Chicago Polkfest???
1246723
  • halo
    halo Posts: 5,616
    edited November 2006
    HTrookie wrote:
    Just let me know what you'd like me to bring, if anything.....If I don't take anything I can ride....hmmmmm....not a bad idea....
    Whatcha got?
  • Lowell_M
    Lowell_M Posts: 1,660
    MikeC78 wrote:
    Yes, please bring over the Hitachi 51". :)
    Accept that....
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • MikeC78
    MikeC78 Posts: 2,315
    a_mattison wrote:
    Accept that....
    Sweet!!!:D You accept that!!:p Now, I can compare it to my Panny!:)
    :confused: Did you mean except that?:(
  • Ricardo
    Ricardo Posts: 10,636
    Halo wrote:
    Whatcha got?
    Nothing fancy.....
    http://www.polkaudio.com/forums/showcase/view.php?userid=64116
    Pictures are not up to date, so look at the list :)
    SOPA
  • McLoki
    McLoki Posts: 5,231
    All my gear is in my sig except a polk 350 sub, rm6600 sat. system and an onkyo 777avr.
    Anyone want to hear anything?
    Michael
    Edit - oh, i forgot I do have a 3960 dvd player that was modified by MadMax for audio playback. (i use it as an audio cd player) If someone can bring an actual decent CD player, could make for an interesting shootout.
    Edit #2 - and a beat up pair of sda 1b's. (unmodified)
  • halo
    halo Posts: 5,616
    HTrookie wrote:
    Nothing fancy.....
    I really think you should bring the Carver AL-III's and the Bada HD-22 Tube CD player. Are there going to be any SDA's making an appearance?
    With Joey's ML's you'd get to hear an electrostat. The Carver AL-III's you'd get to hear a ribbon tweeter (all four feet of it). My Von's are a convential (cone) speaker - but all three are (sort of) di-pole speakers.
    If I bring both TAD-60's we can bi-amp the the AL-III's. Ask Normanality his AL-III's are beasts when bi-amped.
    I'll bring the Sheng Ya if you want to go toe to toe ;) I thought someone wanted to hear that Cinepro?
  • halo
    halo Posts: 5,616
    Head count now @ 12 ish:
    1. Halo
    2. Joey_V
    3. a_mattison
    4. HTrookie
    5. heiney9
    6. F1nut
    7. Polk65
    8. McLoki
    9. opus
    10. brettw22
    11. Demiurge
    12. Shizelbs
  • Demiurge
    Demiurge Posts: 10,874
    50/50ish though. All depends on how busy biz is. :cool:
  • halo
    halo Posts: 5,616
    Hence the ish Dave :) If you show up last minute with the brats we'll be happy to see ya ;)
    brettw22 & Shizelbs are somewhat up in the air also.
    heiney9 Posts: 25,396
    Anybody heard from Noel?
  • halo
    halo Posts: 5,616
    No, I haven't. SCompRacer will let me know. Normanality would be a last minute decision. I'd hope all three would be able to attend.
  • Joey_V
    Joey_V Posts: 8,600
    Halo wrote:
    Correction - Joey is the youngest with the most expensive gear. The cool factor is subjective. I'd take a tube amp over a sand amp any day in a :cool: contest.
    That's fine that you'd take a tube amp.... but I'd take a Class A amp with a tube preamp over anything else any day of the week. Besides... I do have cool gear, atleast to my eyes. :p:D
  • Joey_V
    Joey_V Posts: 8,600
    Nm.. moving my new preamp post to a new thread so as to not further derail thread.
  • Joey_V
    Joey_V Posts: 8,600
    Alright...
    Regarding gear....
    I want the following there to hear:
    1. Carver Amazings
    2. LSi15
    3. VS VR2
    4. SDA
    Aside from that.... I'm sure I'd like to hear exactly what Halo's amp can do. Anything else is gravy.
    Joey
  • Joey_V
    Joey_V Posts: 8,600
    Halo wrote:
    Let's start to generate a gear list. We don't want to have too much shite there or we'll never get through it all.
    Joey's gear is a given. Are you going to have any decent cables or IC's by then Joey?
    I'm not sure.... I should have some by then.
    Also, I should have something like the Transporter by then.... and we can use the AKM DACs if we want to go with a CDP to it instead of the usual streaming of FLAC. Though I will bring my External HDD myBook to the party so we can hook it up to the network and I can stream my FLACs to the Summits.
    Joey
    F1nut Posts: 51,672
    Victor, older than any of you.
    I'm also NOT interested in hearing music thru a computer, get real folks.
  • Joey_V
    Joey_V Posts: 8,600
    Either way, I'm still bringing my FLACs. You can probably hear better than me, that's fine. But this is for real and I dont understand why people have this bias against FLAC. IMO, the more the merrier.
    If you dont want to listen to FLAC, that's fine. But to dismiss it entirely is something I dont personally understand.
    Joey
  • Polk65
    Polk65 Posts: 1,405
    How does flac or ape sound compared with satellite radio? I would assume better but I've never listened to these formats.
  • Joey_V
    Joey_V Posts: 8,600
    FLAC is lossless and is a compression file of the original wav file, only to be uncompressed during playback. FLAC is basically a zip storage form of wav... but it is full wav. FLAC is essentially CD.
    Hence, FLAC is better than Satellite since that is lossy, if I'm not mistaken.
    Joey
  • Ricardo
    There is no way I'm taking the AL-III's on that road trip....sorry, but those ribbons are too damn delicate and I don't want to get there and start hearing scratching and buzzing....
    I will take the BADA player, and I would also take the 3.1TL's if there is interest.
    SOPA
    This an audio meet....FLAC is dubious. I use FLAC as a storage medium and I use it in my now defunct (soon to be upgraded) computer rig. I know it's gaining popularity with the music server crowd and it is lossless, etc. But this is an audio meet to see cool gear etc. I won't say I won't listen to FLAC but others should have enough transports/cdp's to make listening to the FLAC's unnecessary.
    Bring the 3.1 TL's if you can. It's been awhile since I've heard SDA's and the 3.1's are actually the model I'd consider if/when I buy a pair.
  • Polk65
    Polk65 Posts: 1,405
    Placing a ban on audio related thingamagigs that others don't approve of or is too old sucks. In all fairness I would figure it's up to the host for what will be connected to his electric. Consult with BDT.
    My interest in flac is that I have not heard "lossless" digital recordings and I don't get any satisfaction from satellite radio.
  • Lowell_M
    I've got the mostest awesomest vocabulary. I guess I should return those "Joe Johnson Vocabulary Builder Upper" tapes.
    I always flip flop accept and except....doh!
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Polk65
    Polk65 Posts: 1,405
    doh! A deer. A female deer. :D
  • McLoki
    McLoki Posts: 5,231
    That is the exact reason that I want to hear it. I have never heard of FLAC prior to this thread, but it would be nice to hear it in comparison to other more standard gear. As to whether it is worthwhile or not, is for us to listen and decide.
    Michael
    I really don’t have an issue with FLAC. I just don’t want it to become the focal point for the meet and have people leave gear at home. FLAC really isn’t all that evil, but from a purists p.o.v. it’s hard to swallow. I use FLAC a lot but I’m still traditional enough to use a conventional transport. I will however say that if we are going to be using top gear I won’t listen to Mp3’s or WMA’s or any of the Ipod/iTunes stuff. Well, I’ll listen but it won’t be in the spirit this meet was intended. I’ve listened too many of the other computer based formats out there and they don’t belong in mid/high end audio. There I took a stance. :p
  • MikeC78
    Michael
    Me too!!
    I really want to compare all these things, and see if you guys can make me a true audiophile.:) I'm happy with using my current HD/DVD players to play my disks, and also using Ipod.:o
  • halo
    halo Posts: 5,616
    Read all the info on the TAD Joey. Class A tube amp :p with variable feedback, gain control, choice between triode mode and UL mode + I can roll different tubes = infinite adjustability. Besides, IMHO, nothing beats the warm glow of tubes for looks ;)
    I never said your gear wasn't :cool: Joey - I just said it was the most expensive (which it is). Expensive gear doesn't always = :cool: and :cool: gear doesn't have to be expensive.
    Are you going to bring the Onix mini's too? If not when are you bringing them over??? ;):)
    I'm just going to come and have fun!!! I'll be bringing my 9's unless someone else is, and perhaps my DAC. By June I may have some other stuff too, who knows.
  • halo
    halo Posts: 5,616
    Ditto.
    What happens when you compress something? Things get lost. Don't think it's true? OK, then go to the grocery store and buy two oranges. Proceed to eat the first orange. Compress the 2nd orange. Put the compressed orange back together and eat it. Notice a difference? Still not convinced? Look at all the crap still sitting on the table from the compressed orange that you weren't able to "put back together". When you compress - you lose something. Plain and simple.
