Mini models of the SDA SRS. i need help with crossovers.
    xschop Posts: 5,875
    Great job. One day there will be a set of Shorty 1.2 TL's with 1-piece faceplates in that same fashion. I'm a fan.
  • Lerjebrink
    g6vl0t0kbxt8.heic
    Update
  • Lerjebrink
    F1nut Posts: 52,406
    Sure are putting a lot of work into those. I hope they turn out ok.
    What is all the black stuff inside the cabinets?
    heiney9 Posts: 25,711
    edited September 12
    The cabinets look really narrow (depth). Did you do calculations for frequency response of the box and PR? Where's the bracing? Just wondering.
  • Lerjebrink
    It”s 1 layer of butyl. Sound dampening
  • Lerjebrink
    heiney9 wrote: »
    Yes the calculations has been done. With ”exact” spare room for filters. If bracing is needed, i Will add some later.
    The plan right now is to use them as a 2.1 system, paired with a 8-10’ sub.
    F1nut Posts: 52,406
    edited September 14
    Lerjebrink wrote: »
    That's what I thought. Unfortunately, your speakers will sound lifeless with that material in them.
    Rip all of it out and use polyfill.
    xschop Posts: 5,875
    Lerjebrink wrote: »
    If it is a few mils thick butyl rubber, it will help with cabinet vibes/resonance.
    You will probably have to brace a few spots in the middle line to really mitigate cabinet vibes just like the original 1.2's
    F1nut Posts: 52,406
    edited September 14
    A few mils??? You need to look closer. Heck, he even stated, one inch.
  • ptrooper
    ptrooper Posts: 769
    Unless my eyes are painted on, it desn't look like 1"to me,correct me if I'm wrong ,the comment stated ,1 layer of butyl rubber.
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
    F1nut Posts: 52,406
    You are correct, 1 layer. Still a lot thicker than a few mils.
  • Gardenstater
    Gardenstater Posts: 4,960
    edited September 14
    So basically Dynamat without the aluminum skin. Just as reflective of airborne sound waves as MDF (probably more) but will help dampen cabinet resonances some.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Lerjebrink
    Lerjebrink wrote: »
    No. In this case you are wrong. My friend made a pair of JBL minis, where i 3D printed a bunch of parts to him. I heard these speakers with and without this 3mm butyl sheets. It made very much difference, in a really good way. rppj9q0dct5o.jpeg
    F1nut Posts: 52,406
    Maybe, maybe not. Completely different speaker designs.
  • Lerjebrink
  • Gardenstater
    Looks great! 3D printed boards and cap holders? One thing I noticed is you have 2 inductors that are pretty close to each other without aligning one magnetic field perpendicular to the other one. Those will interact with each other.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Lerjebrink
    I think i solved it, thanks man
  • Lerjebrink
    Lerjebrink Posts: 39
    audioluvr wrote: »
    You should have posted this on April 1st. It would have made more sense. You should also build a mini Matthew Polk in a white lab coat that you can stand next to them. I have to admit though, you do have good taste in brandy.
    Lerjebrink wrote: »
    Next print will be with white lab coat, this was just a test
    xschop Posts: 5,875
    Lerjebrink wrote: »
    audioluvr wrote: »
    Lerjebrink wrote: »
    @audioluvr ...The famous colloquial idiom is definitely warranted here....
  • Gardenstater
    Can you make him loosen up a bit and have him playing air guitar?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    skipshot12 Posts: 2,163
    This is way cool.
    Applaud your vision.
    Can’t wait to hear your impressions of your project.
  • ptrooper
    ptrooper Posts: 769
    edited October 2
  • Lerjebrink
    Swear i understand all americans calling us swedes crazy
  • Unknown
    xschop Posts: 5,875
    Lerjebrink wrote: »
    Ingenuitive, not crazy. Enjoying the show and skills here.
    The high chair is from Squatty Audio, and only required by the height-challenged members here for the factory 1.2TLs. :D
    F1nut Posts: 52,406
    The high chair is from Squatty Audio, and only required by the members here for the flawed design of the factory 1.2TLs.
    Fixed it for you and them.
  • Gardenstater
    The 1.2tl model:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,875
    The Squatty Deluxe.
  • Lerjebrink
    Some progress on the tweeters!
