Mini models of the SDA SRS. i need help with crossovers.
Great job. One day there will be a set of Shorty 1.2 TL's with 1-piece faceplates in that same fashion. I'm a fan.Don't take experimental gene therapies from known eugenicists.
Update
Sure are putting a lot of work into those. I hope they turn out ok.
What is all the black stuff inside the cabinets? -
The cabinets look really narrow (depth). Did you do calculations for frequency response of the box and PR? Where's the bracing? Just wondering.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
It”s 1 layer of butyl. Sound dampening
Yes the calculations has been done. With ”exact” spare room for filters. If bracing is needed, i Will add some later.
The plan right now is to use them as a 2.1 system, paired with a 8-10’ sub.
Lerjebrink wrote: »
That's what I thought. Unfortunately, your speakers will sound lifeless with that material in them.
Rip all of it out and use polyfill. -
Lerjebrink wrote: »
If it is a few mils thick butyl rubber, it will help with cabinet vibes/resonance.
You will probably have to brace a few spots in the middle line to really mitigate cabinet vibes just like the original 1.2'sDon't take experimental gene therapies from known eugenicists. -
A few mils??? You need to look closer. Heck, he even stated, one inch.
Unless my eyes are painted on, it desn't look like 1"to me,correct me if I'm wrong ,the comment stated ,1 layer of butyl rubber.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
You are correct, 1 layer. Still a lot thicker than a few mils.
So basically Dynamat without the aluminum skin. Just as reflective of airborne sound waves as MDF (probably more) but will help dampen cabinet resonances some.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Lerjebrink wrote: »
No. In this case you are wrong. My friend made a pair of JBL minis, where i 3D printed a bunch of parts to him. I heard these speakers with and without this 3mm butyl sheets. It made very much difference, in a really good way.
Maybe, maybe not. Completely different speaker designs.
Looks great! 3D printed boards and cap holders? One thing I noticed is you have 2 inductors that are pretty close to each other without aligning one magnetic field perpendicular to the other one. Those will interact with each other.George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »Looks great! 3D printed boards and cap holders? One thing I noticed is you have 2 inductors that are pretty close to each other without aligning one magnetic field perpendicular to the other one. Those will interact with each other.
I think i solved it, thanks man -
You wont believe thisYou should have posted this on April 1st. It would have made more sense. You should also build a mini Matthew Polk in a white lab coat that you can stand next to them. I have to admit though, you do have good taste in brandy.Lerjebrink wrote: »
Next print will be with white lab coat, this was just a test
Lerjebrink wrote: »
@audioluvr ...The famous colloquial idiom is definitely warranted here....
Can you make him loosen up a bit and have him playing air guitar?George / NJ
iFi nano iDSD DAC
iPurifier3
This is way cool.
Applaud your vision.
Can’t wait to hear your impressions of your project. -
Gardenstater wrote: »Can you make him loosen up a bit and have him playing air guitar?
I want one of him sitting in this ...
Swear i understand all americans calling us swedes crazy
Lerjebrink wrote: »Swear i understand all americans calling us swedes crazy
And your meatballs suck too....
Ingenuitive, not crazy. Enjoying the show and skills here.
The high chair is from Squatty Audio, and only required by the height-challenged members here for the factory 1.2TLs.
Fixed it for you and them.The high chair is from Squatty Audio, and only required by the members here for the flawed design of the factory 1.2TLs. -
The 1.2tl model:
George / NJ
iFi nano iDSD DAC
iPurifier3
The Squatty Deluxe.Don't take experimental gene therapies from known eugenicists.
Some progress on the tweeters!
