Mini models of the SDA SRS. i need help with crossovers.
    xschop Posts: 5,788
    Great job. One day there will be a set of Shorty 1.2 TL's with 1-piece faceplates in that same fashion. I'm a fan.
  • Lerjebrink
    g6vl0t0kbxt8.heic
    Update
  • Lerjebrink
    F1nut Posts: 52,360
    Sure are putting a lot of work into those. I hope they turn out ok.
    What is all the black stuff inside the cabinets?
    heiney9 Posts: 25,662
    edited September 12
    The cabinets look really narrow (depth). Did you do calculations for frequency response of the box and PR? Where's the bracing? Just wondering.
  • Lerjebrink
    It”s 1 layer of butyl. Sound dampening
  • Lerjebrink
    heiney9 wrote: »
    Yes the calculations has been done. With ”exact” spare room for filters. If bracing is needed, i Will add some later.
    The plan right now is to use them as a 2.1 system, paired with a 8-10’ sub.
    F1nut Posts: 52,360
    edited September 14
    Lerjebrink wrote: »
    That's what I thought. Unfortunately, your speakers will sound lifeless with that material in them.
    Rip all of it out and use polyfill.
    xschop Posts: 5,788
    Lerjebrink wrote: »
    If it is a few mils thick butyl rubber, it will help with cabinet vibes/resonance.
    You will probably have to brace a few spots in the middle line to really mitigate cabinet vibes just like the original 1.2's
    F1nut Posts: 52,360
    edited September 14
    A few mils??? You need to look closer. Heck, he even stated, one inch.
  • ptrooper
    ptrooper Posts: 648
    Unless my eyes are painted on, it desn't look like 1"to me,correct me if I'm wrong ,the comment stated ,1 layer of butyl rubber.
    F1nut Posts: 52,360
    You are correct, 1 layer. Still a lot thicker than a few mils.
  • Gardenstater
    Gardenstater Posts: 4,911
    edited September 14
    So basically Dynamat without the aluminum skin. Just as reflective of airborne sound waves as MDF (probably more) but will help dampen cabinet resonances some.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Lerjebrink
    Lerjebrink wrote: »
    No. In this case you are wrong. My friend made a pair of JBL minis, where i 3D printed a bunch of parts to him. I heard these speakers with and without this 3mm butyl sheets. It made very much difference, in a really good way. rppj9q0dct5o.jpeg
    F1nut Posts: 52,360
    Maybe, maybe not. Completely different speaker designs.
