Chicago Polkfest???
May (not Mothers Day) or early June work best for me. But I'm probably the most flexible if we get it planned early enough. Around the 4th is no good for me.
Which weekend (posted above) works best for you Brock?
If we want to include Joey it looks like the last two weeks in June are it.
Joey - Review the dates and get back to us.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
How about we do this...
Everyone who plans on attending, please post the date which DO NOT work for you. Holidays are exempt of course.
This should make it easier to plan for everybody. I'm still open as of today...
Mike -
I have no life. You name date, I show up.
How's that for flexible?The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
I'm still open. I just need a little advance notice so I can plan on the kids to stay somewhere else for the weekend. Also, so I can run to Sam's and get drinks, munchies, and whatever anyone else wants?:)
Mike -
I should be free anytime in may... preferably earlier. I wont know "exactly" how my rotation will schedule me, but more than likely, I should have the weekends off.
JoeyMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
The best weekend for Joey is June 29th, 30th, & July 1st. This puts us about two months away from almford's PF '07.
Since most who are planning on attending Chicagofest '07 (except for F1nut) are from the Chicagoland area and are not, that I'm aware of, going to attend PF '07 this shouldn't be an issue unless the date is a problem for somone else.
The only other date that might work for Joey is May 18th, 19th, & 20th but it isn't guaranteed.
Sound off -
May 18th, 19th, & 20th or June 29th, 30th, and July 1st?Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Both would work for me.....there's plenty of time for everyone to plan for it...just pick a date
Either weekend is cool with me.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
End of June is probably the ideal one then....
Anyone else?
Either is fine with me. May 18th is my wedding anniversary (16 years) so I will have to miss that day - but it is a Friday (I assume travel day for most) and I would still be able to attend Sat. (and Sun if needed)
Michael,
You make me feel really young!:D Congratulation's on your 16th year!! -
Sweetness... no objections so far?
Les do dis...
Ok then, tentatively it looks like June 29th, 30th, and July 1st??
Damn, I'll be 29 already.
Great.... I'll be 25....
:(:( Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I'll be 47.....maybe I shouldn't go....:eek:
Joey_V wrote:Great.... I'll be 25....
YEAH!!!:D Someone closer to my age!!:p -
Crap..I'll be 31 by then.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Youngest with the coolest gear.... doesn't sound that bad to me....Joey_V wrote:Great.... I'll be 25....
33 for me :eek:Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Correction - Joey is the youngest with the most expensive gear. The cool factor is subjective. I'd take a tube amp over a sand amp any day in a :cool: contest.McLoki wrote:Youngest with the coolest gear.... doesn't sound that bad to me....
MichaelAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
I would prefer the May date (that's not Mothers Day weekend is it). The June date will be 50/50 for me as I usually head up to Hayward for the 4th of July and it may be that I leave at the end of June. No solid plans yet, but that's the usual plan. If May can't work I could probably work around the June date.
Let's start to generate a gear list. We don't want to have too much shite there or we'll never get through it all.
Joey's gear is a given. Are you going to have any decent cables or IC's by then Joey?
I'll be happy to lug the whole enchilada, just one peice, or nothing at all depending on who wants to hear what. I also have some AR-2ax's I could bring in addition to the stuff in my signature.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
You guys gotta give more time on these decision's. I wasn't able to access at work today and it looks like in a matter of hours the June date was decided
That being said we need to plan it for when a majority of people can attend. If it's June then I will try to work around it if I have a conflict. We haven't put solid plans in place for the 4th yet, just going on the past 20 years or so of tradition.
HTrookie wrote:I'll be 47.....maybe I shouldn't go....:eek:
Shhhhh.......I turned 40 this year and still get carded occasionally
Mother's Day is Sunday May 13th Brock. Let's assume the end of June date is it: June 29th, 30th, & July 1st. You must be there!heiney9 wrote:I would prefer the May date (that's not Mothers Day weekend is it). The June date will be 50/50 for me as I usually head up to Hayward for the 4th of July and it may be that I leave at the end of June. No solid plans yet, but that's the usual plan. If May can't work I could probably work around the June date.
H9Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
I wonder how old Jesse is?Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
In regard to gear.... I don't have anything off the wall, or really all that fantastic since this sickness has just recently really grabbed hold. I wasn't planning on bringing anything due to that, but if anybody sees anything in my sig you want me to bring, I would be happy to.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Yes, please bring over the Hitachi 51".
Just let me know what you'd like me to bring, if anything.....If I don't take anything I can ride....hmmmmm....not a bad idea...._________________________________________________
