45 could be corrected with a longer port. If you dont have Win ISD . Then shoot me over the size of your tube and size and length of your port. I can get the Theil specs from PE. I can put the info in my WINisd and see what it comes out to.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I was messing with WINisd, and the sononosub.exe programs. The sono sub program came up with shortening the tube to 15". I also feel that is rather drastic, so I was thinking 20" tube.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Putting the specs in WinISD accounting for a 10cuft incloser. This is what I got.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
That was tuning it to 18.5hz You might just have a bad null in your room.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
gross 10.07 cubic feet
effective volume 9.42
30*6 portPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
30*6 port
So you have it tuned way below 18hz. Did you try a port length of 20" or 18"? It just seems the port is kind of long. Or reverse the polarity of the speaker.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I just checked out your calcs, and my port is six inside, and is 30 long. What you had is what I was thinking of modifying it to.
Ben -
I just tuned it for 15hzPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
This is a read/out of a 9.45cuft with a 5.5" port 30" long. Port is way too long. I would think you need to cut about 7-10" off the length.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I was thinking of whacking 10" of the port, and if need be I can always add a coupling to increase it again. The Specs you are showing in the second thumb are way different than sonosub's, and the room measurements. I think what the are giving you is if the sub was out in an open field. I have to run to the hospital now. My 1 1/2 yo girl just jumped out of her crib at her mom's house, and landed on her head.
I'll be back!
Ben -
OHH>..I hope everything is ok Ben...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Ben -
So she is ok...goodMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Let us know if she's OK. Prayers sent out.engtaz
I have been running some test, and I am now getting a completely flat response at all frequencies. 0-DBL oopsPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
What did you change?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Ben, I have been playing around with sonosub.exe. Is it supposed to give a Fr graph like winisd? All I do is put in my demisions and port size, etc. But it doesnt do anythingMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yeah I had a little over heat problem, everything is back to norn
Ben -
What's your latest thoughts on your sonosub? Any newer pics?engtaz
It works better than expected. I was worried that with such a large enclosure that it would be boomy, but it is actually deep, and tight.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Nice, Glad your enjoying it. What about the kids? Do they like it? My kids love the 15" Velo and the 10/12" Velo.engtaz
