here is a very good page on expensive cables. check it out.
1235»
  • cmy330go
    cmy330go Posts: 2,341
    edited November 2006
    !!!!Die Thread Die!!!!:D
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • PolkThug
    PolkThug Posts: 7,532
    madmax wrote:
    Does anyone think the ones with batteries work and if so do you think it is because of the battery?
    madmax
    Duracells have deeper bass than Energizers.
  • ND13
    ND13 Posts: 7,601
    Now see that is BS...everyone knows all you need is those cheap-**** batteries from the dollar store.:p
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • madmax
    madmax Posts: 12,434
    No, I'll bet he is correct but I'm thinking the energizers would be quicker sounding.
    madmax
    Vinyl, the final frontier...
  • marker
    marker Posts: 1,084
    madmax
    But none of them have quite the "inner detail" of the Ray-O-Vacs. :p
  • marker
    marker Posts: 1,084
    NO NO NO! You get much better sound with "audiophile approved" batteries. ;)
  • ND13
    ND13 Posts: 7,601
    My dollar store cheapies just have to be replaced every 10 minutes
  • MSALLA
    MSALLA Posts: 1,602
    I don't care what kind of batteries we use. If The kids are out of the house and we get wild enough, the batteries in that rabbit thing only last about 2 hours.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    If you put the battery in backwards would the sound be backwards also?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • killerb
    killerb Posts: 390
    please kill this thread! i promise ill be good from now on, no more cable talk for me ever again!!!!!!!! i going to seek help right now!!!!!
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    I hooked up a pair of Diehards to my R30's, and I definitely could tell a difference in the sound.
    I was also able to pop popcorn off the tweeter at the same time, so my listening experience was definitely enhanced.
    The only problem I experienced was the 22-gauge wire running along the floor to the R30's got a little hot and kind of melted into the carpet. I'm going to go to Loews and get some bell wire. That's what I used for the front doorbell, and my doorbell sounds pretty clear (can hear it throughout the house), so I figured it would help bring out the highs a little better on the silk dome tweeters.
    If nothing else, it should reduce popping time for my Act III popcorn.
    Anybody got any suggestions ?
    :rolleyes:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    cables matter
    next.
    RT1
  • disneyjoe7
    LOL :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • shack
    shack Posts: 11,154
    No...but if you if you put the battery in backwards and play The Beatles White Album you will be able to hear "Paul is dead" in the background.
  • disneyjoe7
    Cables matter ?????????????
    Time Warner or COX?
    Or is this jumper cables? I prefer 4 gauge I had some High Compression **** to turn over in my day ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    That would be UGLY :eek:
    But if I listened to Boston would I get say Chicago?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    F1nut Posts: 52,035
    LOL.....you learn quickly, I'll give you that. :D
  • killerb
    killerb Posts: 390
    i do, cable is left for t.v.!!!!!
  • killerb
    killerb Posts: 390
    good luck.
  • hearingimpared
    hearingimpared Posts: 21,136
    cfrizz wrote:
    If a tree falls in the forest does it make a noise?:rolleyes: ;):p:D
    WAAAAAAAAAA!!!!
    Does a bear **** in the woods? If he does, does it make a boomy plopping sound when it hits the ground or is it tight sounding?
  • exalted512
    exalted512 Posts: 10,734
    so youre saying stick with the AA batteries? What about triple A?.
    just reverses the polarity
    -Cody
  • marker
    marker Posts: 1,084
    Well, I suspect that much like a sub, for it to be tight sounding, it must be sealed, and since it's pretty obvious that the bear's ****$ was ported instead of sealed, the smart money is on a boomy plopping sound. :p
  • disneyjoe7
    Ok if battery does a 9v work better then a AA?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
