Billet RD-0194/8 Tweeter Bezels
12346»
    pitdogg2 Posts: 27,549
    Never liked the look after that plastic bent.
    No disagreement here!
    xschop Posts: 5,657
    Badass. I bet Megadeath never sounded so good lol
    Toolfan66 Posts: 18,286
    xschop wrote: »
    It’s Deth , not Death. But I’m sure you know that!!🤣
    Tony M Posts: 11,859
    edited April 28
    I didn't... :s Now I do. ;)
    xschop Posts: 5,657
    Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
    xschop Posts: 5,657
    If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.
    xschop wrote: »
    I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies.
    billbillw Posts: 7,956
    edited April 30
    I think this is what is known as a Mandela effect?
    Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
    xschop Posts: 5,657
    edited April 30
    They must have graduated from The Quality Learing Center.
    xschop Posts: 5,657
    xschop wrote: »
    That's quality manufacturing.
    edited April 30
    xschop wrote: »
    xschop wrote: »
    Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense.
    xschop Posts: 5,657
    8 left from this run.
    Anyone building Monoliths?
    F1nut Posts: 52,146
    xschop wrote: »
    xschop wrote: »
    Someone didn't measure twice.
  • bcwsrt
    bcwsrt Posts: 2,582
    Or, they did, but they used Tom’s ruler …
    Brian
    xschop Posts: 5,657
    6 left.
    xschop Posts: 5,657
    Made 6 extra alloys plates this weekend.
    So 12 left
    xschop Posts: 5,657
    10 available.
    xschop Posts: 5,657
    8 to go.
    PSA:
    Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
    and post pics when done.
    xschop Posts: 5,657
    Down to 4
