Holy SonoSub!
135
  • engtaz
    engtaz Posts: 7,670
    edited April 2007
    no but other senses can
    engtaz
  • Face
    Face Posts: 14,340
    edited April 2007
    OK, I don't feel bad buying a sub that only goes down to 20. :D
    Best of luck tuning that beast!
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    My port is too long I checked with a couple programs, and I need to shorten it to 15 inches. I will be flat to 20, and then roll off real quick.
    Ben
  • engtaz
    engtaz Posts: 7,670
    edited April 2007
    When you finish you adjustments let us know the does and don't for making a SonoSub. Good work!
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    ben62670 wrote: »
    So your going to limit that monster to 20hz?...AAWWWWWW:(
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • nebborjk
    nebborjk Posts: 425
    edited April 2007
    What did you use the measure the SPL? If you used the Radio Shack SPL Meter did you correct the values? If those are uncorrected values then you're more linear than you realize.
    Proud SOPA Member since 2005!
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2007
    Man I wish I could build one, the excitement from all the tuning alone would be worth it.
  • ben62670
    edited April 2007
    corrected SPL's
    10-88
    15-92
    20-91
    25-91
    30-96
    35-98
    40-97
    45-98
    50-92
    55-93
    60-92
    65-94
    70-92
    75-90
    80-92
    This is in a 24*24 room with 8' ceilings, with the sub in a corner. I have not yet played with the port. The reason I would play with the port is to mainly get rid of that huge bump from 30-45. I realize that I would lose some max dbl, but I would prefer a flatter response. I also realize that I would lose quit a bit at 15, and a bunch at 10. The speaker over travels at I am guessing 30-45 any way.
    What do you guys think?
    Thanks Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    I think you need to increase the length of the port. Can you use WINisd? The bump between 30 and 45 could be corrected with a longer port. If you dont have Win ISD . Then shoot me over the size of your tube and size and length of your port. I can get the Theil specs from PE. I can put the info in my WINisd and see what it comes out to.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    I was messing with WINisd, and the sononosub.exe programs. The sono sub program came up with shortening the tube to 15". I also feel that is rather drastic, so I was thinking 20" tube.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Putting the specs in WinISD accounting for a 10cuft incloser. This is what I got.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    That was tuning it to 18.5hz You might just have a bad null in your room.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    gross 10.07 cubic feet
    effective volume 9.42
    30*6 port
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    ben62670 wrote: »
    30*6 port
    So you have it tuned way below 18hz. Did you try a port length of 20" or 18"? It just seems the port is kind of long. Or reverse the polarity of the speaker.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    I just checked out your calcs, and my port is six inside, and is 30 long. What you had is what I was thinking of modifying it to. ;)
    Ben
  • ben62670
    edited April 2007
    jakelm wrote: »
    I just tuned it for 15hz
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    This is a read/out of a 9.45cuft with a 5.5" port 30" long. Port is way too long. I would think you need to cut about 7-10" off the length.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    I was thinking of whacking 10" of the port, and if need be I can always add a coupling to increase it again. The Specs you are showing in the second thumb are way different than sonosub's, and the room measurements. I think what the are giving you is if the sub was out in an open field. I have to run to the hospital now. My 1 1/2 yo girl just jumped out of her crib at her mom's house, and landed on her head.
    I'll be back!
    Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    OHH>..I hope everything is ok Ben...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    jakelm wrote: »
    The only problem with JJ is her mother:D
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    So she is ok...good
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • engtaz
    engtaz Posts: 7,670
    edited April 2007
    Let us know if she's OK. Prayers sent out.
    engtaz
  • ben62670
    edited April 2007
    I have been running some test, and I am now getting a completely flat response at all frequencies. 0-DBL oops
    Ben
  • engtaz
    engtaz Posts: 7,670
    edited April 2007
    Congrats
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    ben62670 wrote: »
    What did you change?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Ben, I have been playing around with sonosub.exe. Is it supposed to give a Fr graph like winisd? All I do is put in my demisions and port size, etc. But it doesnt do anything
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    Yeah I had a little over heat problem, everything is back to norn :)
    Ben
  • engtaz
    engtaz Posts: 7,670
    edited May 2007
    What's your latest thoughts on your sonosub? Any newer pics?
    engtaz
  • ben62670
    edited May 2007
    It works better than expected. I was worried that with such a large enclosure that it would be boomy, but it is actually deep, and tight.
    Ben
  • engtaz
    engtaz Posts: 7,670
    edited May 2007
    Nice, Glad your enjoying it. What about the kids? Do they like it? My kids love the 15" Velo and the 10/12" Velo.
    engtaz
